E36 (1991 - 1999)
Old 05-19-2009, 05:17 AM
dazza_gt dazza_gt is offline
Send a message via MSN to dazza_gt
Mein Auto: 1992 325i
Question window switch upgrade
hi
i have a 1992 325i, and the window switches have the white backing(no auto up/down feature) i have aquired switches with the green backing(with auto up/down feature)
i have the wiring loom aswell/. has anyone installed these switches? and if so what is required?
regards, daniel.
Old 05-19-2009, 07:21 AM
Tree36 Tree36 is offline
Mein Auto: 93 325i
I think the automatic up and down have to do with the window motor not the switch. I replaced a door and came across this. the window switchs just have a simple plug on the back. i might be wrong about the up down thing tho but they sell 2 diffrent kind of window motors on bav auto.. GL
Old 05-19-2009, 05:21 PM
i hooked up a multimeter to the both switches to see which wires were which(up/down) i connected the positive and negative to a 9 volt battery, and found the on the white based switch the up/down wire had constant voltage of 9 volts, but when the up button was pushed, the voltage on the up wire would go down to 0volts, and same with the down button and wire, but on the green based switch, it did the opposite, - going from 0volts to 9 volts. i respect it could be the auto motor needed to put the window down automatically, but to simply get the switch to work, would a relay of some sort (maybe a comfort relay) be needed?
thanks, daniel
Old 05-19-2009, 05:34 PM
Soviet1942's Avatar
Soviet1942 Soviet1942 is offline
Zinnobitch
Send a message via AIM to Soviet1942 Send a message via MSN to Soviet1942
Mein Auto: 1987 325is
Want to sell me the white backing window switches? I need two, pigtails would be epic if you have
Old 05-20-2009, 04:37 AM
naa sorry, il be needing them soon to replace a couple in my car, but it depends if i get the other ones to work the way i want. sorry mate.
Old 05-20-2009, 07:53 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
thanks, daniel
More likely, you will need the fancier, ZKE central module that understands the switch's one-touch protocol. I suspect your car has a ZVM module that doesn't.
I don't know if it is worth the trouble, but it might help if you were to post a picture of the modules behind the glove box. I believe that's where you will find these things on a RHD car.
Old 05-20-2009, 08:14 AM
bboyvek's Avatar
bboyvek bboyvek is offline
vek-mw
Send a message via AIM to bboyvek Send a message via MSN to bboyvek
Mein Auto: 1995 bmw 325i
wouldnt the one touch modules that umnitza, ddmtuning, and other sell do the trick?
Originally Posted by bimmerbarbie View Post
(I wasn't going to write anything in this just due to the title, but that was too funny Bboy.)
Criminal Law Attorney Carrboro
Costum Web Applications Web Design
Clasificados Empleos Ventas
Landscaping
Old 05-20-2009, 08:50 AM
johnf's Avatar
John Firestone
Probably with the older, non-one-touch switches: the aftermarket one-touch module could provide the missing, one-touch electronics and jam protection. The module might need some tuning, however, if it was designed for a heftier window.
For example, I was able to use a couple Autoloc WC1000 units for my rear, swing out windows -- after I had changed three resistors in each to accommodate the windows' starting delay, travel time and stall current. Fortunately, they could have been designed 30 years ago, which made them straightforward to decode and modify.
auto, power, switch, upgrade, window
