E36 (1991 - 1999)
Closed Thread
Old 12-20-2012, 07:58 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
Originally Posted by bimmer claus View Post
I've got three sitting Ina box in the garage.
Thanks man I'll pull it apart and clean her up didn't know if it was the ICV or not because when my brothers was sticking it displayed different symptoms... Thanks though saved me some cash
whoa 3? mind selling one to me? assuming it's the OBDII one for a 2.8
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
  #71977
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Originally Posted by TechieTechie View Post
What the frig happened>!!!@#>@!#!@#
  #71978
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Yeah, cleaning the ICV is a good start. Could also be a vac leak, so check all the little rubber hoses. (don't forget the little one that goes from the bottom of the manifold to the FPR)
-CJ
  #71979
Old 12-20-2012, 07:59 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Expert? Not me. I couldn't even get my '95 Blazer to run.
That sounds like an idle control valve malfunction to me. When the throttle is closed, it's CLOSED, as in no air getting past the throttle plate. Unlike some fuel injection systems and all carbureted ones, the idle isn't controlled by the throttle plate being set to a tiny opening. It gets it's idle air through the idle air control valve. You can try cleaning it with aerosol choke cleaner, but you'll have to remove it to do that.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
  #71980
Old 12-20-2012, 08:01 AM
Kdoherty's Avatar
This, that big sucker that actually goes straight to the ICV is a common culprit. and good luck going to the store and just replacing it with some random hose, i had to buy a special diameter fuel line spec rubber hose to replace it...
  • '06 325xi 6MT
  #71981
Old 12-20-2012, 08:04 AM
TechieTechie's Avatar
TechieTechie TechieTechie is offline
Mein Auto: 05 M3 ZCP,04 z4,01 325iT
[QUOTE=bimmer claus;7261703]What the frig happened>!!!@#>@!#!@# [/QUOTE
You obviously weren't online last night Full detail in past posts
Cliffs: Guy sideswiped me when I was making a right turn.
Who is at fault is still TBD.
I haz a Nissan Rogue as a rental.
"Don't be fooled, she drives with the aggression of a scorned 17 year old"
  #71982
Old 12-20-2012, 08:06 AM
cj.surr's Avatar
some kid
I think I replaced mine with Autozone hose.
-CJ
  #71983
Santa
Mein Auto: 95 M3
The ICVs I have are all outta the 323's picked some up cheap got one for free the other was from the engine swap I don't know if it'll work for yah but if it will I'd be more then happy to sell one..... and thanks I'll make sure to check the larger diameter hose as well CJ....have to tear it apart Sunday I guess sick of the stalling.I'll replace any hoses that look worn...lucky for me there's an ACE 1/4 mile down the road so if poop ever hits the fan i can always walk for back up parts
I'm sorry about the M seems to be the month of destruction and p/o'ing insurance companies.
  #71984
Kdoherty's Avatar
[QUOTE=TechieTechie;7261714]
good news is, the M3 will get some new paint and stuffs, and you have a car that you can beat unmercifully in the meantime.
  • '06 325xi 6MT
  #71985
Old 12-20-2012, 08:07 AM
cj.surr's Avatar
some kid
I would imagine the 323 ICV is the same as a 328 one.
-CJ
  #71986
Old 12-20-2012, 08:08 AM
Kdoherty's Avatar
welllll the 323 is just an M52 with a different stroke right? they may work.. i'll check pelican and see the the P/Ns match
Edit: we have bingo they are the same part on the M50, M52, and M52tu
  • '06 325xi 6MT
  #71987
Old 12-20-2012, 08:14 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
should I take my B1MM3R plates and put them on the e30 and put 318LMAO on the 318? or suggestions for plates on the e30?
or could have
318-B1MM3R
e30-B1MMM3R
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
  #71988
D'oh, You Kids!
Big storms/tornadoes rolling through here this morning. Major damage to the Mercedes dealership in Mobile. About 30 cars with severe damage; some on their roofs/sides. We are currently between lines of storms.
I was supposed to take the 633 to Mobile to get the old tint stripped and new installed, but the road to the shop was closed and they had no power, so I never left home. Now I find out the road is open, they got power back and are open, but it's too late to leave now. They said it was going to be an all-day job just getting the old horrible tint off the glass.
Quotes to live by:
BMW-CCA #441426
  #71989
Old 12-20-2012, 08:18 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
jen, those pics are nowhere *near* what i expected to see. still sucks, tho...
the suspension on that side most likely got tweaked a bit, so it'll have to get lifted up to inspected. i would not suspect any sort of subframe/frame damage to have been done by this.
hope it all works out well for you.
and it looks a bit chilly up there...
df
Old 12-20-2012, 09:05 AM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Are these OEM?Click image for larger version
ID:	353961Click image for larger version
  #71991
Old 12-20-2012, 09:07 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
No they aren't Brad. The 'grain' doesn't match the dash.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
  #71992
Old 12-20-2012, 09:08 AM
Kdoherty's Avatar
uh I'm going to say Hell no. but that is really really clean.
  • '06 325xi 6MT
  #71993
Old 12-20-2012, 09:11 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Originally Posted by Brad31late View Post
100% not OEM.
That looks like very minor damage, Jen, and very easy to repair. Basically just unbolt the damaged stuff, and bolt new parts back on. If I was closer, I'd help ya make the repairs and you'd walk away with money in your pocket.
1998 BMW 328is
1966 Pontiac GTO
  #71994
Old 12-20-2012, 09:12 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
That looks ghetto to me. Not clean...
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
  #71995
Old 12-20-2012, 09:13 AM
Kdoherty's Avatar
upon looking even closer i saw the exposed screw and that the DS was blended into the dead pedal.. that would annoy the sh!t out of me.
  • '06 325xi 6MT
  #71996
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
Hmmm, figured that, thought I would ask... they are on there perfectly though, no gaps or anything
  #71997
Old 12-20-2012, 09:16 AM
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
And yes, its annoying...
  #71998
Old 12-20-2012, 09:19 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
i like this idea
-Dino
  #71999
Old 12-20-2012, 11:07 AM
cj.surr's Avatar
some kid
So I called the court today... They said that my court date will be in February (I sent in a not guilty plea). I'll be in school then, so they said I can call before my date in Feb and reschedule.
Do I have grounds to plea not guilty? I have a feeling I'm gonna go into court and look stupid. Obviously I was going more than the speed limit. Or should I try for a plea bargain? (not sure how that works). I know Jay said that the standard bargain is 10mph less. I'd be fine with that.
-CJ
  #72000
Old 12-20-2012, 11:43 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
You sure do have grounds to plea not guilty. When you go to court you will talk with a district attorney, he/she will offer you 10mph less then your current infraction (you can try to get more knocked off but up here they are pretty strict about only knocking 10 off and no more) and then you will accept this in front of a judge.
You may go up to the judge first before speaking to the DA, plead not guilty to him so that you can talk to the DA.
Dress nice too, never hurts.
Oh and you wont be the only person there, there will be a lot of other people with tickets/ minor offenses dealing with the DA and the judge, so all the focus wont be on you.
Closed Thread
-*nga*-, 12-6 cloud: yes or no?, :3, because racemower!!, chads looking for a new audi, no tag integrity pls, pls stop erasing da damn tags, what's integrity?, whats audi?, you guys crack me up...
