Old 06-29-2009, 09:19 PM
youraveragepunt youraveragepunt is offline
Mein Auto: 1997 bmw 323i
135i turbo exhaust...golf tee?
hello,
i seached the forums for "Golf tee" but couldnt find anything on this mod...
my old man just bght a new 135i australian spec with 6sp manual. ive been reading some cars come with a vacuum operated valve that closes 1 tail pipe at low rpm or when cold. apparently there is a vacuum hose somewhere you can jam up with a golf tee or similar and keep this flap open for more noise...
anyone know what im talking about? can it be done? anyone know a link to a DIY site etc?
thanks and sorry if this has been asked for before, i did do a search of this forum first and anyways im just a simple e36 driver .....
tks
Old 07-01-2009, 06:54 AM
natantheone natantheone is offline
ballin
Send a message via AIM to natantheone
Mein Auto: 08 135I,
If you want that 1er to be loud the ghetto way just lift the car and unbolt the exhaust right in the middle. Its just two bolts. Try and tell me what you think.
Old 07-01-2009, 04:23 PM
mclaren's Avatar
mclaren mclaren is offline
Chairman of the Bored
Mein Auto: 2014 M5
I'm sure your "old man" will really appreciate you f'ing with his new car.
Old 07-01-2009, 09:27 PM
thanks for all your constructive help d!ckhead....appreciated.
Old 07-01-2009, 09:28 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Hello, please look at your exhaust and see if there is a valve/flap in one of the tips, if there is there is a vacuum hose connected above it. Disconnect it and put a gold tee in there and zip tie it. Enjoy
Old 07-01-2009, 09:30 PM
meh he's not that precious about his cars....they park on the street in inner sydney under sap dripping tree's and fckwits always hit them when reverse parking....turns them over ever 18months... he's just as curious too...
from audi S3 to 130i to 135i now.....the 135 is a goer but doesnt sound as sweet as the old 130i....
Old 07-01-2009, 09:32 PM
thanks solidjake....just the exact type of answer i was after
i'll buy you a beer next time you're in australia
Old 07-01-2009, 09:33 PM
Solidjake's Avatar
Zero. Leaks.
Thank you so much. Looking forward to that Australian beer
Old 07-02-2009, 10:26 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
My 335i had the exhaust flap and valve, not sure about the 135i.
But if it does, I would advise you to use something else than a golf tee to stuff the vacuum tube - I've done it like that the first time and over time it got stuck, it was a pain to remove. Use an 8mm or 10mm stainless steel machine screw to plug the line - when you'll want to remove it, you simply unscrew it. Dead easy.
Also use a zip tie to secure the vacuum tube out of the way and perhaps a little rubber cap on the valve vacuum nipple (so dirt/rain doesn't get in). Any automotive store will carry those little rubber caps, they are used to plug vacuum lines, brake lines etc.
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 07-02-2009, 10:59 AM
atr_hugo atr_hugo is offline
Mein Auto: 2008 135i
adc - the 135i does use the same flap and valve. Your advice is right on. I initially used a golf tee and then removed it when I noticed a bit more drone than I was willing to put up with.
Old 07-02-2009, 11:05 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Good to know!
Droning could also be dependent on your SW version. When my 335i had the original software (V.27) or the latest (v.32), droning was not a big issue. But while it ran on BMW's infamous V.29 software, I was also tempted to undo my golf tee mod...
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 07-06-2009, 04:40 AM
patricksaladino patricksaladino is offline
Mein Auto: '09 135i
Hey. You'll find all the info regarding that mod @ http://www.1addicts.com/forums/showthread.php?t=213042
P.
