The official E36 OT Thread!! - Page 2619 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Closed Thread
Old 09-09-2012, 08:27 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ok guys, i have decided to go ahead and buy into a product that looks 'too good to be true'. fortunately i have some work that i can practice on to see how good it works and can give an accurate review on.
a little history on the scenario.
older early 80's gm diesel van. thermostat housing/crossover pipe goes across the front it the intake, but seperate from the intake.
the stat housing is held on by 3 bolts. steel + aluminum + lots of time = 2 of 3 bolts broken. drilled the one out fine, all the way through (no blind holes on the pipe), went to do the other bolt and broke the drill bit.
tried to drill it through from the other side, and no room to do so, as the channel obstructs from the back. tried every trick in the book i knew of to try to get this out.
no dice.
thinking i may have to cut a slice in the aluminum to make it a little easier to get out, but then i would have to get the aluminum repaired. cost prohibitive.
getting another part has yeilded no results since *everyone* onthe diesel forums that has one of these monsters is looking to find the exact same part ofr the exact same reason.
think coupe door panels, guys.
so, in my infinite searches over teh interwebs, where everyone is handsome, nice teeth, and can lift an m54 without a hoist, (ok, chip can....) i came across this product.
http://durafix.com/
it looks to be what would work, given i have no other (affordable) alternative at this point.
i also came across another product, but that will be for another time.
i should have this stuff in the next few weeks.
we shall see....
if this stuff works as well as it is claimed, the making the adapter plates and intake for the supercharger would be lighter as i could use aluminum.
to be continued...
df
Old 09-09-2012, 08:40 PM
oh, yeah, and i have been meaning to ask....
does anyone have a broken headlight?? i am in the process of making some angel eyes and need a donor to get the diameter correct.
i also need to confirm the high and low beams are the same diameter as well, so if i could get both that would be great.
i'm probably going to buy a set of glass units, but that will be to use for the install. maybe. depends.
heck, if you have a set of headlights that are cheap enough i'll consider them as well.
lmk, k??
df
Old 09-09-2012, 09:00 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
I have two or three sets of headlights!
Sent from my ADR6400L using Bimmer App
Turbo Build Here
  #65454
Old 09-09-2012, 09:43 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Maddie has developed a mysterious coolant leak. It's worrying me.
Instagram | @randytheus
  #65455
Old 09-09-2012, 09:54 PM
Needs Boost
Mein Auto: Red Sled
Pressure tester, you'll find it in 5 minutes.
Turbo Build Here
  #65456
Old 09-09-2012, 10:26 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Check the radiator drain plug. Mine began leaking there, turns out the o-ring cracked and made itself useless.
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
  #65457
Old 09-10-2012, 12:00 AM
Ozzy1989 Ozzy1989 is offline
Mein Auto: BMW 323i
Hey everyone im new here so sory if im posting in the rong thread...
Anyway i have a 96 323i auto and the gearbox ( auto ) keeps sliping changing between 1st and 2nd gear ie if im driving like a nana it will try to change around 2000rpm and the revs go up to 3000rpm before it goes into gear like a manual with a stuffed cluth would, it has no loss of power or anything and doesnt slip in gear only when changing and it does it when its cold and hot....
Any ideas btw this is my first bmw
  #65458
Old 09-10-2012, 12:22 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
http://durafix.com/
{snippage}
to be continued...
df
Hate to burst your bubble, but don't believe everything you see/read about that stuff. There are many products on the market that claim the same qualities (Alumiweld is another one). These things work (after a fashion) on THIN materials, but like any attempt to weld heavy cross-section aluminum parts, you will need a LOT of heat. It's not the aluminum solder (what that actually is) you have to get so hot....it's the base metal. If the base metal is thin, you can get it hot enough pretty quickly. If it's a cast manifold (or blower housing) you'll spend a tremendous amount of time just trying to get it hot enough for the welding metal to flow. Been there, done that, bought a "From now on I'll use a TIG torch" Tee shirt.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
  #65459
Old 09-10-2012, 09:20 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Well, yesterday was fairly productive since I only got to work in the evening. Drained the coolant, pulled the tstat out of the housing to prep for the sealant, rearranged the coolant hoses so I could flush the system tonight, filled oil with 1.5 qts ATF, and got the plugs, coils, and all the intake piping back in place. It's now off the jack stands and ready for the flush tomorrow.
Probably will flush and rearrange the hoses and do a baseline warm compression test tonight, and do the sealant Tuesday and drive it around for a while. May drive it around more Wed night if the bypass arrangement holds, and I'll take a new compression reading and put in new plugs. Thurs will be second oil change, second coolant flush, new tstat and water pump, and pulling the mani. Friday will be putting the mani back on with all new gaskets along the intake path.
Hold me to that schedule, Bimmerfest. I hope it's doable.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
  #65460
Old 09-10-2012, 09:53 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I need more coffee just reading that to do list Chad...
to the kitchen for Ice Coffee!
  #65461
Old 09-10-2012, 09:58 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
okay, so I may have messed up my shifter bushings or linkage. I left the car parked facing downhill in reverse with the park brake on, when i drove it this morning the shifter was leaning over to fifth and being weird. Then I reparked, left it in 1st, came back and it was realigned. but not too springy from N to 5 so me thinks that's getting piled on the to-do
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
  #65462
Old 09-10-2012, 10:15 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Very strange. I would think transmission bushings first, though.
-CJ
  #65463
Old 09-10-2012, 10:43 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is online now
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Detents could be on their way out too...that requires dropping the tranny.
Old 09-10-2012, 10:53 AM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Quick google and sounds like the issue I have in my car, shifted rests where 5th gear is...
Kenny what year is your car? I have a 96!!!
  #65465
Old 09-10-2012, 11:45 AM
Kdoherty's Avatar
mine is also a 96. it corrected itself but there is almost no spring tension against the shifter on the right side, only on the 1/2 side.
  • '06 325xi 6MT
  #65466
Old 09-10-2012, 11:54 AM
still learnin'
mine does this as well. no spring pressue when going into 5th. however plenty of it on the other side towards 1st.
  #65467
Old 09-10-2012, 11:57 AM
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
mine is like that too...
been meaning to fix it but the new car has me tied up...
  #65468
Old 09-10-2012, 11:58 AM
Kdoherty's Avatar
I don't plan on having the transmission out but once, so ill fix it when it comes time for the clutch,flywheel,slave bidness.
  • '06 325xi 6MT
  #65469
Old 09-10-2012, 12:06 PM
TechieTechie's Avatar
TechieTechie TechieTechie is offline
Mein Auto: 05 M3 ZCP,04 z4,01 325iT
Oh my...for the subframe reinforcement on teh touring, they have to strip out the entire interior rear of the car from the c pillar back, weld those suckers into place (both from inside AND outside), then reassemble the car. That's like 10 hours of labor. I thought a lot of this could be piggybacked onto the subframe drop (and welded from the outside), but it's a whoooooooooooole other animal. Since I got the 2001, the subframe tears are very unusual unless you track the car (In 2000s and 1999s, the tears were also seen in daily drivers) Instructions to fix it: http://www.turnermotorsport.com/imag...nforcement.pdf
I am waiting for the final estimate (which he is gonna break out the subframe reinforcment from the rest of the repairs) but given it's probably $800 in labor ALONE for the subframe reinforcement, now I'm thinking it could be better used buying an e36 track car should I decide to continue on with heavy duty driving....rather than pouring tons of track monies into the wagon.
Thoughts?
"Don't be fooled, she drives with the aggression of a scorned 17 year old"
  #65470
Old 09-10-2012, 12:34 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Makes sense to me. Alternatively, you could remove the necessary interior bits yourself and save on labor that way.
1998 BMW 328is
1966 Pontiac GTO
  #65471
Old 09-10-2012, 01:30 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
This.
Wish I could help strip the interior, it would've fun.
Unless le weeknds
Jen dont kill me but...
http://forums.bimmerforums.com/forum....php?t=1890804
-Dino
  #65472
Old 09-10-2012, 02:47 PM
Originally Posted by Dino1394 View Post
Thanks...but this is the one that was stripped to the shell and now put back together
  #65473
Old 09-10-2012, 02:51 PM
Thanks..it's a great idea, but unfortunately, it's already at the shop and track day is soon upon me. So Jen's lack of planning bites her in the butt again (particularly since poor CJ just took apart the freaking trunk for the RSMs). So it's either all or nuttin'
But given I think I'll be on the track like maybe 1 or 2 hours the whole weekend, hopefully that won't kill the darn car. Of course, with my luck, it might
  #65474
Old 09-10-2012, 05:07 PM
well i'm not gonna be building a bridge or anything, and the initial plans are for a small 'ear' portion of the housing. sorta like a 'D' with a '<' section taken out to expose the threaded hole to a 'C' to extract the broken threads. then weld/aluminum solder these parts together.
again, if it works, then great!! if not, it can't get any more broken than it already is...
if it works, then i will try to use in on some thinner stock, like 1/8" or so. the thickest part would be closer to 1/4", but i can heat that pretty evenly. just not sure of the working time with this material, but will try it and report back.
not familiar with tig, but it looks to be the best way to weld aluminum. however, i do not think that i will be shelling out the amount of money these units cost. not for a little project like this.
regardless, i will try to remeber to take pics...
df
Old 09-10-2012, 05:27 PM
still learnin'
I'm torn about buying angle eyes. Can't decide if I should spend the $200 or not.
I'm almost caught up on maintenance items. Can't decide if it's worth it for the looks or not.
Ugh!
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
