Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 06-27-2009, 10:46 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Oil Line ---> Vanos, CCV, ICV and Alternator Air Duct (E39)
I just finished this 8-hour massive job and here is the DIY. This is a "Quadruple" Job:
1- Replacing Oil Line to Vanos (mine is leaking).
2- Replacing CCV and hoses (preventive).
3- Cleaning ICV and replace its hoses (preventive).
4- Cleaning Alternator Air Duct and Installed Gutter Guard to prevent leaves from being sucked in.
GENERAL NOTES:
* This is a job that you want to do some research before doing it. These CCV and ICV hose routing details vary from year to year so look up PN at:
http://www.realoem.com
It is a lot of labor removing the Intake Manifold so any cheap parts (gaskets etc.) should be replaced to prevent repeating labor later.
* Park the car in garage so if you have to stop and do it the next day it is OK. Do Not park the car at a critical spot (it is not fun to push 4000 lbs of steel so other cars can move!) because once things are removed you cannot drive the car. Things can go wrong (happened to me!), you may have to stop and order new parts etc. Do it on a Friday or Saturday so you can run to dealer if you encounter problems.
Budget a whole day for this.
* Use different ziplock bags to label different nuts/bolts so when re-installing you are not confused!
* When lifting up the Intake Manifold, take some digital pictures. Spend at least 5-10 minutes to look underneath carefully and make a mental note of how things run. It is a crowded place with a lot of hoses running like Spaghetti!
* Get an assorted mixture of vacuum hoses, heater hoses (ID = 1/2") and hoses with different diameters to replace different rubber hoses.
* To remove old rubber hoses that bond to the metal line, use a putty knife and gently cut the hose where it mates with the metal connector. Just go slowly so you don't damage the connector.
* When replacing old vacuum hoses, replace one at a time to avoid mixup!
* The two (2) coolant hoses that feed to the Throttle Body (labeled Green #9 in Figure 4) are still good so I decided to leave them alone.
* I marked all rubber hoses with white liquid paper and labeled 09 so later at a glance I know which hoses were replaced in 2009!
* When dealing with 10-mm bolts/nuts and 11-mm nuts, use proper torque to avoid stripping the threads.
* The Ventilation Pipe 11151703775 connects the CCV to the Valve Cover. It is rather expensive ($24.41) for a simple piece of tubing. I measured the O.D. of the Valve Cover and the ICV outlet, it is 1 inch, so if you want to save money then use any Standard Heater Hose with I.D. = 1 inch with clamps, and this should work well!
* My CCV looks good (see Figure 7) at 103K! In theory, one can clean the CCV well with Throttle Cleaner and re-install it to save $76 for stupid device. It is simply an oil separator that returns oil back to the oil pan via the dipstick. Anyway, I bought a new CCV so the new CCV goes in.
My ICV also looks great at 103K! You can see that with mostly highway driving, there is very little accumulation of gunk.
* To clean the ICV, spray the ICV with Throttle Cleaner, use a Q-tip if you have a lot of gunk. Then let it dry.
Parts List from:
http://www.eactuning.com
11151703775----Ventilation Pipe GENUINE BMW --> $24.41
11361703464----Oil Line COHLINE --> $46.74
11151703484----Oil Separator GENUINE BMW --> $76.07
13411733217-----Grommet GENUINE BMW --> $10.24 x 2 = $20.48 (there are 2 of these: one for the CCV and one for the ICV.)
11151740393----Ventilation Hose CONTITECH --> $4.46
11611716174----Throttle Housing Gasket VICTOR REINZ --> $5.40
(This is the gasket between the Throttle and the Plastic Intake Manifold)
13411740950----Air Hose GENUINE BMW --> $8.61
(This goes from ICV to Rubber Boot).
13541703703----Connection Piece, this piece very cheap (about $1.00), and it connects to the above Air Hose. After removing the original piece it is still very good. So this part is optional. Replace it if you wish, but also OK to re-use it if it is good. It is plastic, not rubber.
From Dealer (It was a Friday and I needed these parts right away!)
13541703693----DSC Throttle Gasket --> $6.10
(This is gasket between DSC Throttle and the Main Throttle)
11611740069----Intake Manifold Gaskets x 2 (you need two) --> $16.00 x 2 = $32.00
(You can buy this online for $6.00/each. I was stuck because I took everything apart so I went to dealer and paid $16.00/each! But that is OK with me as well!)
OK, enough talking....let's start:
1. First read this Intake Manifold Removal DIY:
http://www.bimmerfest.com/forums/sho...d.php?t=318750
* In My DIY, there is no need to disconnect fuel lines as mentioned in the above link. The Fuel Lines simply twist along its axis. Note that I use a 2 x 4 piece of Lumber to support the manifold. Read on.
2. Disconnect battery ground cable.
3. Remove Air Filter-Air Mass Meter as a Unit.
Figure 1: Remove the 10-mm bolt, loosen clamps on Intake Rubber Boot.
Figure 1a: Remove the two (2) 5-mm Allen bolts holding the DCS throttle.
4. Figure 2 shows view AFTER Air Filter-Air Mass Meter removed as a Unit.
5. Figure 3 shows Intake Rubber Boot removed.
Notice:
- The Main throttle is nice and clean after 103K miles (mostly highway driving), but I cleaned it with Throttle Cleaner anyway.
- Grease the Throttle Cables while you are there.
6. Figure 4 is a busy picture. It shows the bolts you need to remove:
- Six (6) 10-mm bolts circled in red:
Bolt #1 holds a Vacuum Device
Bolts #2, 3, 4 hold the CCV
Bolts #5, 6 hold the ICV
- Two (2) 10-mm bolts circled in green:
Bolts #7, 8 hold the Intake Manifold
* No need to remove the 13-mm bolts holding down the bracket (circled in Orange) to the Engine Block!
Figure 4a shows you things to remove:
- The POSITIVE battery post (this is WHY you need to disconnect the battery for this job!). It is a 19-mm bolt, be gentle when removing this bolt. Then using screwdriver the pry the connector so it drops down away from the Intake Manifold.
- Hose to CCV, and 2 Connectors on fuel rails.
Figure 4b shows you the Tricky part: How to remove the seven (7) 11-mm nuts holding the Intake Manifold without dropping the nuts into the blackhole!
- My trick: apply some grease to the 11-mm socket so it holds the nut when you remove it, put a telescoping magnet alongside the socket to magnetize the socket and catch the nut. The other way is to slowly remove the nut until loose, then re-install it back about 1-2 turns or so, then use the magnetic telescope to unscrew it.
- When re-installing the nuts, use the telescope magnet to start the thread (apply a bit of grease so the nuts go in easily)!
- The last nut next to the firewall (circled in red): use an 11-mm wrench. A socket will not fit in there!
- To disconnect the Hose to CCV (Circled in Orange), squeeze the outside plastic ring (it is oblong in shape so squeeze the long ends and pull the connector out, it is held by an O-ring so it may be stiff from years of engine heat.)
When lifting the Intake Manifold:
- Do it slowly so you can disconnect appropriate hoses/connectors etc. Make a note of where things go for ease of re-installation. Again, the hoses and connectors under the Intake Manifold look like a whole bunch of Spaghetti, so take a pic for ease of re-installation. Also, try to do this job in one single day so your memory is fresh.
- Watch the two (2) fuel lines, they can twist a bit around their O-ring connections. Do not worry about this.
- Remove the Oil Dipstick and cover the Dipstick Tube with ZipLock Bag/Rubber band to prevent dirt from coming in.
7. Figure 5 shows you the Intake Manifold lifted up to show parts.
Do an inspection of all the small vacuum hoses.
I replace the small vacuum hoses anyway (using standard vacuum hoses).
8. Figure 6 shows you my TRICK of using 2 x 4 lumber and Shop Towel so the Intake Manifold can rest on. This way you do not have to disconnect the fuel lines!
9. Replace Oil Line to Vanos: It is 19-mm Banjo-Type Bolt: I re-used the washers. If you re-use the washers, pay attention to the orientation of the washers so the orientation is the same (these washers are slightly indented after squeezed by the bolt so make sure they go back the same way).
Of course you can use new washers.
Torque these 19-mm Bolts to 32 Nm.
10. Replace CCV + hoses: Straightforward business.
- Note that the CCV mates into the Intake Manifold sideway via the Rubber Grommet so push the CCV toward the engine (from driver to pass side).
- The hose from CCV to the dipstick is standard 1/2-inch I.D. Heater Hose (you can get it at any Auto Parts Store).
- When installing the new CCV, do not connect the 11151703775----Ventilation Pipe at this time.
11. Remove ICV; clean it and re-install with new hoses: Straightforward business.
PS: As you can see, if your driving is mostly highway (air cooling the engine compartment as opposed to stop and go traffic in NY City!), the Main throttle is clean at 103K miles! The CCV and ICV have very little gunk, and the Valve Stems look good at 103K miles (Figures 7 and 8).
12. While everything is exposed, time to clean the Alternator Air Duct:
- Alternator Positive Cable is held by 13-mm nut.
- Alternator Plastic cover is held by two (2) 8-mm nuts.
- Clean the leaves/debris using a vacuum machine. Remember to clean the Intake Duct (under the bumper) as well.
- Figure 9 shows you how to install Gutter Guard. I could not find it in black so I bought the Brown Gutter Guard at Lowes Hardware and painted it black. Then cut it to size and place it in front of the Intake Duct (under the bumper) to prevent leaves/birds from getting inside, secure it with a few zip ties. Nobody will notice that you put a Gutter Guard there!
During Re-installation:
1. Do NOT over-torque the 10-mm and 11-mm nuts/bolts, it is easy to strip them.
2. Install the Ventilation Pipe 11151703775 (CCV to the Valve Cover) at the end because you need access to the 11-mm nut holding the Intake Manifold.
3. Do not forget the Positive Post (when lowering the manifold, slide the positive post into the Intake Manifold. Then later tighten the 19-mm Bolt snug (finger tight) and maybe going from 12 o'clock to 1 o'clock position. There is no need to over-torque this bolt. If you over-torque this bolt, you can crack the Plastic Intake Manifold, now it is $633!!!
4. Using a flashlight and check everything from hoses to connectors (do not forget the Intake Air Temp Sensor Connector). I also forgot it!
5. Re-connect battery cable at the very end. If you cannot open your trunk (remember the battery ground cable was disconnected), so you will need to use your key to manually open the trunk to access the battery. Remember to set the trunk lock back to Vertical position (do a search and you will know why I say this)!
6. Start the car and check for:
- Oil leak at Oil Line to Vanos connections x 2.
- Any Fuel Leak (there are a total of 4 connections to check near the firewall). The Fuel Hoses are labeled in Figure 2.
- Test-drive the car.
So, this is what I learned from this DIY (Live and Learn!):
- At 103K, my CCV and ICV still looks very good but since I have to replace the Oil Line to Vanos (it is wet!), I may as well do the whole shebang!
- For those of you driving mainly highway (hwy driving produces much less gunk than stop-and-go driving), you can delay the CCV and ICV job until 150K miles or so. My CCV and ICV were OK even at 103K miles (primarily highway driving)
- The Alternator needs cleaning and Gutter Guard below bumper. You have 2 options:
1. Leaving the Air Duct Cover off so it looks like any other car with standard alternator.
2. Install the Gutter Guard.
- Removing the Air Filter Housing gives you excellent access to a lot of stuff (PS Low-Pressure and High-Pressure Hoses, Heater Hoses, Vacuum Lines, Left Engine Mount).
- If you are short of budget, many of these hoses can be made from standard vacuum and heater hoses. The key thing is to take a short section of the old hoses (do not take them apart and you will lose tracks of them, they are like Spaghetti down there!) and go to local auto parts stores and buy them. You can argue soaking the CCV in gasoline to clean it (I used a new CCV) and re-install it (again, only if you are short of budget). The only thing you absolutely need new are: Intake Manifold Gaskets, Throttle Gaskets x 2, and the Rubber Grommets x 2.
- If you do only the CCV or only the ICV, then no need to remove the Intake Manifold.
Good Luck and I hope this helps you folks decide what to do when you remove the Intake Manifold for whatever reason!
Bonus: How to rebuild Banjo Fittings? When I closely examine the Oil Line to Vanos, I realize that this is simply Banjo Fittings that are used throughout the car (Vanos, PS High-Pressure Hoses which are very expensive). Then I realize that your garden hose at home works the same way: it has a crimp at the fitting to squeeze the hose against the brass fitting and many times I fixed my leaky garden hose with new fitting and trust-worthy clamps.
So if you are short of money and want to rebuild any Banjo Hoses, I guess you can, the issue is what type of clamp to use at the Banjo Fitting? Has anyone ever rebuilt the Banjo Fitting on any Hydraulic Hose using new rubber hoses and standard clamps and want to chime in?
If you need to change the PS high-pressure hoses and short of budget, I guess you can rebuild the hoses, just go to your local hydraulic shops. I can see that a good hydraulic shop can rebuild any hydraulic line for you with their crimping machine (which costs $2K or so): you bring the fittings and hoses and they crimp for you.
http://www.flexdraulic.com/crimp-fittings.html
ID:	191208   Click image for larger version
ID:	191209   Click image for larger version
ID:	191210   Click image for larger version
ID:	191211   Click image for larger version
ID:	191214   Click image for larger version
ID:	191215   Click image for larger version
ID:	191216   Click image for larger version
ID:	191217   Click image for larger version
ID:	191219   Click image for larger version
Old 06-27-2009, 12:06 PM
joebox's Avatar
joebox joebox is offline
Send a message via Skype™ to joebox
Mein Auto: 2003 BMW 530i Sport
Bravo cn90!
Yet another amazing, detailed, easy to follow DIY that will serve the community for years to come. Your hard work and dedicationa are true assets to the forums!
P.S. This should immediately be made a sticky in the DIY forum!
2003 530i SP, PP, CWP, Dinan CAI, Dinan Throttle Body, Dinan Stage III Software, Dinan Strut Brace, Dinan Shock Brace, Dinan Camber Plates, Bilstein Sport, Vogtland Springs, Eibach Anti-Roll Kit, OEM M-Pars 18X9J 275/35/18 all around, OEM M-Aerodynamics Kit, Beisan VANOS Seals, Bavarian CDV, Bluetooth Retrofit, Sirius Retrofit, Driver's 4-Way Lumbar Retrofit, Rear Sunshades Retrofit.
BMWCCA Membership # 405708
Old 06-27-2009, 02:09 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2001 525iA
Thanks for this! I'm sure many will be helped by seeing this!
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue
*retired
Old 06-27-2009, 03:00 PM
ihsva ihsva is offline
Mein Auto: 98 528i - SP - 5-Speed
Thank you, this looks great!! I will try to do mine July 4th weekend.
Old 06-27-2009, 06:27 PM
TheStig TheStig is offline
Some say...
Mein Auto: N/A
Old 06-27-2009, 07:25 PM
Some tids and bits: To make a long story short I forgot to re-connect the electrical connector to the ICV and the electrical connector to the Alternator and got all kinds of weird symptoms.
1. If you forgot to re-connect the electrical connector to the ICV, the idle is lower than normal and the S.A.S Air Pump runs constantly non-stop. Plugged in my OBD Scanner and got P0505 (= Idle Control System)....I laughed right away b/c I know I forgot to re-connect the connector. Don't ask me why but I cannot understand the linkage between the ICV and the S.A.S Air Pump. Re-connected and all is good.
2. If you forgot to re-connect the electrical connector (the rectangular connector, not the Red Positive Cable) to the back of the Alternator ---> you will have a faint battery light on the dash. Re-connected and all is good.
So the bottom line is when things go wrong, go back and look at the areas that you just performed repair work, 99% of the time the answer is there. That is the cardinal rule of car repair!
Old 06-27-2009, 08:19 PM
By the way, does the car feel any different since you completed the work?
Old 06-27-2009, 08:45 PM
Not really, everything was preventive maintenance, there were no symptoms to start with.
However, I am happy I did it, some of the rubber hoses under intake manifold are on their way out, they start to crack on the outer surface. Typical for 11 years old and 100+K mileage.
Old 06-27-2009, 10:17 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Thanks CN for the write-up!
Top notch!
So, your car did not drive differently after the work?
Did you use the cold weather CCV?
Jason
Old 06-28-2009, 05:49 AM
hokiehigh hokiehigh is offline
Mein Auto: 2003 540i MSport
nice writeup, now I wish you have a V8
2003 540iA M-Sport Black/Tan
Old 06-28-2009, 05:56 AM
Fudman's Avatar
Fudman Fudman is offline
Great writeup!!! I plan to do my CCV (cold weather variant) soon + VANOS seals! This will be helpful, especially the lessons learned. Too bad yours wasn't a 2002!
Old 06-28-2009, 06:26 AM
timmychuck timmychuck is offline
Mein Auto: 1997 528i
great write-up all this was done by PO so it looks like i have got a job for me in the next
40k miles
Old 06-28-2009, 10:12 AM
jchung9825 jchung9825 is offline
Mein Auto: 01' 525it 5sp
I just did the same last week. I didn't take the manifold out and it is a miracle that I remove the ccv and replace all the hoses without breaking anything. the easy part was the vanos oil line expect I dropped the seal ring and took me half an hour to find it.
((( in stereo )))
Old 06-28-2009, 10:57 AM
Curt2128 Curt2128 is offline
Send a message via AIM to Curt2128
Mein Auto: 528i
good wright up!!! u should have done a m50 manifold swap. thats what i did and i love teh extra power
Old 06-28-2009, 12:45 PM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
Nice work.
I've been accumulating the parts to do my CVV ... was planning on removing the IM and getting those gaskets / vacuum hoses and the dual-temp sender under IM at cyl. #6 while I was there.
Great documentation with the pictures.
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 07-03-2009, 09:30 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Excellent work & report.
Thanks for sharing.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 07-19-2009, 10:13 PM
ganesht's Avatar
ganesht ganesht is offline
(oOO)\(lll)°(lll)/(OOo)
Mein Auto: 98 528i 5 speed
Originally Posted by cn90 View Post
11151703775----Ventilation Pipe --> $21.24
11361703464----Oil Line --> $43.12
11151703484----Oil Separator --> $63.05
13411733217----Grommet --> $8.49 x 2
11151740393----Ventilation Hose --> $7.46
11611716174----Throttle Housing Gasket --> $10.15
13411740950----Air Hose --> $7.14
13541703703----Connection Piece --> 1.20
13541703693----DSC Throttle Gasket --> $3.18
11611740069----Intake Manifold Gaskets x 2 --> $12.18 x 2
Ive updated the prices with prices from crown auto
Total: $197.89 (with ccv)
Total: $134.84 (without ccv)
Alida:
Born: Friday, 9th January 1998
Arktissilber Metallic on Schwarz 528i/5
Fs: KAC-8103D, Kicker 08ts10l52
Old 07-20-2009, 07:48 AM
Total: $310.15
No, it is not $310.15.
It is approx. $200 for these items.
Whatever it is, go for OEM BMW parts in this job. It is alot of labor and you know these parts last at least 100K miles, and you don't want to go back and do this later because of inferior-quality gaskets.
Old 07-20-2009, 09:41 AM
ganesht's Avatar
sorry that was my bad, i had some other things i was order in my cart and i forgot to remove them from the price..
if you get everything from crown, for under 200 your getting 100% oem parts (crown is a bmw dealer in Greensboro North Carolina)
http://www.crownpartsonline.com/
Alida:
Old 08-27-2009, 11:47 AM
I was looking at some of my old posts on my E23. I sorely missed my E23 (1983 735i 5sp = beauty!!!) badly....This was my "Sticky" posted on bimmerboard:
http://bimmerboard.com/forums/posts/216219
You can see that back then the PCV was simply a hose from Valve Cover straight to the intake manifold, labeled #11 here:
These days, car engineers make things too complicated as you can see in the E39 CCV design, which is ridiculously complex.
Old 08-27-2009, 12:16 PM
E92-Lighting's Avatar
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
very good writeup, thanks
Old 08-27-2009, 12:30 PM
ganesht's Avatar
^^ nice!! i love working on my m30, its so much easier to work on than my m52..
Alida:
Old 08-27-2009, 12:33 PM
If BMW still makes the E23 5-speed, I'd buy it tomorrow in a heart beat!
It was such a pleasure to drive the E23 beauty on the highway, the M30 3.5L motor has so much low-end torque because of its single overhead cam, coupled with the 5-sp Getrag Man Trans ---> that I smoked many Corvette and Camaro's with Auto Trans....hehe. Plus the M30 engine compartment is logically laid out, easy to work on. The E39 engine compartment is TIGHT, making the job much harder.
Old 08-27-2009, 01:21 PM
ganesht's Avatar
unfortunately my e28 is an auto =/ still looking for the time to do the 5 speed swap.
Alida:
Old 08-28-2009, 09:42 AM
mrodoc mrodoc is offline
Mein Auto: 335i, 525i
Excellent write up. I need to do my 1995 E34 525i. I assume the process is very similar to the E39?
