E36 (1991 - 1999)
Closed Thread
Old 11-17-2011, 05:26 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Originally Posted by drive by72 View Post
Do the routine stuffs first Dino... sometimes the most mind-baffling problems are solved with the simplest solutions.
Only things I can think of being the issue is a clogged ICV
, camshaft sensor, or crankshaft sesnor, Fpr(maybe)
After it starts it run fine but when comming to a stop the rpms jump a lot (as if there's a vacuum leak) if I were to vacuum test it what readings would look for of using a vacuum measuring computer?
What could I do while at home to check for vacuum leaks (ex: tricks)?
Sent from my SCH-R720 using Bimmer
-Dino
  #44027
Old 11-17-2011, 07:16 AM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Ever since I bought my car back in '09, It has occasionally gone through phases where the Check Engine light likes to tease me.
Usually when the car is about 3/4 of the way warmed up, when I'm accelerating normally, every once in a while the check engine light will come on while I have the clutch in between gears. Its usually when I'm shifting under 3k, and goes away the second the clutch comes out.
Car feels normal, normal sounds, nothing out of the ordinary except that stupid light. It used to do it the fall I first got it, I forgot about it and now its decided to do it again. Happens 1-2 times a day, maybe. Any ideas?
  #44028
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Parts car guys...I need an m42 "working" cam sensor to buy cheap if possible for my dads bimmer..any one?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
  #44029
Old 11-17-2011, 07:28 AM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Knock sensors...
I had the same problem...
Instagram | @randytheus
  #44030
Old 11-17-2011, 07:44 AM
SlimKlim's Avatar
Speed is Zen
Originally Posted by KaptinKP View Post
Knock sensors...
Oh rly, I was thinking O2 sensor. Do you think its storing the code?
Is it cheap/easy to replace? Can I shamelessly ignore it like I ignore my washer fluid sensor, coolant sensor, taillight warning, and vanos rattle?
EDIT: $80 each?! And I have to remove the intake manifold?!
UGH. Can I continue to ignore this?
  #44031
Old 11-17-2011, 07:54 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
Lol the intake manifold on the s50 isnt that bad try the one on the m54
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
  #44032
Old 11-17-2011, 08:05 AM
Gooby's Avatar
Mein Auto: 1995 M3
Yeah it stores the codes...do the pedal trick, I think its 11226 or something, I forget exactly...
Is it easy? Lolololol I just did mine 3 days ago and I hated my very existance...
You can ignore for a while. I did for almost a year. But they wont magically fix themselves so eventually you have to do it because I heard that it affects performance and stuff.
  #44033
Old 11-17-2011, 08:12 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I've got one. I'll see if I can pull it off for you tonight.
-CJ
  #44034
Old 11-17-2011, 08:25 AM
B1MM3R's Avatar
Jesse Moon Bayne
Sick...how much shipped to me @24019? I can pay pal you now
Jesse
2001 330i DD
  #44035
Old 11-17-2011, 08:36 AM
cj.surr's Avatar
some kid
What's the production date? There's a different sensor (I think just the connector, actually) for 1992-08/93. Mine's a '95
http://www.pelicanparts.com/bmw/cata...pg5.htm#item30
-CJ
  #44036
Old 11-17-2011, 08:41 AM
SlimKlim's Avatar
Speed is Zen
Yeah, I know, but I have a Miata to turn into a race car this winter, so I'm scrutinizing every penny spent on the ole girl and trying to watch how many weekends I spend in the garage to keep my girlfriend happy.
Yeah. Like I said, its been on and off and on again for 2-3 month periods for the past 2 years I've had the car. If it actually starts to cause a noticeable effect I'll suck it up and do it.
  #44037
Old 11-17-2011, 09:54 AM
B1MM3R's Avatar
Jesse Moon Bayne
Im working on that CJ thanks..ill let you know as soon as I get ahold of my dad. Also meet carlos lol
Jesse
2001 330i DD
  #44038
Old 11-17-2011, 10:21 AM
B1MM3R's Avatar
Jesse Moon Bayne
This is what real oem says cj
Part Cross-reference
RealOEM.com Home
Language: ***269;eskıdeutsch***949;***955;***955;***951;***9 57;***953;***954;***940;englishUS englishespañolFrançaisitaliano***26085;***26412;** *35486;***54620;***44397;***50612;Nederlandspolski português***1088;***1091;***1089;***1089;***1082;* **1080;***1081;svensk***3616;***3634;***3625;***36 34;***3652;***3607;***3618;Türkçe***27721;***35821 ;***32321;***39636;***20013;***25991;Part 12141734813 (TRIGGER CONTACT) was found on the following E36 vehicles:
E36 318i Sedan, M42, AUTO (CC83) : TIMING CASE
E36 318i Sedan, M42, AUTO (CA63) : TIMING CASE
E36 318i Sedan, M42, MANUAL (CC73) : TIMING CASE
E36 318i Sedan, M42, MANUAL (CA53) : TIMING CASE
E36 318is Coupe, M42, AUTO (BE63) : TIMING CASE
E36 318is Coupe, M42, MANUAL (BE53) : TIMING CASE
Search for another part:
Enter 11-digit or 7-digit Part Number:
USA Europe
Copyright © RealOEM.com.
his car was 3/93, cant find anything stating if they are all the same or not.
Jesse
2001 330i DD
  #44039
Old 11-17-2011, 10:35 AM
Gooby's Avatar
Mein Auto: 1995 M3
  #44040
Old 11-17-2011, 10:42 AM
cj.surr's Avatar
some kid
RealOEM.com Home
USA Europe
Not sure, man. It's your call. My guess is that only the connector is different. So you should be able to just splice it in. That's what Dino did with the knock sensors from that engine, and they work well, I believe.
-CJ
  #44041
Ryan...'s Avatar
Ryan... Ryan... is offline
Please, call me Brian.
Mein Auto: 95 325ic, 16' F150
Old 11-17-2011, 10:50 AM
B1MM3R's Avatar
Jesse Moon Bayne
Ok Ill talk to my dad...whats your price shipped to 24019?
Jesse
2001 330i DD
  #44043
Old 11-17-2011, 10:51 AM
cj.surr's Avatar
some kid
I'll do it for $20. Fair?
-CJ
  #44044
Old 11-17-2011, 11:02 AM
B1MM3R's Avatar
Jesse Moon Bayne
Dang I do see the difference in the plug ins now...let me call my dad and find out what he wants to do, but thats def. fair if he wants it man thanks.
Jesse
2001 330i DD
  #44045
Old 11-17-2011, 11:31 AM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
stickers:
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
  #44046
Old 11-17-2011, 02:10 PM
I Love My E36's Avatar
I Love My E36 I Love My E36 is offline
Haters Gonna Hate
Mein Auto: 1996 328is
Lmao! Check this out!
http://www.shortlist.com/entertainme...mage-rotator-1
Old 11-17-2011, 02:20 PM
Ryan...'s Avatar
hahaha he handled that like a boss!
Old 11-17-2011, 02:39 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
iirc, there are tabs on the connectors that allow them to be disassembled for new contacts/weatherpak.
when i did my fogs there were no pigtails there at all, just wires. i had some spare wiring harnesses from an old e32 (green parts car, never drove it, just made it go away...). i found the correct color wires, matched them to the correct plug and viola, magic.
i'd say simply swapping out the connector plastic should be easier.
df
Old 11-17-2011, 02:47 PM
B1MM3R's Avatar
Jesse Moon Bayne
Like a Boss son.
Jesse
2001 330i DD
  #44050
Old 11-17-2011, 02:48 PM
B1MM3R's Avatar
Jesse Moon Bayne
df
You referring to my situation?
Jesse
2001 330i DD
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
