#51
after reading above, my 2000 528i H-7 halogen headlight prob might have been answered. Priced new aftermarket headlight assem's @ $190 each, & factory replacements were a joke approachin $450 each.....ouch, but it IS a Bimmer. Aim is low, & both sides are shaky. Sounds like both vert & horiz adjusters on both sides are shot. Wanted some pointers on removing the headlight assembly, since ALL of the plastic is ridiculously brittle....really don't want to unknowingly move something I don't need to for fear of snappin it. Anyone have simple instructions on not only removing the headlight assem, but also accessing/replacing the adjusters?? Just didn't want to touch any part that doesn't need touching, don't ya know. Appr any help...........
#52
#53
Stig,
thx for the direction. I think this is what I need. Appr it |
#54
ok gotta quick question.....
i recently bought the metal adjusters and swaped them out and right drivers side is fine, my passenger side was a bit low, so i started to adjust the inner knob and the beam started to go up but then just fell and now it won't go back up? any clue as what happened?
Just a thought....but when I replaced mine w/ the aluminum ones the aluminum socket ball that goes into the plastic piece on the headlight was loose compared to the OEM plastic socket ball. If you adjusted it even a little bit the alum. adjuster popped out of the plastic piece and the entire chrome trim that holds the projector and has the high beam reflector just hung there because there was no support from the adjuters. I had to use some alum tape and make some thin shims so the ball didnt pop out of the plastic socket. Thats probably what happened to yours. |
#56
Probably....if you cant adjust them back up more than likely something is wrong internally.
#58
thanks man, i will have to check it out. do you have any pics of how you taped them up?
I'll take a pic when I get home in a few hrs. and post it up for you. |
#60
great, thanks man
Yeah thats it then. Heres a pic....I used some aluminum tape as a shim in the empty hole....both adjusters have the same hole so shim both adjusters just in case. When you put the shim it, it puts pressure on the tab thats holding the aluminum ball into the socket.
#63
Yeah you can use duct tape....or any tape or thin cardboard like from a ceral box. You want it pretty tight so it puts pressure on the tab. If its not putting enough pressure on it, the aluminum ball could pop back out over a hard bump etc. It took me a couple of tries to get the shim to the right thickness. |
#65
A friend just called asking about the aluminum headlight adjusters for his 1998 E39 ... I can't find 'em.
Am I right that, for my USA 2002 E39 525i, I can get (per side): - $500 Hella OEM headlights - $275 Aftermarket DEPO/DJAuto headlights - $165 Aluminum adjusters (both sides, must open sealed lights) - $85 Plastic adjusters (each side, must open sealed lights) But, for his USA 1998 E39 528i, the choices seem to be different (per side): - $500 Hella OEM headlights - $275 Aftermarket DEPO/DJAuto headlights - Aluminum adjusters are not available ??? - $12 Plastic adjusters (per side, do not need to open sealed lights???) Is this a correct assessment of the best choices available to fix broken headlights? REFERENCES: (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) Last edited by bluebee; 04-01-2010 at 11:03 PM. |
#68
The reason there are no aluminum parts for the old lights is you can get adjusters for the 97-2000 lights by BMW part number 63120027924. Pound that number into the search box on the EAC site if you need adjusters for the old lights.
no one is going to pay for CNC machined parts when they can get plastic for 8 dollars a light. The reason our aluminum parts are so popular is because it's either buy those and fix them yourself or buy a set of new Hella angel eyes or some aftermarket crap headlights. The aluminum adjusters for the 2001+ lights are in stock on our site at the moment. If you do not see an add to cart button- here's an idea- call or email us! We get these in lots of 10 or 20 sets. They go quickly and then we have to wait for the next batch. We will always have more in the near future though. |
#69
also for you guys experiencing problems with the adjusters popping out, just wrap the ball end in a layer of tape to make it slightly bigger. You most likely were rough on the ball socket removing the old ball and now it's loose. There is no need to prop up the retainer like that. On the 03 lights that cannot be opened I snap the retainers out as it is the only way to get the old balls out since you can't open the lights. none of those guys have adjusters popping out of socket.
That retainer does not really do anything once the ball is seated fully, it is the friction of the ball itself that holds it in place. |
#70
Id rather make a little shim to put a little pressure on the tab than wrap the ball w/ tape....to each their own.
#71
For the record, there's a really nice headlight polishing thread here.
The DIY shows how to remove the headlights better than in this thread. And, it contains stunning before and after pictures ...
#73
Speaking of adjusting headlights, Ågent99 and I teamed up to come up with the following suggested headlight-aiming procedure for the E39 Hellas:
(0) Find a wall at least 4' high abutting about 35' of level drivable ground (1) Keep handy a flashlight and one, or better yet, two 6mm allen wrenches (remember, it's dark)
(2) Inflate tires properly, tank 1/2 full, typical driver in seat. (3) At night, park just close enough to the wall to fit in between as you string the tape. (4) Mark a 10' horizontal line with tape on the wall at the headlight midpoint; the result should look something like this: ---------------------------------------- (5) At each headlight centerpoint, mark a vertical line with tape on the wall to make a plus sign (one for each headlight center point); the result should now look something like this: --+---------------------------------+-- (6) Back the vehicle until the headlights are 25 feet from the wall and perpendicular to the wall. (9) With the 6mm allen wrench, adjust both headlight's inside (medial) adjusters such that the brightest area is about 2" below the horizontal reference tape.(7) Switch the low beam on (both high & low adjust together for each headlight). (8) Chant "Lateral adjusters handle lateral movement; medial adjusters perform vertical movement", three or four times (or until at least the lateral:lateral part sinks in). (10) Then, with the 6mm allen wrench, adjust each headlight's outside (lateral) adjusters such that the bright spot is also about 2" to the right of the vertical reference tape (i.e., the plus sign) for each side respectively. (11) As a doublecheck, switch on the high beams (the respective alignment should remain the same). (12) The result should look something like this: --+----------------------------------+-- -----*----------------------------------* The asterisks above denote the final positions of the brightest points of your headlights after adjustments (ignore the hyphens with the asterisks...they were necessary for proper placement of the asterisks) Last edited by bluebee; 10-09-2010 at 08:07 AM. |
#74
I did some research into the old posts (back to 2008) and it seems like the procedure listed above is still a bit wrong and needs to be honed.
So I opened a thread to clarify which of the three below is correct: - One adjuster for vertical, one for horizontal - Both adjusters do vertical, there is no horizontal (as stated in the diagram below) - The adjusters are actually DIAGONAL (one is mostly vertical, the other is mostly horizontal) Here is the thread opened to resolve that issue.
#75
While I'm still on this focus, I want to propose an adjustment procedure ASSUMING that DIAGONAL motion (with MOSTLY-directions) is what is actually occurring.
This proposal ASSUMES the answer to this question is "diagonal": (1) Inflate tires properly, tank 1/2 full, typical driver in seat. (2) Find a wall at least 4' high abutting about 35' of level drivable ground (3) Obtain two 6mm allen wrenches (each headlight's two adjusters must be turned simultaneously an equal number of turns in the same direction) (4) Find a small self-standing or clipping light to see under the hood. (5) On a dark night, park just close enough to the wall to fit your body in between as you string the tape along the wall. (6) Mark a 10' horizontal line with tape on the wall at the headlight midpoint; the result should look something like this: ---------------------------------------- (7) At each headlight centerpoint, mark a vertical line with tape on the wall to make a plus sign (one for each headlight center point); the result should now look something like this: --+---------------------------------+-- (8) Back the vehicle until the headlights are 25 feet from the wall and perpendicular to the wall. (13) Using both 6mm allen wrenches in place on one headlight, twist both adjusters an equal number of turns in the same direction such that the brightest area moves diagonally to about 2" below the horizontal reference tape and to 2" to the right of the vertical reference tape (i.e., the plus sign) for each side respectively (the spec is 2.1 inches/52mm +/- 1.3 inches/33mm).(9) Switch the low beam on (both high & low adjust together for each headlight). (10) Wait about 1 minute as the Xenons do a calibration run which takes about 30 seconds to complete. (11) Cover one headlight with an opaque blanket or towel so that only one light is being aimed. (12) Chant "Lateral:lateral, Medial:vertical", three or four times (or until at least the lateral:lateral part sinks in). This is because the lateral (outside) adjuster MOSTLY moves the headlight laterally (i.e., side to side); in actuality, it moves the headlight aim diagonally, but mostly horizontally. Likewise, the medial (inside) adjuster MOSTLY moves the headlight vertically (i.e., up and down); in actuality, it moves the headlight aim diagonally, but mostly vertically. (14) As a doublecheck, switch on the high beams (the respective alignment should remain the same). The result should look something like this: --+----------------------------------+-- -----*----------------------------------* PS: It's confusing to me how BOTH adjusters work in tandem diagonally; but that's what the BMW E39 headlight aiming instructions seem to indicate. Last edited by bluebee; 10-10-2010 at 10:03 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
