The official E36 OT Thread!! - Page 2660 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Closed Thread
Old 09-30-2012, 10:37 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Alan, I took compounding into consideration
Originally Posted by dc_wright View Post
$25 a week for 1144 weeks = $104K assuming a 10% average annual return (typical long term expected return for equity investments) and compounded weekly.
If you managed to beat the market and get 15% you're at $225K.
That's about what I was figuring when I said consistently outperforming. 240/40 yr is my 6 year window. How's that bus coming, DF?
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
  #66477
Old 09-30-2012, 11:03 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
right on schedule....
sounded a bit optimistic to me, too, but then again, i am not a financial advisor.
maybe that's why i haven't retired yet??
and i knew about not being eligible for ssi at that age, which was one of those questions i had during the 'consult'.
i did get a second opinion, or at least try to. the meryl lynch advisor didn't even want to see me without an initial investment of 10k. my question to him was, 'who, at 18 has 10k to invest?? and if they *did*, why would they need a financial advisor??'.
needless to say that went over like a lead balloon.
but it did get me to thinking about money over time.
and yeah, i probably would have lost such a huge chunk of the investment with the crash.
so, does that count as 'saving' money?? (or is that just politician math?? )
df
Old 09-30-2012, 11:07 AM
Originally Posted by Brad31late View Post
nice car, no problems..........then it needs braks???
heeeyyyyyy....was this guy ever a financial advisor in joisey??
df
Old 09-30-2012, 11:12 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I watched mine and my wife's 403(b) (non profit company version of a 401(k)) fall and loose 70% of its value. Still haven't recouped all of it. Owell.
I finally fixed my rear door lock and replaced the actuator. I never wish anyone to do that. Not hard, but frustrating.
And I was frustrated about the darn door lock, I plasti-dipped my washer tank. Thoughts?
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
  #66480
Old 09-30-2012, 11:43 AM
that looks very, uh...'halloween-ish' to me.
df
Old 09-30-2012, 11:56 AM
still learnin'
Looks better than it did. Trust me... It was all stained with washer junk, part blue part green.
Pump had been leaking for a while.
The cap looks funny in the picture though.
99 540i TiAg
  #66482
Old 09-30-2012, 12:20 PM
OV2310's Avatar
OV2310 OV2310 is offline
Mein Auto: 97 M3
Just ran some sea foam through my intake and it is smoking like a fire!!!
Its smoking way more than the you tube videos I saw and it smells bad too.
Is it normal?
Sent from my SAMSUNG-SGH-I717 using Bimmer App
  #66483
Old 09-30-2012, 02:02 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Is it normal?
How much smoke depends on how much carbon build up there is to burn off and how much Seafoam built up in the cylinders. Smoke is good, it means the Seafoam is doing its job.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
  #66484
Old 09-30-2012, 02:11 PM
dc_wright's Avatar
I think I may have a vacuum leak in my brake booster. I have a turbo like whistle I can hear better from inside the car than from the engine compartment, I have power brakes but the effort feels higher than it should (definitely higher than my E46 by comparison), and when I hook my vacuum gauge directly to the manifold I get 19", but when I tee in with the brake booster connected in I get 17"-18". Also when I apply the brakes with the vacuum gauge teed in I get a vacuum drop (expected) but it takes several seconds to build back up to 17".
Anybody had this before?
  #66485
Old 09-30-2012, 02:37 PM
still learnin'
Always wondered what would happen if carbon was removed that was built up over time and helping keep compression. Would blow by happen?
That's what's always kept me from introducing seafoam to my intake....
99 540i TiAg
  #66486
Old 09-30-2012, 04:22 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
In the mood to spend money on my car... Do you guys think these UUC FCAB would be worth it if I can talk him down some?
http://forums.bimmerforums.com/forum....php?t=1854247
-CJ
  #66487
Old 09-30-2012, 04:47 PM
dc_wright's Avatar
Generally other than carbon buildup on top of the piston on the combustion chamber surface of the cylinder head raising your compression ratio, carbon buildup rarely "improves" your compression. Carbon in the ring grooves in the pistons inhibits the proper movement of the rings in increases blow by. Carbon build up in the oil ring grooves inhibits their wiping action and increase oil consumption. Carbon build up on the valve heads can inhibit good sealing and reduce performance. Just some of the things carbon buildup can do.
A seafoam treatment can clean the top of the pistons, the first compression ring groove, the combustion chamber of the cylinder head, and the valve heads.
  #66488
Old 09-30-2012, 04:57 PM
I Am The Machine
Yowch.
// Chad //
You're a derbanana
  #66489
Old 09-30-2012, 05:24 PM
still learnin'
Mmmm warm apple pie on a cold rainy New England night.
It's 110 here! More like 55 and dropping.
99 540i TiAg
  #66490
Old 09-30-2012, 05:34 PM
cj.surr's Avatar
some kid
Originally Posted by E36 Phantom View Post
Yowch.
Attachment 343881
Yeah, but how hot is it if you aren't a hunk of metal sitting in the sun?
-CJ
  #66491
Old 09-30-2012, 05:58 PM
used the 3m headlight kit on my tucson. they were quite foggy. took pics of before and after but having technical difficulties....
think it would be similar with regular sandpaper of the same grit and rubbing compound.
in other news, couldn't get my brothers dremel, and the one i had broke. so still have some additional projects to get completed...
df
Old 09-30-2012, 06:11 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Back from the track (again...):
1998 BMW 328is
1966 Pontiac GTO
  #66493
Old 09-30-2012, 06:47 PM
Njohc's Avatar
Njohc Njohc is offline
Young + Dumb
Mein Auto: '93 325is, '05 Accent
I dont know how big of a difference those bushings make over stock... mine are all stock and the guys a VAC drove my car after they aligned it and said they've never felt steering so sharp on a normal e36. My specs were kind of specific, but nothing out of the ordinary.
Old 09-30-2012, 06:59 PM
ZeGerman's Avatar
Warm Leatherette
You will definitely notice a big difference over OEM FCABs with those UUC units installed. Stiffening up the FCABs is a no-brainer if you want to sharpen up your steering. I love my solid mounts.
1998 BMW 328is
1966 Pontiac GTO
  #66495
Old 09-30-2012, 07:00 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Don't waste your money on mounts that have bushings in them. Check out the bimmerworld ones, or treehouse ones, they are fantastic and use only a delrin(sp?) solid insert. Never will you have any FCAB replacements, and they don't increase NVH at all. I did them as one of the first mods on the M3, and they are awesome.
These ones:
http://store.bimmerworld.com/bwsport...nts-p1301.aspx
I think the price has gone up some though...
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
  #66496
Old 09-30-2012, 07:10 PM
ZeGerman's Avatar
Warm Leatherette
^I think that's what I paid for the BimmerWorld solid FCABs when I bought mine a few years back.
Edit: That's funny, it looks like I'm still the last one to have reviewed that product on their website.
1998 BMW 328is
1966 Pontiac GTO
  #66497
Old 09-30-2012, 07:11 PM
crisscross's Avatar
Hrm, I thought they were closer to $100.00 IDK
-Alan
-2000 F250 V10
  #66498
Old 09-30-2012, 07:14 PM
ZeGerman's Avatar
Warm Leatherette
Well, I definitely paid what they're asking now a few years ago. Maybe you're thinking of the eBay knockoffs that were going around for a while?
1998 BMW 328is
1966 Pontiac GTO
  #66499
Old 09-30-2012, 07:19 PM
crisscross's Avatar
No, I got the bimmerworld ones, but I got control arms and some other stuff too, I just remember my total was over $500.00. They probably were that much.....
-Alan
-2000 F250 V10
  #66500
Old 09-30-2012, 08:35 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
Just got back from a day at H2oi. It was alright.
Severe lack of BMW's, it was kind of sad. I'll have pics up eventually.
@hanloso. '98 328i/'09 Tahoe LTZ
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
