E36 (1991 - 1999)
Old 03-17-2012, 10:57 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
I think those were auto ones... They were too cheap. The title listed "manual", but the compatibility listed automatic cars...
-CJ
Old 03-17-2012, 11:12 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Guys, my e30 radiator has a slow leak and Im going tomorrow to get a replacement. Im torn whether I want to get the m42 rad to clean the engine bay a little, or if I just want to go with what ive been running all along which is another m20 rad? The dude wants $60 for either one, but idk which one I want.
Reason im hesitant for the m42 one is ive read they dont cool down the engine as much, and bleeding the system is a bitch.. Plus my temp gauge isn't completely accurate (and not running an engine fan) so I dont want to take a risk not knowing if my engine is overheating without me knowing it.
But look how pretty this looks!!
Either that, or this (setup I have now)
thoughts?
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 03-17-2012, 11:15 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
M20. Form follows function.
When function follows form in importance, you end up with lawn ornaments that don't work.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 03-17-2012, 11:17 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Originally Posted by jonesin View Post
I'm sorry to hear CJ .
On the light side of the news, those two wreckers in your neck of the woods both had flywheels for 328s in stock for cheap
Edit, I also don't know if you were aware of this, i just found it tonight looking for this issue:
"Praise be to the BMW engineers, because there is a hole in the 6 cylinder intake manifold that allows access to the top nut on the starter housing. It is actually a hole in the plastic webbing between the tubes for cylinders 5 & 6 (or 1 & 2?). With a carefully placed box wrench, you can get to the top nut on the back of the starter housing. I only discovered this & realized what it was while cleaning my manifold before re-installation. I found the attached photo online that clearly illustrates the hole I'm describing:"
I only bring it up since everyone I know who's replaced their clutch swore up and down over the need for 3' of extensions to get that top tranny bolt out.
That's the top STARTER nut/bolt, not the top bellhousing bolt they're talking about. You still can't get to the top bellhousing bolts through that hole.
Sent from my MB860 using Bimmer App
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 03-17-2012, 11:20 PM
jonesin's Avatar
The Canadian Prick.
Ah. Figures. Why would the engineering 'Gods' make it easy?
Thanks Ken
Old 03-17-2012, 11:21 PM
cj.surr's Avatar
some kid
Ah, I forgot about that hole. That was the nut and bolt that I couldn't get on. The bolt is easy, but getting the nut onto the bolt is a bitch. Maybe I could stick the nut into a socket and use that hole in the mani to reach it.
-CJ
Old 03-17-2012, 11:23 PM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Indeed, i've been trying to convince myself not to get the m42 rad, but i'd like to clean my engine bay some more ... But I also really like the m20 cooling system, especially the self bleeding overflow tank! So id probably just stick with m20 one I guess
-Usama
Old 03-17-2012, 11:59 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
If you mount a pusher fan on the front of the rad facing the engine, you can run an m42 rad, heck if I find the one in my back yard ill give it to you just so you have either option
Turbo lag is actually a headstart to make it fair
Old 03-18-2012, 12:18 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Haha, only thing is, I dont want to deal with an electric fan.. It doesn't get ridiculously hot out here for me to need one really, and if it does, then id probably just drive the brothers car since it has A/C and tan interior
-Usama
Old 03-18-2012, 12:21 AM
Mr Gusta's Avatar
Fireballs inc.
Bro your good with wiring and you've come all this way, just do it brah
Old 03-18-2012, 12:24 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
mehhh too lazy lol, plus its just added weight
I'll probably just get the m20 one since its a direct bolt on right now... But look into doing something else to the cooling system in the future. I have a lot of things to change up actually, will also do a new brake booster setup, cooling setup, exhaust setup... All in due time
Thanks though
-Usama
Old 03-18-2012, 07:04 AM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Originally Posted by cj.surr View Post
Well, on RealOEM, the 325 is listed as a 228mm, so that's probably the problem, since I'm using a 325 flywheel... Clutch is too big for the flywheel, probably messing up disengagement.
Thanks for helping me figure this out, Ed. It just really sucks that I have to do all that work all over because a website messed specs up.
Still doesn't explain the pilot bearing, though... I've just got a bad feeling that I'm gonna put a 328 flywheel in and have the same problem.
Yea dude, M3s had bigger clutches, not sure on 328 though. That's at least one issue.
thoughts?
the bigger the better.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Parting Out Complete 96 328is
Old 03-18-2012, 07:23 AM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
I'm alive lol
I remember the guy I purchased my 318 from(and e30) telling me that the dealer gave him the wrong clutch for Lola...then blamed it on the fact that Lola had climate control so it had a different clutch
Don't know if that's true but seems illogical to me.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 03-18-2012, 07:28 AM
The prize lol
Old 03-18-2012, 07:33 AM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
If my car wasn't in some sort of limp mode , I would deff say I got a little more horses from the exhaust I got from Ken. I love it
Old 03-18-2012, 08:01 AM
cj.surr's Avatar
some kid
Ok, so here's what I've got so far, according to RealOEM.
325 flywheel - 228mm
328 clutch kit - 240mm
328/M3 flywheel - 240mm
Since M3 and 328 flywheels are the same, I should be able to use an M3 flywheel with the kit, right? I can't find any M52 flywheels, but I found a bunch of S52 ones.
-CJ
Old 03-18-2012, 08:04 AM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Leaking oil from below vanos where gasket is ...this blows, now i gotta wait till guy comes back to fix it..
Sent from my Motorola Electrify using Bimmer App
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 03-18-2012, 08:18 AM
nothing.
Mein Auto: ItAintUrShtYUCare?
nothing.
Old 03-18-2012, 08:41 AM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
King of Drone
Mein Auto: Bavarian Bombshell
Dude that sucks. When I did mine the paper gasket had like fused to the head. I spent at least 2 hours using gasket remover and a razor blade and still didn't get it 100%. I got pretty much everything except around the bottom of the studs and it seems to have sealed.
I hope he makes it right.
Old 03-18-2012, 09:01 AM
B1MM3R's Avatar
Jesse Moon Bayne
He said same thing about paper gasket...he told me it was insane how stuck it was....ima put some high temp gasket maker around it to see if that fixes it while waiting on him...he'll make it right, jist suck...hes done hundreds of them and said few leak and im one of the few
Jesse
Part out.
E30 87 325e
Old 03-18-2012, 10:09 AM
B1MM3R's Avatar
Jesse Moon Bayne
Hes picking her up tomorrow night and fixing her tuesday...hes a good giy and wouldnt stop apologizing
Jesse
Part out.
E30 87 325e
Old 03-18-2012, 10:38 AM
cj.surr's Avatar
some kid
I pulled the clutch disc, and it is definitely 240mm, so there is a lot of misinformation about this on the web. So I'm guessing I should be able to run an M3 flywheel now.
The only question is if the 328 will be able to handle the S52, which should have 280ish hp, and significantly more torque than an M52.
-CJ
Old 03-18-2012, 10:46 AM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 1993 BMW 325IS
I'll just leave this here
http://cgi.ebay.com/ebaymotors/Isuzu...item2c63bda4de
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Buy stuff!
E36 parts: http://harrisonburg.craigslist.org/pts/3696167489.html
E36 5 speed swap: http://harrisonburg.craigslist.org/pts/3696120610.html
E46 parts: http://harrisonburg.craigslist.org/pts/3696151076.html
Old 03-18-2012, 10:55 AM
cj.surr's Avatar
some kid
^ Just made an offer of 499,000. Fingers crossed that he will accept!
-CJ
Old 03-18-2012, 11:01 AM
I like pie.
Oh dang, you beat my $7 offer .
Buy stuff!
:3, amber is pretty neat, big trucks are :fruit:, bueller?, chadwashere, cummins powah!!!, diesel trucks are where its at, jonisadirtyman, karl disappeared again?, no karl is back., now ed's missing too?, nsfw tags forever, sfw tags now., the cat fact thread, you forgot the randies?!?
