Trouble code P0700 and P0710 - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 05-14-2009, 05:26 PM
jppj36 jppj36 is offline
Mein Auto: 325i
Anyone know whats up with P0700 (Trans control system malfunction) and P0710 (Transmission fluid temperature sensor circuit malfunction). Any idea what thats about?
There is some mild knocking. Its a 2003 325i with 52000 miles. I did just change the oil last week? Checked the transmission fluid, that seems fine, nice and red.
Old 05-14-2009, 06:34 PM
v33_n0d3's Avatar
v33_n0d3 v33_n0d3 is offline
Black Mage
Mein Auto: 2001 325i Sedan
What type of oil did you use?
Old 05-16-2009, 04:38 PM
Mein Auto: 325i
I used BMW oil 5w30 and filter from the dealer. I turned the check engine light off and it has not come back on in 2 days?
Old 05-16-2009, 05:58 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I am thinking you checked the power steering fluid resevoir, unless you got under the vehicle and removed the fill plug and stuck your finger in there.
Old 06-03-2009, 05:19 AM
Mein Auto: 325i
You are correct. I just checked the power steering fluid. My mistake. Do you know where the transmission fluid temperature sensor is on the E46. Thanks
Old 02-16-2017, 01:00 AM
Raul arce Raul arce is offline
Mein Auto: BMW 325i
Did you ever find out what was the problem I have both of those codes as well
Old 02-16-2017, 04:34 AM
jcase jcase is offline
jcase
Mein Auto: 2002 330CI
The best way to diagnose this is to test with a compatible BMW scanner so you can read the trans codes and what the fluid temp sensor is saying.
On my 2002 330ci the connector on the left rear of the trans had some resistance in it so the trans temp was reading 320 degrees when it was only 180. I unplugged it, cleaned and lubed the pins.
So far it has helped
