Old 08-02-2003, 08:53 PM
daven daven is online now
Mein Auto: 1999 BMW Z3 Coupe
Supercharged 2.8 or S52?
Take an existing 2.8 Z3 coupe. You can supercharge it or replace it with an S52. The suspension and diff are already S52 level.
David
Blue Ridge Mntns, NC
1999 2.8l Z3 Coupe
Arctic Silver
Old 08-03-2003, 06:06 AM
Randy Forbes's Avatar
Investigative Tinkerer
2.8 Z3 Coupe suspension is not the same as ///M version (S-52) unless you or someone else has already swapped front struts, springs, upper bearings, brake calipers/rotors and rear crossmember, trailng arms, axles, brakes, shocks, springs and differential.
Randy Forbes
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
Old 08-03-2003, 09:14 AM
Front & rear struts, springs, and sway bars are off a lowered S52 coupe, the diff is from an S52 roadster. All the rest is stock 2.8 (upper bearings, brake calipers/rotors and rear crossmember, trailng arms, axles)
David
1999 2.8l Z3 Coupe
Arctic Silver
Old 08-03-2003, 03:01 PM
In that case, I think it would be easier to supercharge the 2.8 compared to transplanting an S-52. Depends on whether you have real cheap access to a decent 3.2 versus the cost of forced induction.
Randy Forbes
Old 08-03-2003, 03:11 PM
Thanks. Mirrors my thoughts. Know of any 2000 Mcoupes
totaled because of rear end damage?
David
1999 2.8l Z3 Coupe
Arctic Silver
Old 08-03-2003, 04:50 PM
JediZ JediZ is offline
Mein Auto: 2001 Z3 Coupe 3.0i
Randy,
I know the crossmembers of the M versus Z3 Coupe carry different part numbers, but how exactly are they different other than exhaust hanger mounts? I've heard they are identical other than that and was wondering if you could confirm based on your experience. Thanks.
Old 08-03-2003, 07:53 PM
Originally Posted by JediZ
Randy,
I really cannot say, I have only been up close and personal with the M version. I do know that the M XMBR has "HP" painted on it.
Considering the narrower axles/trailing arms, the pickup points may be relocated. No proof though
Seems that somebody thought the M piece was a heavier gauge, but I have no way to substantiate that, it may be pure speculation...
ID:	17291   Click image for larger version
Randy Forbes
