E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Ordered a camera mount for the coupe.
Not wanting to drop megabucks on the harness bar and camera mount I found a suction cup type mount from ioport that seemed to work good enough for some NSX owners. It should be here Friday and I will put it through its paces and report back.
I had that one and it sux,seriously. I have a HMS harness bar I will sell you if interested.
jseely at arcsight dot com Thanks! |
If it shakes more than a crack addict in recovery then Ill send it back!
Here's what I just got....
I had good luck with this package. I purchased it at Smile because they were ~$20 cheaper than anywhere else for that model. I used it on the right rear window and ran through the Dragon ~15 times without any issues. The only problem I had was that it leaves a little rubber residue behind. It create little rings that you have to rub off. But I expect any suction cup mount will do that.
Here's the stuff I have.... Suction Cup Description: http://www.bogenphoto.com/product_te...=92&itemid=350 Purchase Here: http://www.smilephotovideo.com/detai...&itemno=BG3294 Mounting Plate Description: http://www.bogenphoto.com/product_te...hp3?itemid=325 Purchase Here: http://www.smilephotovideo.com/detai...&itemno=BG2934 3/8 to 1/4 Adapter Description: http://www.bhphotovideo.com/bnh2/con...ku=5588&is=REG Purchase Here: http://www.smilephotovideo.com/detai...&itemno=BG3358 Good Luck! |
I just tested it out a but, works awesome IMO. Mounted on back window also, took very smooth footage with my Canon Elura2 mini DV.
The one I have is the HAMA autostativ mount. $99.
Im happy it works for you, its probably my stiff suspension setup.
Im running Bilsteins and H&R's - still worked great. Might also be the camera quality.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
