Old 08-07-2003, 04:58 AM
AC's Avatar
AC AC is offline
Track-tard
Mein Auto: 2001 M Coupe, '10 535 SW
tell me the trick for getting the rear OEM springs out
I'm installing a new suspension and the front was quite easy but getting the rear OEM springs out is proving pretty hard. I have disconnected the shock and sway bar link, let the trailing arm drop. what is the trick? is it a brute strenght thing? (I haven't disconected the drive shaft... but I've read it's not necessary..)
Old 08-07-2003, 05:29 AM
Randy Forbes's Avatar
Investigative Tinkerer
The trailing arm will droop enough to get the springs out (on an M Rdstr), are you sure you're not restricting droop with either the exhaust or halfshafts?
BTW, I didn't have to drop the swaybar link (both sides droop together), but I did undo the exhaust/halfshafts.
Randy Forbes
2001///M Rdstr Steel Gray
Old 08-07-2003, 05:45 AM
AC's Avatar
AC AC is offline
Track-tard
I have to double check the exhaust but it didn't look to me like it was in the way. I really don't want to mess with the halfshaft. Most of the install how-to's say that it is not strictly necessary.
Old 08-07-2003, 05:57 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
We used very little force on a prybar to help work them out. There was not enough play to simply pull them out when we lowered the jack supporting the trailing arm. I would assume this is the same on the M as Shawn McCurdy did it this way as well.
Suspension How-to
Old 08-07-2003, 06:06 AM
AC's Avatar
AC AC is offline
Track-tard
Somehow I don't think my trailing arm drops as much as that.... anyway it's off to Sears to get a pry bar.
Old 08-07-2003, 07:09 AM
elfhearse's Avatar
elfhearse elfhearse is offline
Mein Auto: 00Z3MC,10e91-ZMP,14e8928i
Disconnected the sway bar links and I ended up putting my spring compressor on to finally shorten it up enough for removal.
Pick that up @ Sears while you're there.
Old 08-07-2003, 09:52 AM
Ron Stygar's Avatar
19,585 Miles
You can lower the differential at the rubber mount.
Old 08-07-2003, 09:59 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
This is a really easy way to do this. Use a second jack under the diff to hold its weight. This way you can avoid messing with the 12 x E12 bolts at the 2 half shafts. I always replace those E12s (aerospace habits die hard) so the diff mount method is really nice.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 08-07-2003, 10:19 AM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
you can try a pry bar on the control arm to get additional clearance, BMW service literature recommends dropping the halfshafts first, this is what is causing the binding
never tried it on the Zcoupe, but it worked on the M3 without dropping the shafts
Old 08-07-2003, 10:42 AM
AC's Avatar
AC AC is offline
Track-tard
well, the pry bar alone is probably not going to do it.... Ron (or anyone else) what's that about the dropping the diff?
Old 08-07-2003, 10:49 AM
JonM's Avatar
Moderator
Unbolt this bolt:
Like I posted above, you will need a jack to support the weight of the diff to lower it. You will be able to drop it down 1" or so, which should let the springs right out. No need to unbolt half shafts this way. I do not know torque value off hand, but search archives under my name or Ron's with "3.46" as search word and you will find it yourself.
Jon Maddux
Old 08-07-2003, 10:52 AM
AC's Avatar
AC AC is offline
Track-tard
thank you....but that picture begs the question: how do you keep the bottom of the car so clean?????
Old 08-07-2003, 10:56 AM
JonM's Avatar
Moderator
Once a year I clean it. It's a horrendous amount of work. In the words of an old man: "Once it's clean, it's easy to keep clean". Getting it there is what takes so long.
Jon Maddux
Old 08-07-2003, 11:16 AM
Ron Stygar's Avatar
19,585 Miles
Old 08-07-2003, 12:28 PM
AC's Avatar
AC AC is offline
Track-tard
Oh OK I got it now It was a real Duh! moment.......
OK ready? here's the hot tip:...... the car has to be in NEUTRAL! duh! as soon as it was the trailing arms dropped another half inch and the springs came right out sheesh! well at least I got a good work out!
Old 08-07-2003, 08:55 PM
TeamM3's Avatar
oh yeah, I meant to say that you may need to rotate the drivetrain to get the optimum CV joint positioning, which would have put you in neutral ... sorry
Old 08-08-2003, 04:43 PM
HaqDeluxe's Avatar
HaqDeluxe HaqDeluxe is offline
No can drive 55!
Location: Gainesville, VA. (somewhere outside the DC beltway!)
Send a message via AIM to HaqDeluxe
Mein Auto: 07' Z4 M Coupe
AC,
Don't believe JonM or Ron on that "we cleaned them up and keep them that way.." This is like the old navy trick of sending the new seaman after six feet of waterline! The both of them have a second car that was trailered directly to their garages from BMW, never ever even seeing the pavement! They then plan each and ever one of the "show me" picture post, knowing that all of us are just green with envy at the pristine state of their coupes, having a good chuckle at our expense!
"You know Ron!".. "Yes, Jon?".. "This photo ought to have at least a dozen of them out there on the ground, under their car, trying to get it this clean!"... "Thats some funny stuff, Jon! Your a riot!"
OK.. It's not really the truth.. But it's the only way I can live with myself!
I'm lucky to keep the inside that clean!
HaqDeluxe
AKA: Michael G.
78' E21 - 320i Saloon - Resedagreen-Met
08' E60n - 535xiT Sport Touring - Space Grey-Met
Old 08-08-2003, 06:21 PM
Wait until you see the bottom of Big Al's car, he's been polishing under there all summer!
Best we can hope for is that he hits some rain or construction zones on the way down
With his GPS, there's little hope of him getting lost on a dirt road...
Randy Forbes
