E46 (1999 - 2006)
Old 06-29-2009, 08:23 PM
maize07 maize07 is offline
Mein Auto: 2000 BMW 323i
2000 323i A/C problems..tried multiple diys no fix...any ideas
My a/c on my 2000 323i is going from hot and cold to off, In no certain order, I first replaced the water heater vavle, no fix. I then replaced the final stage resistor, no fix. I checked the R-134a and my gauge says its full and wont take anymore when i try. any ideas on what else could cause this? Im so frustrated
Old 06-30-2009, 12:49 AM
yoda1138777 yoda1138777 is offline
Mein Auto: 2003 BMW 325i 4dr S and P
It might be the control unit itself, maybe there is something short circuiting
Old 06-30-2009, 11:51 AM
galvinston galvinston is offline
galvinston
Mein Auto: 02, 330ci
haha.. wellcome to my world!!... p.s if you r-134 is too full in the heat of the day your systems pressures may become to high in wich case a failsafe automaticly shuts off the compressor. maybe try letting a bit out... also read smolck's Blog ill its helpfull
Old 07-09-2009, 12:09 AM
that could be it cause the gauge shows it extremly full of r134a
Old 07-17-2009, 08:41 AM
it turned out to be the temperature sensor , my dash light showed the outside temperature to be -40 degrees . 84 dollar part
