E90/E91/E92/E93 (2006 - 2013)
I just took our car in for it's final checkup maintenance under the 4-year warrantee. They replaced the brake pads and sensors but did not replace the rotor because they were within specifications.
The rotor thickness currently is 22.8mm, the wear limit is 22.4mm, that's right we are .4mm away from the rotors being out of spec and needing replacement (Note: 0.4 millimeters = 0.0157480315 inches). I am sure that within 3 weeks these rotors will no longer meet the BMW specs, does anyone know where BMW takes the measurements of the rotor and if within 600 miles or so we will use up 0.016" of rotor material (that's about the width of a hair on each side of the rotor)?
Drama queens don't wear panties. |
How many miles do you have on your car and did the computer say it was due for service? I have about 7K miles left before my warranty expires but the soonest service is for and oil change in 9K miles which I'll have to cover that out of pocket.
I am thinking about doing so serious mountain road driving this weekend just for the hell of it.
Go out and do some hard driving and braking!
Hi BLT, it's late and I don't have my spec book but you may be confused. Brake rotors have 3 specs. The first is nominal thickness which is what they were when they left the factory. The second is the minimum turning spec, ie, the minimum thickness that a shop can machine the rotors to. The third is the discard thickness, anything thinner than this and they are scrap metal.
Are you confusing the second and third? If they cut them slightly larger than the minimum machining spec than they have done you no harm and not 'cheated' you in any way. |
The difference between minimum and maximum rotor thickness is usually 1.5mm-2.0mm or thereabouts. So I suppose they would argue your rotors are not quite 3/4 worn?
John - E90 325i - Alpine White - Black Dakota - Brushed Aluminium - M-Sport - Innovations - Steptronic - PDC |
"42942 road test and did hear a squeel noise under light application. It coming for the front wheel. I check and found that front brake is at 61/2mm and sensor is touching rotor. I found SIB#34-08-08. I perform that and found that it need front brake pads and sensor. Rotor measure at 22.8mm and min. 22.4 So I replace front brake pads and sensor only. Road test and the noise is gone."
Drama queens don't wear panties. Last edited by BLT; 05-19-2009 at 07:56 PM. |
* Here in New England you will find that 99.9% of all rotors have to be turned due to rust build up on the inner and outer edges which will often be rubbed by the new pads. Def makes a Rrrrrrrrrr noise when braking! |
I'll see what BMW doctrine is on this in the morning. Stay tuned. |
We currently have 42,328 miles on here and the computer say the brakes should be replaced at 43K.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
Wow. That's BS.
I'd take it on a very long spirited mountain road drive and then to another dealership. Tell them that you measured them with several calipers and they are under spec. The other dealership's caliper needs calibrated. |
Thanks, that's what I thought as well.
Maybe get a good night's sleep and wait until DSXMachina returns with the specs?
I'm thinking that if they are indeed still 0.4mm off minimum thickness and the max-min difference is 1.6mm then it may take as far as 11,800 miles until you wear them out. I would think the amount of fuel used in order to do this might make it cheaper to replace the rotors yourself when the time comes.
most likely orig is 24mm with min being 22.4mm. like others have said, 25% remaining is still quite a bit left.
2010 Acura TSX manual "You know, by the time you become the leader of a country, someone else makes all the decisions. You may find that you can get away with virtual presidents, virtual prime ministers, virtual everything" - Bill Clinton "Give me control of a nation's money and I care not who makes the laws." - |
Do you mean the brakes should be replaced after 43K more miles or less than a 1K miles? Hmmm...so maybe the brake sensors actually work? I'm still confused on what they actually do, LOL
The thickness of a new two sided razor knife blade is .61mm, the thickness of a brand new single edge razor blade is .22mm. So I think it is safe to say we are talking about razor thin margins here.
What is the estimated cost of replacing the rotors?
About $150-180 each axle for the parts, I am not sure what the labor cost are.
fixed prices for common service items up here. prices seem reasonable.
http://crm.bmw.ca/microsites/aftersa...P.aspx?lang=en edit: also it's very unusual to only change the pads but not the rotors on a bmw. they're usually changed at the same time.
2010 Acura TSX manual "You know, by the time you become the leader of a country, someone else makes all the decisions. You may find that you can get away with virtual presidents, virtual prime ministers, virtual everything" - Bill Clinton "Give me control of a nation's money and I care not who makes the laws." - Last edited by HW; 05-20-2009 at 06:09 AM. |
#25
Are you out of time on your maintenance plan? Sounds like your pads/sensor were replaced under warranty to fix the squealing, whereas the rotors couldn't be replace under warranty cause they were still within spec. And you are 700 miles too soon per the computer to have maintenance plan cover them.
-Brian "Used cars are our entry cars." - Luca di Montezemolo |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
