E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Ugh, this SRS light is going to drive me to ruin.
Quick Recap: About 6 months after I swapped my steering wheel (with no SRS light) and 3 months after I swapped in the E46 seats (with no SRS light), the light randomly tripped one day while I was driving to work. Pulled the codes, got the Driver's and Passenger's Seat Belt switches at the exact same time. I did the "resistor fix" that tricks the car into thinking the switches are sending the proper resistance. That turned the light off for about 20 minutes, then it threw a light but wouldn't throw a code. I replace the airbag module and paid my shop to install it and recode it, which showed me it was throwing code 01-02, something about the driver's contact ring. Pulled the wheel, cleaned the ring, reinstalled and the light went off for about 40 minutes, then came back. I figured maybe the seat belt switch codes were due to the old SRS module on its way out, so I undid the resistor fix. Nope, threw both codes again, and the passenger occupancy sensor, BUT not the driver's firing circuit. I redid the fix, cleared the codes, and they went away... for about 5 minutes. Then the firing circuit one came back. New News: I'm completely fed up with trying to fix it completely, and I can't just throw good money after bad down this rabbit hole, AND I'm due for inspection next month, so its time to get dirty. I did this fix: http://www.maxbimmer.com/forums/showthread.php?t=93207 Which gets the light off and will make driving a little more peaceful, but it doesn't turn the light on when the key is in position 2, which is what needs to happen to pass inspection. Does anyone have an idears about how to trick the system to do its diagnostic cycle? I have a code reader, so if I absolutely have to I think I can get a sticker on it by asking my inspection place to kindly look the other direction while I clear the code, and then hope it doesn't come back on while he's pulling it into the shop (likely with my luck). Another option is just to replace the contact ring, but I'm hesitant because 1.) The one in there is less than a year old, 2.) its expensive, 3.) I don't trust this thing when it says there is a fault in one particular place any more, all it does is jump around to to the next thing after I fix one... ...and people wonder why I drink...
There's a shop near me that usually only has one guy working so he was you sit in the car and do all the lights, I for my 318 inspected with an SRS light there for two years..... Just mentioning it because I know you pass my way every once in a while.
Sent from my ADR6300 using Bimmer App
Buy stuff! E36 parts: http://harrisonburg.craigslist.org/pts/3696167489.html E36 5 speed swap: http://harrisonburg.craigslist.org/pts/3696120610.html E46 parts: http://harrisonburg.craigslist.org/pts/3696151076.html |
![]() I just threw this in there to see if it would work, figured it'd be a lot easier just to tape over the insulation I scraped off instead of re-soldering them. Here are the wires I'm actually jumping: ![]() I was hoping that the wiring diagram would give me some clues and I could snip or bridge something to make it come on during the diagnostic check but go off afterwards. But what if, as you suggest, I stick something in my little wire jump that delays giving power from the violet/green wire to the blue/black for 20 or 30 seconds? I just wouldn't even know what to look for at radio shack. EDIT: Thank you google: http://www.wolstentech.com/products/...delayrelay.php Sounds like I could get a positive switching version of one of those things, set the delay to 30 seconds, ground the relay where the control module is grounded, use the vi/grn as the trigger and the blue/black would be the output. I'd just have to go find a 12V supply for the relay somewhere, could I piggyback off of one of the center console light things? (which haven't worked in my car for like, ever)
I clocked in today at just over 200. Still need to drop some weight, as I'm not very tall -- 5'9" or so.
My folks gave me the rundown on Los' car. Turns out my cat likes to guard it or something. Maybe there's mice inside it? Should be safe where it is, all covered up. Joey, what you're looking for is an inductor. It resists change in current, so on power up it will delay power and after cutoff will supply power. I'm not sure how big you need, but you'll need to be careful. Inductors are no joke dangerous.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
Im so over this winter
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
Gotcha. My napkin math was magnitudes off, then. Perhaps a more complex solution? Or maybe fixing the real problem? Find a friend with the equipment to reset? Great time to join the BMW CCA.
But, you could get a small switch and controller, and program the controller to allow pass through until it gets a pulse from the ignition wire, and then cut power to the light after like 2-3 seconds.
Sent from my LG Revolution 4G using BimmerApp
![]() All of us sitting here wracking our brains with circuitry and such.....that seems so much more simple and elegant. Feel awfully silly now. ![]() Sent from my LG Revolution 4G using BimmerApp
Yeah it will fail in VA if it doesn't go off after starting.
Gotta love upstate ny salt!
![]() And an e36 rear bumper ALMOST fits in the passenger compartment ![]() V1 performed as advertised on the trip home. I got half mile notice on a statie shooting ka band in the opposite direction from the other side of a concrete overpass! Would have been invisible otherwise. Pretty incredible. Sent from my SCH-I405 using Bimmer App
-CJ
| Bookmarks |
| Tags |
| :3, amber is pretty neat, big trucks are :fruit:, bueller?, chadwashere, cummins powah!!!, diesel trucks are where its at, jonisadirtyman, karl disappeared again?, no karl is back., now ed's missing too?, nsfw tags forever, sfw tags now., the cat fact thread, you forgot the randies?!? |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
