Old 05-18-2009, 09:59 PM
alfonso12 alfonso12 is offline
El Macho
Mein Auto: 1999 540i 6 speed sport
Seat adjustment plastic cover broke off?
Does anyone know where I can find a replacement for the plastic cover on drivers side where the seat adjustments switches are on? Can any one recommend where I can order this piece or where to find/order the snaps?
Old 05-18-2009, 10:08 PM
TheStig TheStig is offline
Some say...
Mein Auto: N/A
Use RealOEM for part numbers and go to Tischer BMW or Crown auto to order the parts.
Old 05-19-2009, 05:04 AM
Fudman's Avatar
Fudman Fudman is offline
Part number is 5210821922*. Last digit is for color. Switch is the same for all seats. Part is about $10. Dealer should have it.
Old 05-19-2009, 05:58 AM
sidneyj sidneyj is offline
Mein Auto: '03 BMW 530i
Dealer. You get both the right and left side as a set and there around $40 max for the pair.
Old 05-19-2009, 10:15 AM
540-S3 540-S3 is offline
Mein Auto: 1997 540i6
I bought the whole set, but only needed 1 rail. I need to check to see what I used, but I would be happy to send you what you need. Also note that my interior color is gray, so yours would have to match. Let me know your color and I will look through my stuff.
o 1997 540i6 o Dinan supercharger system o Dinan stage 3 suspension system o Dinan wheels o UUC EVO3 SSK/DSSR o SS Headers - M-Tech illuminated shifter o M5 3.15 LSD o Cubic trim o Gauge rings o OEM In-dash CD o Ultimate pedals o Hella AE's o M-Sport Steering Wheel o 400 RWHP o
Old 05-19-2009, 11:02 AM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Mine is gray and broken PM me if it doesnt work out with the OP.
Old 05-19-2009, 11:15 AM
Anthony MV Anthony MV is offline
Mein Auto: 2003 E39 M54
to OP:
just did mine saturday........two torx 25 screws..........one at the very trailing edge of seat bottom (about were the seat belt dissapears) push the leather back n you'll see it, the other torx screw is at the leading edge below seat cushion front (you'll see the hole), then just below that you'll see a black push pin,use a plastic fork shaped panel removal tool, then another push pin underneath the panel,towards the center, (i broke this one off,a bit too tedious for me)
and then another all the way back to the bottom of the seat back (use a flash light to see it) use the panel removal tool for this one again......dont worry about breaking the push pins , just make sure you get replacements at the dealer.........look up driver seat control panel on this site someone posted the part #'s for the push pins
SCHNELLER ARSCHLOCH!!!!!
BMWCCA # 386993
Mods: 2011 Mazda MX-5. Mazda Ipod kit,weathertech liners,garmin nuvi 1390 LMT,eclipse sunshades,front plate delete. Soon: tint 20% sides 5% back. Covercreaft NOAH car cover
Old 05-19-2009, 11:46 AM
Ops! I thought he was talking about the seat rail cover being broken.
Old 05-19-2009, 04:57 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Details about ordering the BMW E39 "seat covers" and hole covers
You have to (clairvoyantly perhaps?) know that the covers come in pairs yet all the hole covers don't come in that set (only some do); so you have a bunch of things to order.
See details here ...
Tips and suggestions for replacing destroyed E39 driver seat adjustment control panel
See cross references here
Power seat switch failure
Old 05-19-2009, 07:41 PM
El Macho
What colour do I have?
Thanks for all the amazing help. My interior is beige but I see that there are 2 tones. How do I find out which beige tone is mine?
Old 05-19-2009, 08:14 PM
bluebee's Avatar
From this picture in the aforementioned post, perhaps that's the SANDBEIGE and PEARLBEIGE in the realoem diagrams?
Since I only have gray (grau), I'll let someone with the beige seat covers answer why there are two different beiges listed weirdly below.
Old 09-23-2012, 04:43 PM
Kel Kel is offline
Mein Auto: BMW 5
Where is cheapest place to buy either new or used set of these ( part 5107058008)?
Old 09-23-2012, 11:01 PM
bluebee's Avatar
Here is the generic answer ...
- Supplier prices lookup comparison engine (1) & BMW salvage (junkyard) parts lookup engine (1) & BMWfans search by part number (1) & Realoem nominal prices by part number (1) & EACTuning actual prices by part number (1) & BMW of South Atlanta actual prices by part number (1) & Maxmillian BMW dealer prices by part number (1) & the most often recommended parts suppliers (1) & what BMW E39 parts & supplies are best to buy OEM (1) & joining BMWCCA to lower parts costs (1) (2) & what parts to always get OEM (1) which BMW dealers match prices (1) & in situ pictures of common parts of the M54 engine (1)
Old 09-24-2012, 08:26 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
put the part# in www.furiousmethod.com and shop around
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 09-24-2012, 09:02 AM
eparayno's Avatar
eparayno eparayno is online now
Mein Auto: 2001 530i
When these break its usually the mounting tab that snaps where the front torx screw is. I removed and fixed mine. The broken part of the tab was still underneath the screw to I glued it back using industrial strength epoxy and for reinforcement I glued metal washers on each side of the mounting hole.
I'm about 190lbs and the cover does not budge and looks like is permanently fix. Only cost me the price of the epoxy and a day of waiting for it to dry.
Old 09-24-2012, 10:41 AM
bluebee's Avatar
Just so you know, that's the very first link in the list we provided the OP from the bestlinks...
