Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 08-13-2003, 10:51 AM
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
Which spark plugs do I use, Bosch or NGK?
Folks,
2001 E46 325i (M54B25), which spark plugs do you guys recommend, Bosch or NGK?
I am talking about the OEM plugs available from the dealer.
I have no idea what my factory plugs are, but both are good quality brands.
Any recommendations on where to buy these from, the stealer wants $14.59 for each plug, which is probably double the normal price.
Old 08-13-2003, 11:07 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
In my past experience with other cars, it's typically best to stick with whatever brand came with the car. Generally this meant NGK for Japanese and Bosch for German. Mixing these always gave my friends and I poor results.
But modern BMWs are an oddity in that they are German engines with NGK plugs (BKR6EQUP) from the factory. I've noticed recently that BMW is finally specifying a Bosch alternate (don't have the number offhand) for those who prefer Bosch.
I've seen the proper NGK for $9 or so, and would personally stick to that. Keep in mind that BMW specs the plugs for a 100k replacement interval, though I'd probably at least do a check at every Inspection II or so.
Old 08-13-2003, 11:13 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
I've had bosch in my car and NGK in my wife's 323Ci and have had no decernable effect between the two.
The Bosch is about $1.50 cheaper than the NGK.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 08-13-2003, 12:00 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
I know they are supposed to be changed at 100K, I am approaching 38K, what do you think, should I change them?
My car is running fine, I'm just being anal about it.
I have seen posts where people have said that their plugs were in bad shape at about 60K, so I thought I would change early.
If NGK were OEM, then I would prefer to stick to them.
Old 08-13-2003, 12:12 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
I say don't mess with the plugs if you don't need to. I'd take one out and examine it (there are pages out there that show you how to 'read' a plug) if you really want to do something. With the type of plugs and ignition system in these cars, as long as you run the motor pretty hard on occasion, the plugs will probably look barely-broken-in for at least 50-60k. Otherwise I'd save the time and money and leave em alone for another year or so.
Old 08-13-2003, 12:18 PM
The HACK's Avatar
Ditto what Kaz said. When I took out my plugs, they looked almost brand new, except the color is slightly off (they're not the bright, polished white that new platinum plugs look like). When I took the plugs out of my wife's car, it's got a good amount of GUNK on the tips of the plug and the discoloration is pretty bad.
Our driving style is slightly different. I let my car run up to redline about once or twice a month. I take it to driving schools. She's pretty much your average everyday driver wrt to throttle application.
Old 08-13-2003, 02:43 PM
SergioK's Avatar
SergioK SergioK is offline
Donkeybike?
Mein Auto: HP2Sport - R1200GS - F30
I just changed my plugs at the 70k mark. I wish I had done it at the 50k mark though. There was a noticable difference in startup, the smoothness of the engine, and throttle response. As soon as I cranked the engine over I noticed this change.
Although the plugs looked to be in good condition and the car ran fine, I'm glad I changed them out.
Old 08-13-2003, 02:52 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Hmm, I'd have to see a new one but those center electrodes look pretty worn.
Old 08-13-2003, 03:11 PM
SergioK's Avatar
Donkeybike?
The electrodes didn't appear to me to be that worn out from new... I did notice that the gap between the electrode and the insulator was more worn out though.
Pretty good for 70k miles and 20 track days.
Old 08-14-2003, 02:25 AM
Raffi's Avatar
Raffi Raffi is offline
Hi
Mein Auto: Frankenstein monster
I changed mine at 30K. For $60, it's definitely worth the peace of mind for me.
'01 330ci
Old 08-14-2003, 10:02 AM
Brashland's Avatar
Brashland Brashland is offline
Das Hellrot Reisender
Mein Auto: 1999 323i Hellrot 'vert
I've heard about plugs getting fused to the engine when left in for 100k. Is this just a mechanic ghost story or what?
My YOKOHAMAS were BALD after only 7,000 miles of daily driving!!!
Old 08-14-2003, 12:07 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
Thanks for the info guys.
I am leaning towards doing the plugs at 50K. That will be when I change my diff oil and manual transmission fluid for the second time.
What else would you guys recommend at 50K? Fuel filter, O2 sensors?
Old 08-14-2003, 12:17 PM
SergioK's Avatar
Donkeybike?
Nah, don't change the O2 sensor... that should last up to 150k or longer. As for the fuel filter, yeah, definitely change it at the 50k mark. I changed mine at the 60k mark and wish I had done it sooner.
Are you going to be doing this work yourself? Or having a shop do it?
Old 08-14-2003, 01:48 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
The plugs I will do myself, the other stuff I will probably get done by an independent mechanic, as I don't have any ramps and jackstands and living in an apartment means I would have to leave them in the garage where things get stolen.
Old 08-14-2003, 01:59 PM
The HACK's Avatar
Fused? No. If the engine got hot enough to melt the plugs, it'll melt your cylinder blocks too.
It DID take significant more force to break the OEM plugs free. You're suppose to use copper based anti-seize on the threads of the plug so they don't seize up and make it impossible to take out.
Old 08-14-2003, 02:36 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
besides plugs (maybe) and the fuel filter what else should be done at 50K?
Tim
Old 08-14-2003, 02:58 PM
The HACK's Avatar
Tim
I do brake flushes about once a year on my wife's car and every 6 month on mine...Usually by 50 K you would have had 1 factory flush (the interval is 2 years I believe).
Also, the radiator is supposed to be flushed every 4 years but I do it at the 60K mark just for fun. I believe the "microfilter" is supposed to be changed out ever 30K miles so you're close enough to warrant a new microfilter too.
Old 08-14-2003, 06:17 PM
SergioK's Avatar
Donkeybike?
I have such crappy tools that I had to use my improvised 'breaker bar' (a piece of pipe that I slide on the end of the wrench) to break loose my plugs. I used the same anti-seize that I use on my brake pins for my StopTechs.
Old 08-24-2003, 05:33 AM
joea9146 joea9146 is offline
Mein Auto: 04 Z4(his) / 04 525(hers)
Changing plugs at 100k and oil at 15k in my opinion is all marketing / sales hype. I change the oil Mobil1 about every 5k and change the plugs about every 30k.... its cheap maintenance items. Wiating 100k for changing plugs can cause problems as previously mentioned thay can be really tough to remove.
Old 03-15-2005, 11:14 AM
Hutchman Hutchman is offline
Mein Auto: 2011 328i, 01 325I
I call that bar "The Negotiator."
Old 03-24-2005, 08:38 PM
reevesna reevesna is offline
Acceleration Junkie
Send a message via AIM to reevesna
Mein Auto: '99 328i, '03 cbr954RR
spark plugs
At 75,000 i took my engine cover off and took out a single plug and checked that sucker out...underneath the engine cover looked like it was right outta the factory...and that damn plug looked like it had 5miles on it...i shoved her back in there n called it good...my dad was pissed his ford F150 plugs that he changed at 100,000 miles took him 2 days to change (fuel rail) and they were in mediocre shape
Old 05-16-2005, 08:46 PM
jayf jayf is offline
Mein Auto: 2002 m3c
Plug removal - how to reach the 6th cylinder
I have a '02 M3 and changed the plugs. I have plenty of socket pieces that swivel, but cannot reach the cavity with a socket wrench to get the spark plug out of the 6th cylinder (most rearward). Do I have to drop the engine? Do I need to remove some kind of bracket. Is there some tool I need?
Old 05-16-2005, 09:16 PM
lancelot1959's Avatar
lancelot1959 lancelot1959 is offline
Send a message via Yahoo to lancelot1959
Mein Auto: 2010 335D- E90
You need to remove the Microfilter housing, It has three Hex screws on top then it come off reaaly easy.
Of course, you need to remove the microfilter first, I changed my plugs back in December and this step made it a walk in the park, no special tools needed.
Old 05-18-2005, 07:04 PM
Mein Auto: 2002 m3c
thanx - sir lancelot
