E46 M3 (2001-2006)
Old 05-19-2009, 08:41 PM
mathguy94 mathguy94 is offline
Mein Auto: 2006 M3
06 M3 died out while driving and had to be towed home
As a new member, I am asking for some help. I have a 2006 M3 convertible that my wife was driving the other day. She was just cruising, when all of the sudden it died and never would start again but does crank over. She did not notice any idiot lights before it died. Had it carefully towed back into the garage where it is currently sitting. Car has about 55,000 miles. Fuel pump primes when key is turned on. The car is sounding strange when it cranks over. Just keeps cranking kind of slow, but does not even hiccup. Please help. Is this a broken timing belt??? Fuel problem??? Spark problem??? Any suggestions would be great. Thanks in advance.
Old 05-19-2009, 08:57 PM
Ryan M Ryan M is offline
Mein Auto: .
Are you still under warranty? Why not take it to the dealer?
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 05-19-2009, 09:08 PM
Grentz's Avatar
Grentz Grentz is offline
BMW d Driver
Mein Auto: e46 M3, 335d
Sounds like something fuel system related. Fuel Pump/Fuel Filter/Spark Plugs are the first things that come to mind.
Old 05-20-2009, 01:05 AM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
Plugs/Battery i would think. I am not sure if its the same as an e30 but fcsteve had the same problem. i guess the battery didnt have enough to give it spark and we used my car and jumped his and it started right up.
Old 05-20-2009, 03:30 AM
MJS MJS is offline
HMFIC
Mein Auto: 2002 ///M3
+1 on the dealer. Could be anything. But if you're not getting an SES light, I'd guess (and guess is the key word here) that it's fuel system related.
46 & 2 just ahead of me...
Old 05-20-2009, 07:31 PM
Mein Auto: 2006 M3
My warranty ran out at 50,000 miles. Is there a schrader valve on the fuel rail somewhere that I can test for pressure? I can hear the fuel pump when the key is turned to the on position. Does my car have a timing belt or chain? I will try to jump it. To the garage I go.
Old 05-21-2009, 07:39 PM
Mein Auto: 2006 M3
Well, I tried to jump the car to no avail. I think it is a fuel problem. I have two new questions:
1. Where would be the best place to check the fuel pressure?
2. Where is the fuel filter located?
Thank you.
Old 05-21-2009, 08:12 PM
MJS MJS is offline
HMFIC
Look for the fuel filter cover on the bottom of the car. Not sure exactly where. The diagram on RealOEM doesn't tell you exactly.
http://www.realoem.com/bmw/showparts...08&hg=13&fg=10
http://www.realoem.com/bmw/showparts...84&hg=16&fg=15
Hopefully those links help.
Old 05-22-2009, 09:17 AM
bimmerboss bimmerboss is offline
Mein Auto: M3
if you're in the mississauga area give techmax a call - ask for attila 905.795.0419. Tell him what you told us and I can almost guarantee you he'll know what it is right away.
I agree tho sounds fuel system or battery related
Old 05-29-2009, 10:11 PM
Mein Auto: 2006 M3
Battery is perfect. Checked spark-OK. Replaced fuel pump-No help. I will be towing it to the dealer next week. This was my last resort.
Old 05-30-2009, 06:59 PM
Phin Phin is offline
Mein Auto: 06' BMW M3
I'm sorry to hear about your car problem. I too,just recently bought an 06' M3(coupe)I've had it a month.I drove it all over the place the week or so,then I had the orange SMG light(tranmission) go on and I was scared.I took in to the dealer,it's still under factory warranty and all it was was a relay which they replaced and the DME recall(emissions) was done at the same time.
Sorry for the rant, but please let us know what the problem was/is when you find out.GL man and I hope it's nothing major.
Oh btw,if you know a BMW "indy" shop (not dealer) it might be worth towing it there first,tell them you want them to "READ" all your fault codes,at least this way your aware of the issues with your car before the dealer "tells" you whats wrong with it.Just my 2 cents...
Phin
Old 06-02-2009, 07:39 PM
Mein Auto: 2006 M3
Towed the car to the dealer today (love BMW roadside assistance-FREE towing) and they claimed that the cylinder #3 was not showing any compression. They said that one of the valves "kissed the piston". Probable cause- overreving. NO WAY! I baby my car. That is not the reason, BMW USA had better be involved with this. There had to be a defect in the building process. My car is just out of warranty at 56,000 miles. The dealer said that BMW may still help me out. I pray that they do. Anyone ever experience this valve hitting piston problem on a car that is driven carefully?
Old 06-03-2009, 12:34 PM
sfca-325i sfca-325i is offline
humanum est errare
Mein Auto: which day is this?
Sounds like a money shift. 6sp?
David
2004 e83 3.0, 2003.5 e46 M3 Cic, 2008 e9x 335xia, 2008 Sienna XLE Limted AWD
Gone: 2006 B7 A4, 2003 Honda Pilot EX-L RES
Old 06-06-2009, 09:29 PM
Mein Auto: 2006 M3
SMG--- and my wife was driving it when it happened.
Old 06-06-2009, 09:32 PM
edgar620's Avatar
edgar620 edgar620 is offline
Mein Auto: M3-Imola Red Interior
Damn that scares me. It better not happen to me. Keep us updated as to what happens.
Old 10-06-2010, 09:51 AM
trism3 trism3 is offline
Mein Auto: e46 m3 6spd
Died out while driving
Same thing happened to me last Sunday and had to get it towed home.
I pulled these fault codes: 2C 8F 69 0E 01.
2C : Thermal oil level sensor
8F: E-box fan
69: Engine coolant temp. plausibility
0E: Tank small leak
01: Fuel pump relay
I don't hear any buzzing/energizing/pressurizing sound when I turn the key. I had checked the fuse (#54) and replaced the fuel pump relay, but it doesn't fix it.
I guess the fuel pump is done, what do you think?
Please advise
Thx
Old 10-11-2010, 11:35 AM
Fixed it. It's the fuel pump.
Old 10-13-2010, 08:35 AM
StrangeC StrangeC is offline
Mein Auto: E46 M3
Didnt you replace the fuel pump at home?
Old 10-13-2010, 09:23 AM
Yes, I did. At first, I planned to have it done at an indy. shop, but found out it's not hard to replace so I did it myself. Saved me $400 for labor and towing.
Old 10-27-2010, 12:17 PM
caden caden is offline
Mein Auto: '05 M3--'11 X5 50i
Your wife should only be allowed to drive your ///M3 in the "P" mode...just J/K
'00 GS 300-sold
'04 325ci black/black-sold
'05 X5 3.0i-black/biege - aka "work horse"- sold
'08 535i-"never more HPFPs"-sold
'05 ///M3 'vert - my Valium, still kicking strong
'11 X5 50i:blck/blck-all the goods, except the M package- sold
'14 528xi: dd- sold
'15 x5 50i:black/mocha- modest goods, with the M package
'15 f80 ///m3: black/black with modest goods
