Old 06-25-2009, 04:49 PM
BMWGTMAN BMWGTMAN is offline
Mein Auto: 2001 bmw 530i
Driver's Side Window Stopped Working
Hi Everyone,
My driver's side window stopped working today. The car has 76,000 miles on it. Is this a common issue? Can someone please provide instructions on how to remove the door panel? Its a 2001 530i. Thank you!
Old 06-25-2009, 06:04 PM
tedm's Avatar
tedm tedm is offline
I'm otay. You are not.
Mein Auto: 98 540i Sport Auto
Your window regulator probably went out (you didn't describe any symptoms, but it is extremely common on the e39). Hit up google for a diy e39 window regulator replacement.
Old 06-26-2009, 03:38 PM
well basically when I press the switch I hear parts moving but the window doesn't move. I can manually move the window down about a quarter of the way and power it back up but otherwise its dead
thanks for the tip
Old 06-26-2009, 04:31 PM
Darkflame808 Darkflame808 is offline
Mein Auto: 1997 540i
chances are the nut that secures the window to the regulator became dislodged and freed from the regulator assembly.
Do yourself a favor and stop messing with the controls and start working on that DIY project. It's not too difficult, I've done a regulator repair and that was my first automotive project.
Head over to youtube and search for e39 regulator. You'll see a few videos of a rear door regulator repair. It's not the same door but a video is worth a million words.
Once you watch that video read the text/photo based diy's scattered all over the creation.
If you're lucky you might be able to just reseat the nut in the regulator and do some epoxying or whatever to hold it in place. If you keep messing with the controls you risk burning out the motor or shredding the cable which will require a new motor/regulator to fix. using epoxy or even fabricating your own cover to prevent it from happening will buy you some time (or a lot of time if you're good with fabricating a more secure placement) that will allow you to return the project with a more suitable replacement at a later date.
Old 06-27-2009, 03:23 PM
thanks for the advice
Old 06-27-2009, 09:04 PM
rph74 rph74 is offline
Send a message via AIM to rph74
Mein Auto: 98 540ia Sport
Definitely sounds like the regulator. They indeed are very common problems with E39's. I've done this job 3 times for the back doors!
99 Toyota Land Cruiser, 08 Dodge Ram Quad cab 4wd 6-speed manual, 01 BMW X5 4.4 All high mileage, but paid for!
An armed society is a polite society
Old 06-27-2009, 10:20 PM
jimybonz 528 jimybonz 528 is offline
Mein Auto: 1998 BMW 528i
There is a repair kit for 25 that will fix the problem if it is the nut that came out of the regulator holder, usually the holder chips or breaks, allowing the nut to move freely but will not move the window. i had to do this repair on my e39 about 3 weeks ago and the repair kit worked great and saved me quite a bit of money.
[/SIGPIC]BMW
E39 Black/Black
OEM Hella AE Headlight
OEM Hella Celis LED taillights
M5 Flat Black Kidney Grilles
OEM Clear Sidemarkers
19" ADR Wheels / Dunlop Sport SP MAXX Tires
Custom Black Interior Trim
5 % tint
Ac Schnitzer Pedal Set
Painted Eye Lids
M5 Rear Bumper
M Tech Exhaust
OEM Front Lip
OEM M5 Trunk Spoiler
Currrent BMWs:
1998 528i Blk/Blk-e39
2005 325i Blk/Blk-e46
Previous BMWs:
1998 BMW e36 green 318i-e36
1997 BMW e39 sterling Gray 528i-e39
Old 06-27-2009, 10:36 PM
cn90 cn90 is online now
Try:
http://www.bmwrepairkit.com/
(From the same person in bimmerforums who started out with this repair kit).
Old 06-28-2009, 03:17 AM
Careful, I believe the front regulators are different then the rear regulators and the kit from bmwrepairkit won't work. It's shaped differently.
You'll have to remove the regulator and inspect it to determine if you can fabricate a fix or get by with some epoxy. when we had that problem we used the repair kits for the rear windows and used a rough file and epoxy for the front.
Old 06-28-2009, 08:14 AM
You are propably right,Front regulator not fixable. See post #6:
http://forums.bimmerforums.com/forum....php?t=1012534
I guess if your front reg is gone, just cough up with $260 for a new part. Help the economy guys....hehe...
As an emergency measure to keep window up to keep rain water out, this fellow is very clever (using 2 suction cups to hold the glass up!!!):
http://bimmer.roadfly.com/bmw/forums/e39/8918407-1.html
REAR REG DIY:
http://bimmer.roadfly.com/bmw/forums/e39/8965453-1.html
(Same kit as LanceM in ebay, same person).
Old 06-28-2009, 08:32 AM
BMWGTMAN,
You live in NJ, then try this rebuilder in NY (they rebuild guide not motor) about $50:
http://www.regulatorusa.com/index.php
Or browse their website and buy the guide WITHOUT the motor for $95.
Old 06-29-2009, 10:53 PM
Its too bad they don't make a kit for the front window regulators. Thanks for all the advice. I am going to take off the door panel this week and see whats going on and if I can't apoxy it, i'll have to cough up the money for a new one or try that guy in NY.
Thanks for all the responses.
Old 06-30-2009, 12:07 AM
skydryice's Avatar
skydryice skydryice is offline
Farewell
Send a message via AIM to skydryice Send a message via MSN to skydryice
Mein Auto: CBR954RR
I am parting outmy car and I am selling my regulators... maybe I can help you out? Check out the parting out thread and let me know if you need anything.
Sky
Hushpower II, Stoptech BBK, UUC V12 Clutch Conversion, UUC LTW Flywheel, UUC 9-Button Clutch, Eibach Sways, CF hood, Zionsville HD conversion
UUC EVO3 SSK w/ DSSR, UUC Clutch Stop, DICE, 2point5, Eibach Pro Coilovers, High Flow Cats, Simulated O2
