Old 06-02-2009, 08:21 AM
wvmikep wvmikep is offline
Mein Auto: 2005 Z4
Question iPhone and the Z4 (bluetooth & audio question)
I recently bought a 2005 Z4 that has BMW Assist. I believe it has bluetooth as well since the steering wheel controls are there and the radio responds. However, I can't seem to pair my iPhone with it, something I was able to do with my previous two Bimmers ('01 325i and '06 330i). The instruction booklet is just confusing as can be. Am I missing something?
Also, I don't have the iPod adapter and from what I can tell, it wouldn't work properly with the iPhone anyway. Are there other options available to me so I can listen to my podcasts? My previous car had an aux input jack.
Old 06-02-2009, 11:22 AM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
My iPhone paired without a problem by using the manual.
As far as ipod integration. I have the Nav in my Z4MC and I installed the Intravee II ipod adapter. I love it!
CDV delete, clutch stop, strut bar, stainless brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, RAD wheel locks, M strut caps, roundel under hood, Intravee II ipod adapter, Homelink garage opener, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK,…
Old 06-02-2009, 11:33 AM
Mein Auto: 2005 Z4
There were a couple times during the attempt it asked for the 4 digit PIN or whatever. Maybe it's set to the previous owner's? Is there a way to reset it? The manual didn't indicate that there was any way.
Old 06-02-2009, 01:15 PM
misha75 misha75 is offline
Mein Auto: 2005 Z4
There should be a white card that comes with the car that has the code.
Old 06-02-2009, 01:48 PM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
Yeah you need the BlueTooth Pairing Code (should be a separate, glossy card with the owners' manual) that you should be entering when your phone prompts you for it. Also, one important thing to note about using the iPhone with the BMW BlueTooth is that the iPhone bluetooth volume works separately from the BMW bluetooth volume. Typically, after pairing your phone the first time, you'd make a phone call, turn the volume up on your iPhone to max (which sticks from then on) and then adjust the BMW bluetooth volume as needed. (Otherwise, if you leave the iPhone bluetooth volume at default, you'll be hard pressed to hear the person on the other end)
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 06-02-2009, 05:08 PM
bten's Avatar
bten bten is offline
Luv'in Texas
Mein Auto: '08 Z4 3.0si
If you can't find the white card, try to find the bluetooth module itself. It will have the 4 digit paring code on a sticker on the outside. This is how I got it for my X3. I think the module is near the battery. IIRC, the four digit code was next to the letters PC.
2008 Space Gray Z4 3.0 si, Saddle Leather interior
2011 Nissan Frontier King Cab
2010 Lexus RX350
Old 06-02-2009, 05:10 PM
bten's Avatar
Luv'in Texas
You can add an Aux input to your radio. Search this forum.
2010 Lexus RX350
Old 06-02-2009, 05:34 PM
Ron Stygar's Avatar
19,585 Miles
TCU
Old 06-02-2009, 06:33 PM
bten's Avatar
Luv'in Texas
Pass Key, not Pass Code. Thanks Ron
2010 Lexus RX350
Old 06-03-2009, 12:34 PM
Feathers Feathers is offline
I'm just chuckling here....RON has everything. Simply amazing source of information. Thanks for being on the forum Ron.
Jim
Old 06-04-2009, 07:30 PM
rpsz4's Avatar
rpsz4 rpsz4 is offline
Mein Auto: 2008 135i
I am using an iPhone 3G and had no problems pairing the phone to the car. Once you have the code for the car and the phone tells you to enter the code, you are good to go. Works great and have not had any problems with it.
Old 06-23-2009, 06:54 PM
07z43.0i 07z43.0i is offline
Mein Auto: BMW Z4 3.0i 2007
Does anyone if the bluetooth that the 2007 Z4 comes with can be paired for both phone calls and music with an iPhone? I.e., I understand I can use BT to make phone calls, can I also use it to play music (rather than having a separate aux for music or a ipod kit)?
Old 07-20-2009, 09:43 PM
Ron Stygar's Avatar
19,585 Miles
Pass Code.
Deutsch Kode = English Code
Old 07-20-2009, 10:38 PM
KevinC's Avatar
KevinC KevinC is online now
your average JAMF
Mein Auto: '07 Z4MC,'05 330Ci ZHP
Negatory.
I need to try my 3GS with Bluetooth, I'm hoping it might work better. My 3G was awful, I couldn't hear incoming calls (despite having the volume all the way up on the phone) and I couldn't be heard on the other side. And this was with a coupe. Sheesh.
Kevin C.
Chandler, AZ
'07 Z4M Coupe ..LL93707
'05 330Ci ZHP ..PD99819
Old 07-20-2009, 11:12 PM
KevinC's Avatar
your average JAMF
Negatory.
Kevin C.
Chandler, AZ
Old 07-21-2009, 07:06 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I am beginning to wonder when Ron's car is actually assembled.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 07-21-2009, 08:42 AM
Jigsman Jigsman is offline
Mein Auto: BMW Z3
I have a the same problem please let me know if your able to find a solution. I just tried to pair my phone on a 2004 Z4 this morning but my Iphone does not find the car. I have the card with the blue tooth but the car never shows up. Any advice would be appreciated.
Old 08-28-2009, 08:19 PM
z4mlover z4mlover is offline
Mein Auto: z4m
my iphone just cannot find the car...some one please help!!
Old 08-28-2009, 11:37 PM
b-y's Avatar
b-y b-y is offline
bimmerfest Supporting Member
Mein Auto: 328xiT & M roadster
Assuming you are in the Sydney (in Oz), all of the above may not apply. US Z4s (2005 & up) came with a BT-enabled TCU, but that is not necessarily the case for cars delivered outside of the US. See if you can visually locate the TCU (see Ron's photo).
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.)
Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.)
Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue.
Old 10-06-2009, 06:04 PM
viper2544 viper2544 is offline
Mein Auto: 2006 Z4
BMW puts the Bluetooth buttons in all Z4s, Bluetooth equipped or not, so button does not necessarily equal Bluetooth unfortunately. The car will only be in pairing mode for the first 60-90 seconds after it is turned on, so:
Put your key in the ignition
Have your code ready
Get your phone ready to pair
Then turn the vehicle on and have your phone look for available Bluetooth
Took me two tries to have it pair correctly, but works like a charm after that.
Old 10-07-2009, 06:20 AM
jragan's Avatar
Originally Posted by viper2544 View Post
...The car will only be in pairing mode for the first 60-90 seconds after it is turned on...
Assuming BlueTooth is installed, the car also goes back into pairing mode (if unpaired) when you activate Telephone mode.
Old 05-11-2011, 04:10 AM
T1berious T1berious is offline
Mein Auto: Z4M Roadster
Hi,
I hope someone here can shed some light on this issue for me to.
I have recently got a 2007 Z4M Roadster and have had no joy getting the car to show up on BT on my iPhone 3GS. We have an E92 2007 330 and that set up with no issues at all.
I've found the manual useless (the button above the storage compartment? huh?) and some of the info on the web differing. (hold talk button on steering wheel, no wait hold the button in console between the seats, erm have ignition set to 1, erm do a rain dance etc)
I'm at the stage where I might go to a dealer but really don't want to as I should be able to do this my self.
The Z4M has sat nav.
Any help would be greatly appreciated!
Many thanks,
T1b
Old 05-11-2011, 09:44 AM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
Do you have the assist buttons between the seats? No assist, no Bluetooth. The assist TCU should go into paring mode for a few seconds every time you start the car.
Old 05-12-2011, 12:44 AM
Hi
Yes I do have the button in the flip down panel between the seats
Cheers T1b
Old 05-12-2011, 07:55 PM
centerice centerice is offline
>55 F, then top down!
Mein Auto: 2005 Z4
I'm wondering how many times he has disassembled and reassembled it? From the looks of all the articles, at least once a year! Course he's so good at it, it probably takes him the same time to do it that it takes me to just to clean those dang wheels.
"Punch it Boss, I see a cat!!"
bluetooth audio iphone
