The official E36 OT Thread!! - Page 2672 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Closed Thread
Old 10-05-2012, 09:16 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Originally Posted by Ryan... View Post
I'm getting pretty upset here, I have 3 tires losing air right now, about 10lbs a night. I cant find any punctures, no cracks in the wheels, and they have new valve stems. Any ideas?
Fill the bathtub halfway with water and stick the wheel in there to find bubbles. Found a practically invisible hairline crack in one that way.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
  #66777
Old 10-05-2012, 09:17 AM
Ryan...'s Avatar
Ryan... Ryan... is offline
Please, call me Brian.
Mein Auto: 95 325ic, 16' F150
Why would that help though? Can you mount a tire in such a way that it wouldn't hold air? I figured its all all or nothing deal; its either ON the wheel or NOT on the wheel
I'll have to wait for the gf to leave, she certainly wouldn't approve
That being said, is there anyway to fix a hairline crack without removing the wheel and having it welded?
  #66778
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
this
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
  #66779
Old 10-05-2012, 09:18 AM
B1MM3R's Avatar
Jesse Moon Bayne
Could be a small hole that you can't see...the water will make bubbles if there is air coming out anywhere.
Jesse
2007 328i DD
  #66780
Old 10-05-2012, 09:22 AM
B1MM3R's Avatar
Jesse Moon Bayne
Originally Posted by TheFinanceGuy View Post
Also, I figure for an investment of the gasket $30 bucks, and 2 hours of my time. It's got to more sealed than I am now.
However, I am leary of stuff falling into the pan and getting sucked up and through the engine.
Was thinking it would be good to flush out the pan somehow after being complete...???
im not really worried about dropping much debre in there, the gasket is metal so shouldnt it be intact?
Jesse
2007 328i DD
  #66781
Old 10-05-2012, 09:40 AM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
bad image in my mind now...
I have found the OT line and sprinted past it. O well, its a sarcastic Friday.
could try having them re-mounted?
This. One of my tires was losing 10 psi after 3 days. While washing the wheels I pinpointed the leak to a 2 inch segment at the bead. Apparently the bead just lost seal because its fine now after being remounted.
The shot heard 'round the world.
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
  #66782
Old 10-05-2012, 09:47 AM
TechieTechie's Avatar
TechieTechie TechieTechie is offline
Mein Auto: 05 M3 ZCP,04 z4,01 325iT
Alan...I have a gasket if you want it. I bought it when CJ was working on the car and there was a suspected gasket leak. IIRC, the e46 an e36s are the same size. You can have it for the price of a Starbucks Latte
"Don't be fooled, she drives with the aggression of a scorned 17 year old"
  #66783
Old 10-05-2012, 09:50 AM
  #66784
Old 10-05-2012, 09:52 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Alternatively, you can check them like a tire shop does.
Take a squeeze bottle of dish soap, (with just a little bit in it) fill it with water, run it over the tire. You can do this outside, and it will bubble up at any leaks.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
  #66785
Old 10-05-2012, 10:05 AM
Ryan...'s Avatar
I found one leak on the front tire, from around the rubber neck of the valve stem (technical name?), is it possible to just replace that without needing to remove the tire + balancing the wheels?
According to Holmes tires, it will cost me $30 a wheel to have it dismounted, wheels buffed to remove pits from bead, valve stems replaced, mounted + balanced :/
  #66786
Old 10-05-2012, 10:09 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
You gonna be at the meet on the 20th?
Of course. Will you?
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
  #66787
Old 10-05-2012, 10:19 AM
jonesin's Avatar
The Canadian Prick.
Look around. That usually costs $15-20 here.
  #66788
Old 10-05-2012, 10:23 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Bad news for CA gas, Chad. Valero halted wholesale transactions due to the refinery outages. Expecting $5+/gal here soon.
Bad time to own an X5. Wish I bought a diesel E90 when I had the chance.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
  #66789
Ryan...'s Avatar
For a while, they scheduled me to work at 730, so worse case scenario I can come for the earlier shenanigans..
CarX just quoted me at "up to $30" per tire, but said it would probably run around $20/tire if all they need to do is pop it off the bead and replace the rubber valve stems. Plus, I'll get an oil change, check up, rotation, and wiper blades for an additional $30
  #66790
Old 10-05-2012, 10:24 AM
I Am The Machine
That's a hell of a deal for all that work. But yes, you can do it without the balancing if it's just the valve stem.
// Chad //
You're a derbanana
  #66791
Old 10-05-2012, 10:31 AM
I Am The Machine
It's already $5 here. But I'm not really affected any more now that I'm taking ACE.
Filling up the Rovers will still suck, but I won't be dumping as much gas in now. I haven't filled up the Disco all week and still have half a tank. I bet the Chevron by my house is missing me.
// Chad //
You're a derbanana
  #66792
Old 10-05-2012, 10:32 AM
Ryan...'s Avatar
Well I'm gonna bring it to the CarX place I think, they'll do the same work, plus they have a billion coupons for cheap labor. If I can trick them into doing my spark plugs for cheap that'd be excellent
Or I can just keep filling them up and wait until I mount the snow tires in two months..
  #66793
Old 10-05-2012, 10:56 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
If you remove the tire at all it will need to be balanced.
Ryan, it could be the valve stem, actual valve, tire to wheel bead isn't seated, or small hole. It's probably the bead, the wheel will need to be sanded and cleaned at the bead.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
  #66794
Old 10-05-2012, 11:00 AM
Ryan...'s Avatar
Well I just dumped soapy water on the 3 that are leaking, and I have bubbles by the 3 valve stems, so I'm hoping that's the only leak. Regardless, I'm only gonna get those 3 done, as I can play with the wheels later when I install the Blizzaks.
Old 10-05-2012, 11:01 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Wait me? I'm not Alan... but my little brothers name is Allen. I'm Patrick
however. DEAL! I'll take you up on that! < Where in Mass are you?
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
  #66796
Old 10-05-2012, 11:05 AM
I Am The Machine
Nope. If the tire was already balanced when it came in they can chalk it and just match the chalk when they reinstall. No sense in paying to redo something that's already correct.
He does have a name! We all thought you were like most financial analysts, faceless and nameless.
// Chad //
You're a derbanana
  #66797
Old 10-05-2012, 11:14 AM
still learnin'
Those are accountants Us finance people figure out how to make what you want happen... we work around the rules
Didn't know it was that much of a mystery
Oh and my parents are in SF today. To rub it in, they keep sending me pictures. They will be watching the blue angels tomorrow. I asked again where my invite to come was. It was pretty quite on the phone for a minute
99 540i TiAg
  #66798
Old 10-05-2012, 11:18 AM
petriej's Avatar
This weekend is going to be insane. So much going on in the city, it will be soooo crowded. America's Cup, Bluegrass concert, parades, Fleet week, Giants home game...
Sadly I have to go in an out of SF twice this weekend...
GGC BMW CCA #443004
Join the BMW CCA!
  #66799
Old 10-05-2012, 11:19 AM
I Am The Machine
So I guess we're yin and yang since I'm in compliance.
// Chad //
You're a derbanana
  #66800
Old 10-05-2012, 11:27 AM
still learnin'
oh you compliance people drive me insane!
but really, I follow the rules that I need to follow. 95% of my projects are gov't related. WAY to many rules. then there is the company rules, which are generally more strict than my clients rules. but whatever.
I just had a big arugment with the gov't compliance guy. I was making my company pay a $150 change fee that was caused by management and not my project. compliance guy kept telling me the project needed to pay for it. Lets just say that I won and he doesn't know it yet.
QUOTE=petriej;7115850]This weekend is going to be insane. So much going on in the city, it will be soooo crowded. America's Cup, Bluegrass concert, parades, Fleet week, Giants home game...
Sadly I have to go in an out of SF twice this weekend...[/QUOTE]
should be a good time for you right? HAHA best of luck! They are staying in the city. Don't even have a car till sunday when they head to napa.
99 540i TiAg
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
