Old 01-29-2015, 11:33 AM
gnik14 gnik14 is offline
Mein Auto: 2000 E46
Radiator flush
Iím going to do a coolant flush this weekend on my 2000 E46 323i. What is the correct way to flush? There is a drain plug at the bottom of the radiator, would draining from the radiator be sufficient, or do I have to drain from the engine block plug too?
Old 01-29-2015, 12:01 PM
harleyrob harleyrob is offline
Mein Auto: 2004 330 CI
You will need to drain from the engine block as well. Make sure you bleed the system really well after adding fresh coolant.
This link is actually for a "cooling refresh" but will give u guidance on coolant flush and fill. IF, you don't have something guiding already.
http://www.bmw330ci.net/maintenance/completecoolant.php
Old 01-29-2015, 02:51 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Put about 3 tablespoons of baking soda in a gallon jug, fill with hot water, shake well to thoroughly dissolve the baking soda, then use this to flush the system. This will help to neutralize any old deposits that have turned acidic over time.
New fluid should consist of 50% BMW coolant, and 50% distilled water....
Bleed thoroughly when finished.
The road goes ever onward....
(R.I.P. Jever)
