E90/E91/E92/E93 (2006 - 2013)
Old 06-14-2009, 02:34 PM
Spagolli94 Spagolli94 is offline
Mein Auto: 2006 330i
Another Tire Pressure Thread
I'm starting another tire pressure thread b/c I have some specific questions and can't find answers using search...
My door jam and owner's manual say 32/26 for my 18" staggered sport package. However, this number is for the stock RFT. I'm running non-RFT so should I go higher, lower, or stay the same? To throw in yet another variable, I bumped up the tire size from stock. To bigger tires typically need more or less pressure?
I tried running some high pressures, but this made the tires feel a bit harsh and brought back bad flashbacks from my RFT days. Then again, if I go too low, the tires start to feel too squishy.
Given that most of my driving is done at 25mph over manhole covers and potholes (sad, but true), I'm more likely to error on the side of squishy. I had 35/37 in today and felt it was too harsh. I'm thinking of trying 31/33 - is that too low?
What are the rest of you non-RFT guys running? I'm sure if I lived out in the burbs, I'd go with a higher pressure 'cause the tires seemed really responsive with 35/37.
Old 06-14-2009, 02:47 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
Did you check the back of the manual? I recall they had some fairly long lists of options.
I don't think the RFT is different than the non-RFT when it comes to tire pressures.
I'd call somebody up at the Tire Rack and ask them. The guy I spoke to about something a while back was very helpful.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 06-14-2009, 03:07 PM
ish's Avatar
ish ish is offline
Mein Auto: 328xi M, Range Rover, 911
[QUOTE=Spagolli94;4267400]I'm starting another tire pressure thread b/c I have some specific questions and can't find answers using search...
QUOTE]
Those pressures sound way to low for my taste. I'm running 36f 34r on 18" non rft on my wife's X3.
PS. Great color combination on your car.....LOVE it!
"Ish...I have in the past mistaken you for a perverted chitbag...now I realize that I am not chitbag enough. You truly are a king among men.I am not worthy with such imagination."
Series 3 Guy - LRO Site
2013 550 xi Msport
2005 Range Rover HSE Grey/Grey
2009 MB C 300 4Matic
1997 Porsche 993 C4S Black/Black
2005 Jeep TJ
Old 06-14-2009, 03:21 PM
[QUOTE=ish;4267475]
QUOTE]
I know I think I tend to run much lower than most on this board. Then again it's all really dictated by my road conditions. Trust me, I wish I could run higher pressure and enjoy the benefits. In fact, if I ever plan a road trip out of the city, I plan on setting the pressure higher just for that.
I noticed all the combinations in my manual - but I thought those were for RFTs? Just for the hell of it, I tried 36/37 today. After a half hour, I measured the pressure and I was at 39/40. That's an acceptable increase (sun was out, roads were hot), but when they warmed up that high, they did become noticeably harsh.
Why is the stock setting 4psi higher in the rear? I've never understood this.
Old 06-14-2009, 03:23 PM
Maybe I should just stick to the stock setting then? Might be the safest bet.
Old 06-14-2009, 04:06 PM
Not a real doctor.
I would for now. But you did go to wider tires. I think that would make a difference in the pressure needed. Probably up from the standard pressures. I'm gussing 34/38.
Old 06-14-2009, 04:20 PM
So as a rule of thumb, do wider tires typically require higher pressure?
Old 06-14-2009, 04:22 PM
Not a real doctor.
I think so. But I'm no expert.
Old 06-14-2009, 04:36 PM
Yeah, but I heard you stayed at a Holiday Inn last night.
Old 06-14-2009, 05:35 PM
wrh3 wrh3 is offline
Send a message via Yahoo to wrh3
Mein Auto: 2007 M Coupe, 2008 M3
I run 36 front and 37 rear and find this to be the best from a performance standpoint (and even tread wear for the last two sets of tires), at least with H&R swaybars, M3 front suspension parts, and some aggressive driving
I think the danger of running low pressures is that your wheel is more susceptible to damage if you hit a pothole or other unavoidable road hazard......
Bill
Bill
2011 Lotus Elise R, 2010 Porsche Boxster S, 2005 Mini Cooper S
BMW CCA Member # 389948
www.billswebspace.com/bmwindex
Old 06-14-2009, 06:00 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
The best test of correct tire pressure is to check tire wear. The loading of your car and style of driving will determine the optimum pressure. I watch for edge wear on front tires as a sign that they are too low in pressure and for centre wear on the rear as a sign that they are too high in pressure. 36 psi front and back sounds OK to me for general touring. On track days taking it up to 40 psi will stiffen the side wall for better cornering. I agree that wider profile tires need higher pressure to create a good contact patch but again it is trial and error to get it right, in my opinion.
Don
328XiT Sonora
Old 06-14-2009, 06:18 PM
Don
328XiT Sonora
Old 06-14-2009, 06:23 PM
This is what I'm concerned about. I like the idea of dropping the pressure for comfort. But then I'm less likely pay as much attention to the pavement and more likely to damage a rim. Especially because I have the Koni FSDs helping to hide the potholes as well. I finally got my car all sorted out, so that's the last thing I want to do.
Old 06-14-2009, 07:01 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
[QUOTE=Spagolli94;4267494]
Because higher pressure in the rear increases understeer and BMW wants to make sure no one spins out in their new car while "pushing it" on curvy roads. Tho they (apparently) sell The Ultimate Driving Machine, not everyone who buys one can drive... so they make sure everyone *thinks* there's some magic to having wide rear tires running higher pressures. The reality of it is, wider rear tires = understeer... increase the rear pressure on those wider tires, even more understeer.
Size of tire has nothing to do with what pressure to run. 30psi in a 16" tire is the same as 30psi in a 22" tire... it's 30psi. Big rigs run super high pressures to support the heavy weight of the vehicle riding on them, not because they are big-ass tires.
Jeff R.
Old 06-14-2009, 07:55 PM
Thanks Jeff. I think I'd like to try matching pressures, or even going somewhat closer to matched. Given my horrendous pavement I have to drive on everyday, I'm more inclined to keep the front at the suggested 32, and drop the rears to 33 or 34. My hope is that is enough pressure to still be responsive and resist rim damage, but not too much pressure to be harsh. Gonna try that tomorrow and then post what I think. Now that I got my suspension sorted out, tire pressure is the last variable to conquer.
