Old 05-12-2009, 08:32 AM
newcity01 newcity01 is offline
Mein Auto: 1999 BMW 528I
White smoke coming from under hood
While the car (1999 528i) was running, I smelled something burning from under the hood. I saw wisps of smoke coming from the components shown in the photo below.
Can someone tell me what this part is and how to fix the problem?
Old 05-12-2009, 08:34 AM
Ryan M Ryan M is offline
Mein Auto: .
That's an oxygen sensor. You shouldn't have any smoke coming from it because it should be screwed down tightly enough where no exhaust gas escapes. Now as for your white smoke problem, that could be a few things.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 05-12-2009, 09:15 AM
lsfeder lsfeder is offline
Mein Auto: 540i M , 560SEL
Check the brake lines behind the heat shield coming out of the ABS/DSC module. The lines on my car ruptured there causing white smoke to escape from that area of the engine bay.
Old 05-12-2009, 11:01 AM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
+1
Check the two rubber hoses located just beyond where your blue arrow stops.
Old 05-12-2009, 11:05 AM
beems4life beems4life is offline
Mein Auto: 528i
Could it be leaking oil? Valve cover gasket? I'm having the same thing...seems like burning oil to me.
Old 05-12-2009, 11:07 AM
+1
How's your break/clutch pedal feel?
Old 05-12-2009, 11:15 AM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Possible if the gaskets are bad enough.
