E34 (1989 - 1995)
Old 05-26-2009, 11:13 PM
mdj89 mdj89 is offline
Mein Auto: corvette
trans fluid in a 525i
On a 1995 bmw 525i, does the transmission fluid have to be change?
Old 05-27-2009, 08:37 AM
Tourburgring Tourburgring is offline
Mein Auto: 1993 525iT
I would do a search on 'Transmission' there are plenty of posts and opinions regarding this subject.
Personally I would recommend a Fluid & Filter change at least every 80k. BMW do list it as part of their Inspection II Service schedule. No Transmission Fluid is good for the life of the car or the transmission. Just like engine oil its lubrication properties decline over time and the additives package is depleted. The 525 Automatic Transmission is known to run hot which only adds to the problem. You will see some posts that claim changing the fluid will cause sludge to be displaced which will damage the Tranny. My take is that if there is sludge in the tranny its going to cause damage anyway, better to try and remove it with new fluid and a new filter. "Power" transmission Flushes are however to be avoided as this can force dirt particles that are maybe already trapped in the filter back into the transmission.
Old 05-28-2009, 05:54 AM
woodnthings8's Avatar
woodnthings8 woodnthings8 is offline
Mein Auto: 1995 525i olympics editio
"Lifetime" means until the transmission fails! Change the fluid like Touburgring says.
Drain the trans, pull both the pans, replace the filter and gaskets, fill her back up (from underneath on a 95) Get enough in the trans to get it running and idle it until it comes up to temp (Warm on the pan around 80-100 degrees) check the level with the car running and in park or neutral. Top off until runs out the side of the fill hole. Make sure the car is level when doing this! You should be good for another 60 -80 K depending on how you drive.
1995 E34 525i Olympics Edition Oxford Green Metallic
2008 E63 650i Black Sapphire Metallic
1994 E34 525i Alpine White- SOLD
2007 E90 335i Sapphire Black- SOLD
