Old 06-28-2009, 05:10 AM
fasx786 fasx786 is offline
Mein Auto: 730
Anyone know how to change to steptronic transmission
Hi,
I drive a BMW 730 03 model. I want change from tiptronic to steptronic transmission so I can use the paddleshafts to change gears. I've read the manual and it tells me to press a button on my steering wheel and the change in transmission type will be confirmed in my info display on the dashboard. However after pressing the button there is no change on the info display and it seems as though the button has no effect. Anyone else had a similar problem? I would appreciate some help.
Old 06-28-2009, 03:14 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
you should have a D-S-M button on the steering wheel above the buttons that control the CD track's. Press that once to get to Sport, twice to go into Manual mode, and three times to go back to regular Drive.
Old 06-29-2009, 12:39 PM
OnlySkills's Avatar
OnlySkills OnlySkills is offline
_____________________
Mein Auto: 745i
yEAH, the post above.
____________________________________________
BMW 745i - Titanium Silver [SOLD]
2013 Ford Edge Limited w/ Ecoboost - Platinum White
Old 06-30-2009, 06:22 AM
Mein Auto: 730
Thanks for your replies guys. I've sorted it. It wasnt working when the car was stationary. However I tried it again whilst driving and it worked
Old 06-30-2009, 07:36 AM
730dMaster 730dMaster is offline
Mein Auto: 2004 730d, SL 55 AMG
Yes, the car must be in 'Drive' so that you'll able to switch to sport or manual
Old 06-30-2009, 11:24 AM
csmeance's Avatar
Mein Auto: 760Li
As well it won't work in reverse since you can't really to much sporty driving in reverse with only 1 gear...
Old 06-30-2009, 01:33 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
i used to have a honda prelude with a vtec engine and i would hit vtec in reverse, fun stuff
then i had an turbo Audi A4 and i would build up boost up in reverse and let the blow off valve release it into atmosphere, very cool when a car blows off in reverse, PSHHHHH
'03 745i - modded - GONE -
steptronic, transmission
