Old 06-26-2015, 09:42 AM
z3don z3don is offline
Mein Auto: 2001 z3
Not working covertible
Hello and help,
2001 z3 that for some reason the top does not want to work so I am doing it manually for now.
Fuses under the hood look fine.
I wanted to look at the switches in the center console but have not been able to remove it.
I tried to remove the tray, in the console, and got the front of it out, but could not get the rear to come out and did not want to break it.
I tried to remove the console by removing the one screw per side near the rear, but it did not seem to help.
What am I don't wrong and any help would be greatly appreciated.
Have a great day,
Don
Old 06-26-2015, 10:38 AM
Wolfbeef123's Avatar
Wolfbeef123 Wolfbeef123 is offline
Mein Auto: BMW ///M Roadster
Originally Posted by z3don View Post
Hello and help,
Have a great day,
Don
Check your brake sensor, if all lights are working then its fine.
If you lower the top and try to put it up will it work?
There's a microswitch located inside of the top which lets the system know that you raised it and to start the hydraulic pump.
That's what went wrong with mine.
Old 06-26-2015, 10:43 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
I would check the micro switch in the top frame over the drivers head. It is what tells the computer that you have pushed the top up the required amount before the pump takes over. There is also a switch on the brake which seems to fail a lot. It lets the computer know you have the brake pressed before the computer will let the top move. The console is a pain to remove. Here is a link to how it is done - http://www.bimmerfest.com/forums/sho...d.php?p=631115
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 06-27-2015, 07:41 AM
Mein Auto: 2001 z3
Brake Light Switch
After reading your responses and others on this site I checked and found that my tail lights were not working, thus it would appear that my brake light switch is defective or somehow not working properly.
I have to assume that once I figure out how to get it replaced/fixed my convertible top will again work.
Thanks to all who took the time to respond to my, not so unique, problem.
It's amazing how much you miss something, when it was working you took it for granted; IE: Z3.........
Have a great day and thanks again,
Don
Old 06-27-2015, 12:50 PM
Warning - Thin Air
I have note done this (yet), but here are some good directions telling how to do it.
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Old 06-29-2015, 08:10 PM
BMWFrenzy BMWFrenzy is offline
Banned
Mein Auto: 2002 BMW M Convertible
I think i'm having the same problem. Will take note of the comments here. I might need to check and see what's the real problem why the convertible top stopped working.
Old 06-29-2015, 08:25 PM
33Bravo 33Bravo is offline
Mein Auto: M Roadster
I just figured out that on my M roadster - it was the switch in the top. Easy test - just jumpered the switch and it now works fine. I'll replace the switch.
