E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Yeah, my t-stat came out in more than one piece, too. Not a big deal.
Actually, for the E34, the drop isn't very much. It'll only be 1.6" lower in the front, .8" lower in the rear. Probably will be a little lower (by a smidge) than the M5 suspension. My friend (who owns the car) didn't want to go super low at this point. The springs are going to be used with adjustable Koni Yellow Sports, and he's buying sways, too, so the car should handle pretty awesome when finished. I'm putting the Turner chip in today, so we'll see how that goes. I'm curious to feel the difference an instantaneous 20hp22/ft.lb. makes.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 11-19-2011 at 10:23 AM. |
Bleed, bleed, and bleed again! You have air trapped in there. Just let the air out, fill it up to the correct level, drive, check, repeat... Eventually it will stop going down.
Raise front of car 8-10 inches, start car, heat on full blast hot, remove bleeder screw, remove rad cap, massage top rad hose, keep topping off until bubbles stop.
Repeat twice. (At least).
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
Also, the car does not need to be cold to bleed it, just be careful not to burn yourself. When I bled mine, I had steam coming out of the bleeder screw, which is what you want.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
had my mom sit in the car to rev and keep watch off the needle
i told her where to keep the rpms she WOTS the car screams in my face I start screaming MOM!!!!!! then she was OHHH! then the rpms stayed at 2 anyways i poured and poured bubbles started comming out till i stopped i kept pouring and had to dodge coolant coming at face due to the fan flinging it everywhere now the car isnt overheating and but i heat is blowing cold air until the car is reved high and the coolant was way too full while writing this i went to check it again now the coolant went down and is now sitting 3/4 of the tank (a little higher than the cold mark) does this sound about right? and continue bleeding?
If your heater still isn't blowing hot, you still have air trapped in there even despite the fact that it's at the 3/4 mark. So yeah, you'll have to continue bleeding until the heater blows hot and the coolant stops going down. Sounds like you're making progress, though.
Also, you don't need to rev the motor at all. Idling is fine. On another note, I WANT:
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 11-19-2011 at 11:16 AM. |
Meh, I've never been an enormous fan of the MX5s. I'm sure they're fun is shyt to drive, I would just want something a little more not a Mazda (unless it had a rotary engine) if I were going to get a roadster.
Buy stuff! E36 parts: http://harrisonburg.craigslist.org/pts/3696167489.html E36 5 speed swap: http://harrisonburg.craigslist.org/pts/3696120610.html E46 parts: http://harrisonburg.craigslist.org/pts/3696151076.html |
Just bled the system again
bubbles came out of the screw then a steady flow of coolant started coming out and flying everywhere heat was blowing out hot air (It was burning hot when i first bled but it is still hot now) guess im good now?
I think they have pretty classic styling. No, they aren't going to win any beauty contests, but I think they're fairly handsome. And of course, any Miata I'd own would have the convertible top removed and a hardtop bolted on.
Just keep checking it regularly until the coolant level stops going down. Sounds like you have enough coolant in there now to prevent the car from overheating, so that's good. When I did mine, I was able to get it bled pretty easily, but I did keep checking it for days afterward to see if the level dropped.
the coolant went back to the 3/4 after bleeding as it was the first time ill probably check it before each drive from paranoia
If I were going to have a roadster I would want something classic like an old Lotus or Jag.
I got a truck today. It has a flip switch ignition, push button start, toggle switch security system, and no reverse gear. Guess how much I paid.
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
![]() $350. |
Ok so I got a tail light failure on the OBC. Pulled the bulb and both filaments are still intact. Switched it to the other taillight and it is fine. Something with the tail light? It's really pissing me off.
![]() Quality is remembered long after price is forgotten. |
Connections TO the bulb. Clean the socket, check and clean the harness plug. If that doesn't fix it, start tracing the wire over the wheel well. You may have the dreaded loom failure in the making.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
![]() Quote:
and a big hammer makes it easier... df
Where the insulation gets worn off the wires inside the wiring loom going over the wheel well. I KNOW you've read about it before.
| Bookmarks |
| Tags |
| :3, amber is pretty neat, big trucks are :fruit:, bueller?, chadwashere, cummins powah!!!, diesel trucks are where its at, jonisadirtyman, karl disappeared again?, no karl is back., now ed's missing too?, nsfw tags forever, sfw tags now., the cat fact thread, you forgot the randies?!? |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
