Old 06-19-2016, 12:01 AM
Richesloo Richesloo is offline
Mein Auto: BMW 528i
2001 e39 540i m sport //AC condenser issue with wires being torn
Hello, appears my AC condenser had suffered some wires being torn when the water pump blew, causing the belts to snap. Although all was replaced but it seems my mechanic had missed this AC condenser with the wires issue. Basically when the AC is on it does not blow cold air. When k bought it back to mechanic they said it is holding freon but due to the wire being torn. They will have to take out the piece and see if they can savage it or replace another AC condenser. Any ideas? I am kind of lost as I felt thy should of seen this when replacing my belts n water pump and such. Seems like double work to me especially when they are a Dinan BMW shop.
Sent from my iPhone using Tapatalk
Old 06-19-2016, 12:25 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Take it back and get them to sort it.
BTW, you do not have an M-sport, unless you have a Canadian model.
Old 06-19-2016, 10:13 AM
Mein Auto: BMW 528i
2001 540i sport manual original 6 speed is not an m sport?
Mein Auto: BMW 528i
Or u mean it's not an true m tech like the 03
Old 06-20-2016, 11:37 PM
flyride flyride is offline
Mein Auto: 530i, 330i, M3
Condenser is the AC radiator in the front of the car. If the condenser was damaged the system would not hold refrigerant.
I think you may mean compressor, which is driven by the A/C belt. There is a single trigger wire that controls the compressor. When a water pump goes, it takes out the serpentine belt that drives the alternator and power steering but the A/C is a separate belt. I don't know why that would cause the trigger wire to be damaged though, as it is on the outside of the compressor far away from the rest of the engine.
I think what they are saying is that the compressor is not coming on due to the trigger wire being damaged. The wire unplugs from the compressor, so replacing the compressor would not help if the wire is damaged. The wire is very simple so it could just be repaired without removing the compressor.
I think it's possible that they may not have seen damage to the wire, although it is weird not to have tested the A/C after replacing all the belts.
Hopefully that will help you with your discussion with the mechanic.
Old 06-21-2016, 02:24 AM
Mein Auto: BMW 528i
Thanks man and yes big help indeed. You put things into correct terms and prospective. Just got to get dirty and hands on now.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Old 06-21-2016, 02:27 AM
Mein Auto: BMW 528i
I have the thicker black wire covering thinner wires intact and I have an grey or silver thin wire which is torn and looks like it's placed on the ax compressor itself. I guess it's an ground wire of some sort.
Old 06-23-2016, 06:20 PM
Mein Auto: BMW 528i
OK I see the single wire you spoke of and the wire loose I was referring was a thinner grey one which I believe is the ground wire. However while trying to secure the ground wire I did the opposite and tore it off the Compressor. Will a speaker wire work I'm place of the ground wire?
