E36 (1991 - 1999)
Closed Thread
Old 08-08-2011, 08:00 PM
hornhospital's Avatar
D'oh, You Kids!
You MUST have a hub to center the wheel. The lugs will not do it.
Tell me how the hubcentric ring broke on your spacers....did it break off as a ring, or did it split? If it broke off as a ring, it wasn't made correctly. The counterbore inside that fits the OEM hub was bored too deep.
Quotes to live by:
  #36302
Old 08-08-2011, 08:09 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Ken, it broke off as a little ring. Its stuck inside my wheel right now so its safeish structurally. But I was hoping wheel studs would solve it. Oh well. Time to spend another 100 bucks on spacers again...
And I think I'll bump up to 12.5mm. That'll clear the hub for sure, right? (I thought I was sure but now I'm all paranoid ) Im going through TMS now, by the way
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
  #36303
Old 08-08-2011, 08:12 PM
D'oh, You Kids!
I bought Amber a set of 15mm spacers from eBay cheaper than I could buy the material and make them, and they were excellent. They were like $60 shipped.
Quotes to live by:
  #36304
Old 08-08-2011, 08:16 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
15mm are like 80 now on ebay. and after this, not sure if I trust ebay stuff. I just found ECS has 12.5mm for 75 bucks. Im gonna go this route I think, ECS has decent customer support if something happens and I think 12.5mm would clear the hub. Says "* Note: Height hub contour up to 11.5mm. Inside wheel bevel = 7.0 x 45 degrees"
Height Hub Contour means how long the hub can be before the spacer bottoms out, right?
  #36305
Old 08-08-2011, 08:19 PM
D'oh, You Kids!
Right. You have to have a little angle cut to clear the radius at the shoulder between the hub and flange, and the counterbore in the spacer has to be long enough to accept the factory hubcentric ring on the OEM hub.
Quotes to live by:
  #36306
Old 08-08-2011, 08:21 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Okay. So if these dont fit flush I'm busting out the die grinder and grinding off a mm or two. Thanksies ken!
edit: so then I'd need lugs 50mm thread length long?
  #36307
Old 08-08-2011, 08:22 PM
D'oh, You Kids!
Update for CJ: bad news, the spare corners I have are for a sedan. I have some coupe ones on Elvira, but they are in horrible shape...cracked and scratched. I have a set of clears to go on her, but never have swapped them out.
Quotes to live by:
  #36308
Old 08-08-2011, 08:24 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Alright, thanks anyway. I'm still undecided if I want ambers or smoked for my car. I like the ambers but I will probably do all-red tails in the near future, which would probably look bad with the amber corners.
-CJ
  #36309
Old 08-08-2011, 08:25 PM
D'oh, You Kids!
Yes. I had to go to 60mm on the 25mm spacers I made for the 6er.
Quotes to live by:
  #36310
Old 08-08-2011, 08:26 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
see-jiz, remind me to look for a corner for you tomorrow. I'll send you one if I have it for like 5 and shipping, or if its broken just shipping
  #36311
Old 08-08-2011, 08:28 PM
cj.surr's Avatar
some kid
Sounds good. But if it's broken, I don't want it
-CJ
  #36312
Old 08-08-2011, 08:48 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
I mean like broken but usable but not sellable. duhh
  #36313
Old 08-08-2011, 09:19 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Yeah I bought 5mm for 50
Sent from my HTC HD2 using Bimmer
-Dino
  #36314
Old 08-08-2011, 09:37 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
:shifty: I needs 12+
  #36315
Old 08-08-2011, 09:39 PM
cj.surr's Avatar
some kid
Wait until you get those contours (if you still are). I went and tried spacers with my bottlecaps then ended up not needing them when I put on the 68s.
-CJ
  #36316
Old 08-08-2011, 09:46 PM
Hellawut??
Mein Auto: who knows?
Ken i think that i sent you those corners...
Do you mind to ship them to me? uppyeyes: i lost my smoked passanger corner on the road yesterday
-Franklyn
  #36317
Old 08-08-2011, 09:50 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
good point cj. wow. thanks for bringing that up, i was literally about to press submit order
  #36318
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
wtf is with everyone losing their lights?
  #36319
Old 08-08-2011, 09:51 PM
cj.surr's Avatar
some kid
They fall out easily when the mounting tab on the headlight is broken.
-CJ
  #36320
Old 08-08-2011, 09:54 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
My tabs are perfect. I don't have this issue.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
  #36321
Old 08-08-2011, 09:56 PM
Hellawut??
my tab was working too...... idk why or how mine fell out in all honesty
-Franklyn
  #36322
Old 08-08-2011, 10:00 PM
Hellawut??
For those of you that are low.....
What the measurement on the fender rocker panel. and the front bumper in the dead middle?
in inches please
-Franklyn
  #36323
Old 08-08-2011, 10:05 PM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
what measurement exactly?
  #36324
Old 08-08-2011, 10:39 PM
Hellawut??
clearance on those two spots
-Franklyn
  #36325
Old 08-08-2011, 10:48 PM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
brb.
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
