Fuel Pump Warranty Exension - Bimmerfest - BMW Forums
Old 05-22-2009, 11:49 AM
excogitus excogitus is offline
Mein Auto: 2008 335i
I just received a notice from BMW of an extension on the fuel pump to 10 years. Note that it comes in a plain envelope with BMW indicated only on the back of the envelope. It could easily be missed.
Ken
Old 05-22-2009, 11:54 AM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
Ken,
Could you post the relevant portion of the letter here?
Thx, gsl
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 05-22-2009, 11:57 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
here's the SIB:
http://www.bmwtis.com/tsb/bulletins/...p/B130309g.htm
SI B 13 03 09
Fuel Systems
April 2009
Technical Service
SUBJECT
N54 - Special Limited High Pressure Pump (HDP) Emissions Warranty of 10 Years/120,000 MilesMODEL
MY 2007/2008 E60, E61 – 535i/535xi with N54 engineMY 2007/2008 E90, E92, E93 – 335i/335xi with N54 engineMY 2008 E82, E88 – 135is with N54 engineSITUATION
BMW has become aware of a potential problem that could affect the durability of the High Pressure Fuel Pump (HDP) of certain MY 2007/2008 BMW automobiles equipped with N54 engines. We estimate that only a small percentage of vehicles will actually develop a problem. Vehicles affected may have the Service Engine Soon lamp illuminated with various low fuel pressure-related faults (e.g., 29DC, 29F1, 29F2 ) stored in the Engine Control Module (DME). Also, the affected vehicles may experience an extended engine starting time ("long crank") or reduced engine performance ("engine failsafe mode") when the High Pressure Fuel Pump malfunctions.CORRECTION
In the event that the High Pressure Fuel Pump of an MY 2007/2008 3 Series vehicle (335i/xi Sedan/Coupe/Convertible), MY 2007/2008 5 Series vehicle (535i/xi Sedan/Sports Wagon), or MY 2008 1 Series vehicle (135is Coupe/Convertible) with the N54 engine exhibits the symptoms listed above, it should be replaced with the improved part (P/N 13 51 7 592 881). For HDP diagnostic and replacing instructions, refer to SI B12 55 06 and RA 13 51 017, found in BMW TIS.PARTS INFORMATION
Part Number
Description
Quantity
13 51 7 592 881
HDP High Pressure Fuel Pump
1
11 61 7 547 242
Profile manifold gasket kit
1
13 53 7 582 770
ASA bolt M8x17.5
1
EMISSIONS WARRANTY INFORMATION
As a commitment to our customers and to demonstrate our confidence in our product, BMW will extend the emissions warranty of the High Pressure Fuel Pump (HDP) from 4 years or 50,000 miles to 10 years or 120,000 miles, whichever comes first.The emissions warranty extension for this component applies to the above-listed models only, and is transferable to any subsequent purchaser of these models.This extended emissions warranty is applicable to vehicles registered in all 50 states.Warranty coverage for all other parts is not affected.BMW will inform all affected owners of the above-listed models of their extended High Pressure Fuel Pump emissions warranty. A sample letter is attached.The following Emissions Warranty Information should be used if the High Pressure Fuel Pump (HDP) replacement becomes necessary, as outlined above:*******> ********>
Defect Code
13 51 90 12 00
Replace HDP pump. Includes deleting any
HDP fault codes & adaptation values stored in the
Main Work
Labor Operation:
Labor Allowance:
00 58 118
25 FRU – E60, E61
20 FRU – E82, E88, E90, E92
22 FRU – E93
+Associated Work
Labor Operation:
Labor Allowance:
00 58 687
24 FRU - E60
23 FRU – E61
18 FRU – E82, E88, E90, E92
20 FRU – E93
Note: The following explanations spell out the correct use of the work times.*******> ********>
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 05-22-2009, 12:23 PM
DJEcLeCTiK's Avatar
DJEcLeCTiK DJEcLeCTiK is offline
Gentleman Extraordinaire
Mein Auto: 2009 E92 335i
So they are implying that '09s have no HPFP issues? Or are they going to wait two years to add '09s to the list?
2009 E92 335i xDrive (Ordered 3/21/09 / Completed 5/4/09 / Delivery 6/6/09)
Space Gray Metallic / Black Dakota Leather / Gray Poplar Wood Trim / ZPP / ZCW / ZSP with 18" wheels / StepTronic / Navi+HD Radio / Logic 7 / iPod+USB / PDC / Anti-Theft
Old 05-22-2009, 12:31 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Orient, I've always wondered what length of time one FRU is. Can you tell me?
Old 05-22-2009, 12:32 PM
nhman nhman is offline
Mein Auto: 2016 M4 SO w/ GB pending
I received the same letter today. It is filed. Hopefully I can stay with the original fuel pump.
Regards,
NHman
Old 05-22-2009, 01:08 PM
BerfsBimmer's Avatar
BerfsBimmer BerfsBimmer is offline
Boosted Bavarian
Mein Auto: '08 335Ci
I’ll be waiting for my letter of “reassurance”. I find it a bit odd they classify an HPFP under the emissions warranty.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=93468&dateline=1203123566
'08 E92 SpaceGray/Gray/Burl/ZSP/ZPP/ZCW/Step/Nav/CA/6FL/HD/Original HPFP
Old 05-22-2009, 01:09 PM
i think its 7.5 minutes, or 1/8th of an hour. there was talk about it going to 1/10th of an hour....
Old 05-22-2009, 01:31 PM
GarySL's Avatar
Originally Posted by Orient330iNYC View Post
Awesome Orient. I look forward to my 'Dear Valued Customer' letter
Thx, gsl
Old 05-22-2009, 02:25 PM
Kurt_OH's Avatar
Kurt_OH Kurt_OH is offline
First Timer
Mein Auto: Me: M3; Her: 335i
I did NOT get a letter in the mail, BUT I made an appointment to have my dealer retrieve my summer tires from their storage, install them and put my winter tires/rims in storage, and while I was there having the swap done, they informed me verbally that the warranty on my HPFP had been extended from 4/50k to 10/120k miles. They also printed out a piece of paper that ALMOST displayed all this info: printer printed the WIDTH of landscape mode but on paper in portrait mode so the right 1/3 of the page is missing.
Originally Posted by PhillyNate
I just love how a 4 year old car/design is STILL the benchmark which other automakers aspire to reach. Still winning comparisons . Still very much in the conversation. Is the E9x M3 a legend? You bet your @ss it is.
Old 05-22-2009, 02:30 PM
figure99 figure99 is offline
Mein Auto: 09 335i, Acura
It will be interesting to see how this progresses. I believe a few users have reported HPFP problems on their 09. I haven’t had any problems, but it’s early still…
2009 335i Sedan - ED 12/08
SG/Oyster, 6-speed MT, Premium, Sport, Nav, Logic7, iPod, heated seats
“If everything seems under control, you’re just not going fast enough.”
-Mario Andretti
Old 05-22-2009, 03:43 PM
Chach Chach is offline
The Dude abides.
After seeing this thread, I went out to my mailbox and there was the letter from BMW. Sweet! This is good to see, as I've had the hpfp replaced twice now. Glad to see that BMW is offically addressing this.
2008 E90 335i / 6MT
Old 05-22-2009, 05:43 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Thanks, makes sense! I used to think when they gave 10 FRUs to do a job that it must be tenths and therefore one hour. I thought they weren't giving enough time. If it is 7.5 minutes then 10 FRUs equals an hour and a quarter. Much better.
But everyone else quotes time in tenths, it would seem logical that BMW would do the same. Might be a holdover from when 7 1/2 minutes made sense but I don't know why that would be.
Old 05-22-2009, 06:00 PM
Bill-SD's Avatar
Bill-SD Bill-SD is offline
Mein Auto: 2007 335i Coupe
Originally Posted by nhman View Post
i received the same letter today. It is filed. Hopefully i can stay with the original fuel pump.
Regards,
nhman
+1
E92 335i - Monaco Blue/Saddle
F30 328i - Alpine While/Black|SportLine
Old 05-22-2009, 06:23 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
Me too. Got the letter today. The wife gave me a hard time. 'uh, you got a letter from BMW today'
"Was it about the high pressure fuel pump?"
'Yeah'
I go run over there and get the letter.
'You know, if I told you it was a hundred dollar check, you would just leave it there'
"Grunt" (to myself, the HPFP ain't no hundred dollar item, babe.)
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 05-22-2009, 06:47 PM
The Dude abides.
'Yeah'
Exactly. On my second HPFP repair, as I'm picking up the car my SA gives me a sheet for me to sign and says something to the effect of, "Sign here so we can charge BMW another $750."
2008 E90 335i / 6MT
Old 05-22-2009, 07:54 PM
bmw-hoya bmw-hoya is offline
Mein Auto: 2008 Montego Blue 335i
Talking
'Yeah'
Too funny! I can't wait to get home to see if I got it, too!
Old 05-22-2009, 09:14 PM
strider41 strider41 is offline
Mein Auto: E92 335i
Got mine too.
08 E92 335i, Crimson Red, Black Leather, Aluminum, Premium, Sport, Step, Paddles, Heated seats, IPOD/USB and HD radio.
Old 05-22-2009, 10:12 PM
Thehammocklife's Avatar
Thehammocklife Thehammocklife is offline
Mein Auto: 335i
I wonder if this applies to us up North. Wouldn't make sense that it would though, the cars cost more, get less too. Probably will we filed under the get less clause.
Old 05-22-2009, 10:43 PM
vocalthought vocalthought is offline
A thought that speaks
Mein Auto: Monaco Blue E92 335i
I just received my letter. 10 years or 120K miles. Not bad.
8/4 ED at BMW Welt
8/11 Drop-off at Harms.
8/12 Started thumb twiddling
10/25 Redelivered
2008 E92 335i MT Monaco Blue, Saddle Brown, ZPP/ZSP/322/415/653
Old 05-23-2009, 05:08 AM
Kurt_OH's Avatar
First Timer
Yea, within about 10 minutes of saying I did NOT get the letter, I went downstairs and it was in the day's mail.
See attached scan
Name:	BMW HPFP Warranty Extension Letter - small.JPG
Old 05-23-2009, 09:28 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Got mine too. As much as I don't like playing Russian Roulette with fuel pumps I am happy to get the 10/120. Let's say I eventually need the pump replaced (the odds are against it but still higher than me winning the lottery), I will still have a guarantee, on a very critical and expensive item, good for 10 years. I'm satisfied with that.
(Note to BMW Marketing: Don't congratulate yourselves, this should not have happened in the first place.)
Old 05-23-2009, 02:47 PM
wouvlfe wouvlfe is offline
Mein Auto: 335i sedan '08
See attached scan
ditto. got mine today.
gj bmw.
Old 05-23-2009, 02:52 PM
GarySL's Avatar
And mine arrived today (west coast delivery). & filed away....
Old 05-23-2009, 05:58 PM
srobmw's Avatar
srobmw srobmw is offline
Mein Auto: 2009 M3 Coupe
Add my letter to the pile as well.
2009 M3 coupe,interlagos blue,6mt,loaded19" hre comp 97s,powerchip,h&r springs,hamann front splitter,eisenmann race exhaustDelivered 7/10/09
