Old 06-23-2009, 06:57 PM
07z43.0i 07z43.0i is offline
Mein Auto: BMW Z4 3.0i 2007
Z4 Bluetooth and iPhone: for Phone and Music?
Can anyone tell me if the bluetooth that the 2007 Z4 3.0i comes with can be paired for both phone calls and music with an iPhone? I.e., I understand I can use BT to make phone calls, can I also use it to play music (rather than having to install a separate aux or an ipod kit for music)?
Old 06-23-2009, 08:24 PM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
Only the latest iPhone firmware version 3.0 even includes the A2DP BlueTooth profile to allow this. That being said, the BlueTooth in the E85/E86 isn't aware of A2DP, either, and never will be...So you're stuck using the AUX port under your dash.
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 06-24-2009, 06:54 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
Eve if you could use BT to push music, would it sound good? If the sound of the phone is any indication- I wouldn't want a BT connection for my tunes...
Old 06-24-2009, 07:26 AM
jragan's Avatar
Yes, it would, as long as you're in range.
Old 06-24-2009, 11:49 AM
But so currently, you cannot push BT to play music, is that correct?
For the AUX in the dash, is there any way you can run the controls from the CD player in the dash or has to be from the iphone itself?
Old 06-24-2009, 12:04 PM
jragan's Avatar
Correct. Nothing OEM, anyway.
No, no way to control the phone from the dash/wheel, unless you pick up something like the DICE or IntraVee units.
Old 06-24-2009, 10:50 PM
Thanks a lot - helpful to know of my options.
Old 06-30-2009, 11:54 PM
Andrewinla Andrewinla is offline
Mein Auto: BMW-07 Z4 M Coupe/07 X3
Is there any bluetooth device to attach to aux so using iPhone A2DP you can send music to the stereo in the car without having to hook up the aux cable to the iPhone itself?
Old 07-01-2009, 07:26 AM
jragan's Avatar
Yep - http://www.daydeal.com/product.php?p...20932&cat=2824
bluetooth, iphone
