E46 (1999 - 2006)
Old 05-28-2009, 10:44 AM
Flatman's Avatar
Flatman Flatman is offline
Mein Auto: 2005 325ci
New Wheels!
These are from a 135i. This is with no spacers. No rubbing at all.
Front 18x7.5 offset 49 (215/40/18)
Rear 18x8.5 offset 52 (245/35/18)
2008 328i Coupe - Alpine White
2005 325ci - TiAg
Old 05-28-2009, 10:45 AM
Missmodena310's Avatar
* BLONDETOURAGE 2010*
Mein Auto: BMW
looks nice!
Old 05-28-2009, 10:47 AM
Flatman's Avatar
Thanks, I think they look so much better than what I had before!
2005 325ci - TiAg
Old 05-28-2009, 10:48 AM
CaptainTrap's Avatar
CaptainTrap CaptainTrap is offline
a man made of men like me
Mein Auto: 2001 330i 5MT ZSP
nice conservative rims with style. flows nicely with the OEM stock look of the car. great job!
2001 330i ZSP 5MT H&R Sport Cup Kit 18" VMR v710 18x8.5
BMW CCA #: 399644
Old 05-28-2009, 11:12 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Yep, no problems with those offsets. Very similar to the 68M and 135M offsets (+47 and +50). Looks great!
Old 05-28-2009, 11:32 AM
Spdu4ia Spdu4ia is offline
Mein Auto: X5 4.4i
5mm spacer on the rear would look nice... Wheels go well with the car
-Travis-
Old 05-28-2009, 11:40 AM
Flatman's Avatar
Yeah..I am thinking 5 or 10mm. You think I need one in the front as well?
2005 325ci - TiAg
Old 05-28-2009, 11:45 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Keep in mind spacers can cause premature wear of wheel bearings and stuff. I'd just get wider tires next time around (225/40/18 and 255/35/18), should help fill out the tire profile a bit. The sizes I posted are the 'correct' ones for the E46 anyway. Right now your speedo is going to read a *bit* high.
Old 05-28-2009, 11:51 AM
roverT's Avatar
roverT roverT is online now
Send a message via ICQ to roverT Send a message via AIM to roverT Send a message via MSN to roverT Send a message via Yahoo to roverT
Mein Auto: '04 ///M3 Individual
How does it do that? The weight of the wheel is out farther stressing the balls?
--Trevor--
Vancouver, BC
Old 05-28-2009, 11:52 AM
Flatman's Avatar
Supposedly only 0.4% different right now from what I calculated. There is NO WAY I could get a wider tire in the back without a spacer. It is pretty close right now. That is why I am contemplating a small spacer. Most likely, I will keep it like this until I need new tires. Then I might get some spacers, wider tires and drop it a tad.
The LAST thing I need right now is for my balls to be stressed!!!
2005 325ci - TiAg
Old 05-28-2009, 11:54 AM
Bucknekkid's Avatar
Bucknekkid Bucknekkid is offline
Fully Dysfunctional
Mein Auto: 02 325i
Looking good ! !...
Today is more like it is now, than it has ever been before...
That costs too mucking fuch ! !...
Sig courtesy of SolidJake...
Old 05-28-2009, 11:55 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Exactly....
Old 05-28-2009, 11:56 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
I bet you could...every ZHP has 255/35/18 on +50 rear wheels. My tires are more than 2mm from the strut...
H&R does make a 3mm spacer, for what it's worth.
Edit: Also, your calculation is wrong, it's 1.1% (still not enough to really matter).
Old 05-28-2009, 12:36 PM
roverT's Avatar
Exactly....
How much life do yo think 5mm or 10mm wold make? Would your edumacated guestimate be? 5% shorter life or much more dramatic?
--Trevor--
Vancouver, BC
Old 05-28-2009, 12:46 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
It's hard to say... jvr has had a bearing failure at very low miles simply due to his driving (sticky tires, lots of track days).
I guess it's enough of a loss that I wouldn't bother for simply aesthetic reasons. If the tires fit and don't rub, why bother...
Old 05-28-2009, 12:54 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Regardless of the rate of wear, it`s just a bad idea....you`re multiplying the leverage on the bearings substantially with spacers, plus you`re introducing another potential failure point at a *very* critical spot....and they serve NO function besides Show & Tell, so why bother ?
The road goes ever onward....
(R.I.P. Jever)
Old 05-28-2009, 01:13 PM
milobloom242's Avatar
milobloom242 milobloom242 is offline
gashlycrumb
Mein Auto: 325i
Those wheels look great on the car
Old 05-28-2009, 02:04 PM
delirium330's Avatar
delirium330 delirium330 is offline
John Voight's BMW
Mein Auto: 05' 330i ZHP 6MT
looks great man, love those rims.
My Merit Badges:
CVV, VCG, OFHG, Full Cooling System, Tensioners, Plugs, All Fluids, Fuel Filter, Angel Eyes, Kidneys, Badges, Front/Rear Clears, Battery, Brakes, CDV, V1 Install, TB Housing, ICV.
Old 05-28-2009, 02:06 PM
Flatman's Avatar
Looks great!
Originally Posted by Bucknekkid View Post
Looking good ! !...
Thanks for all the positive comments, everybody!
2005 325ci - TiAg
Old 05-28-2009, 02:19 PM
Mein Auto: X5 4.4i
just get them... I think 10 will be pushed out pretty far. 5mm will be more convervative.
-Travis-
Old 05-28-2009, 02:23 PM
Flatman's Avatar
Really? 10mm is still less than 1/2"!
2005 325ci - TiAg
Old 05-28-2009, 02:54 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Looks good. I'm not a fan of band-aid spacers either. Wear those tires out and go wider next time. 5mm more tire will fill that 5mm space you're trying to remove with a spacer.
For the record, I think my bearings were fine. It was the diagnosis that failed. But, I had an opportunity to buy and use a big honkin' torque wrench. Glad I did cuz I've used it a few times since then too!
I never pass up an opportunity to buy new tools!!
Jeff R.
Old 05-28-2009, 03:43 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I like those a lot
Old 05-28-2009, 04:23 PM
Mein Auto: X5 4.4i
thats funny ... i'm trying to find smaller tires to stretch so I can run a larger spacer
-Travis-
Old 06-15-2009, 10:00 AM
Flatman's Avatar
2005 325ci - TiAg
