Old 07-28-2009, 12:21 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Originally Posted by QSilver7 View Post
How are each of your cars configured...could it be that one of you has the low instrument cluster and the other has a high instrument cluster?
You can't get the message "CHECK COOLANT LEVEL" if your instrument cluster doesn't have the 20 digit alpha/numeric display and you have the "Graphic Display" instead.
Yes, I have the high cluster and the OEM Navigation system and the OBC. But still, if there is a place for a sensor... ???? The OP says he has "check engine oil levle". So your's doens't do that either?
mw
MatWiz
"Seeing is not believing. Believing is seeing." -Judy the Elf
Old 07-28-2009, 12:43 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
mw
E39 owners that have the LOW instrument cluster...have a Graphic Display for some of their warnings....then the "idiot" lights on the cluster turn on for "oil" problems. Depending on which color (yellow or red) the light is...determines the issue:
This is the low instrument cluster's Graphic Display:
Those that have the HIGH instrument cluster...the Check Control system will put up text warnings that are either Priority 1 or 2:
Q {BMW CCA Member #191509}
(SOLD)
Old 07-28-2009, 12:59 PM
TheStig TheStig is offline
Some say...
Mein Auto: N/A
I have the low cluster...
Old 07-28-2009, 05:14 PM
LMSenus LMSenus is offline
Mein Auto: 2003 BMW 530i
I have the high instrument cluster with the text display.
The verdict from the dealer was they couldn't find anything wrong, except the oil level was down about half a quart. They said there were no codes lurking on the computer, and they saw no obvious leakage. They added a quart of oil and didn't charge me for anything.
I'm still not convinced something isn't strange. There's no evidence of leakage, but we've had to add 2 quarts of oil in the last two weeks (only 5 weeks after an oil change)
I guess we have to keep an eye on it and see if the oil level holds...
Old 07-28-2009, 06:06 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Whatever you do, find a good local BMW mechanic and go there for a second opinion to rule out sludge.
And if you have not done so, change your oil every 4-5K. When it comes to oil change interval, do not listen to the dealer.
Just Google "BMW Sludge"and you will alot of pics on it:
http://syntheticlubricants.org/BMWsludge.jpg
Old 07-28-2009, 06:14 PM
MatWiz's Avatar
Mein Auto: 528
Damn $tealer! Having the audacity not to charge you for checking your car, and adding oil DO NOT TRUST THEM. Something is not right.
2. Some cars just burn a lot of oil. See how many miles for you to add 1 quart, and post back here?
How many miles on your car?
mw
MatWiz
Old 07-28-2009, 06:18 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
BMWs shouldn't burn oil….at least at reasonable mileages assuming oil has been changed….
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 07-28-2009, 06:22 PM
MatWiz's Avatar
Mein Auto: 528
But many do burn oil. Mine doesn't burn anything. Zero. But there are others that burn quite a lot.
mw
MatWiz
Old 07-28-2009, 06:50 PM
Agreed. My woman's intuition is telling me something isn't right. Or they're just being patronizing. You know the deal. "Oh she's a woman. What does she know about cars?"
mw
Car has 43,115 miles on it as of today. Last oil change was at 39,350 or thereabouts. Call it 4,000 miles since the last oil change (June 10) and it was down a quart and a half.
Anybody know a good BMW mechanic in western Hunterdon County, NJ?
Old 07-28-2009, 07:16 PM
LMSenus,
Has anyone other than the BMW dealer changed your oil?
Are you the original owner?
Get some popcorn and Coke and read through this thread, it is like a comedy show by reading through the posts by "dambro24". Pay attention to Post #64:
http://www.bimmerfest.com/forums/sho...d.php?t=349741
As it turned out the Oil Filter Cap has a broken part, the one in the following pic with the 36-mm socket on top of it:
With the broken part in the Plastic Oil Filter Cap, the oil pressure is not registered properly ---> "Low Oil Pressure" Warning Light.
A new Plastic Oil Filter Cap is about $28 at dealer.
It is a piece of cake to replace right in your driveway, provided this is your problem. It may not be the case, but just a thought.
You don't know until the Plastic Oil Filter Cap is removed and compared against a Brand New part.
Old 07-28-2009, 07:28 PM
gumbi4u gumbi4u is offline
Tha All-star
Send a message via AIM to gumbi4u Send a message via Yahoo to gumbi4u
Mein Auto: E60M5/E39 SC525i/540/330
You are not too far from us. We are exit 50b on 78. Its worth the trip. We know these cars inside and out.
Originally Posted by FP5241 View Post
hahaha.. at least they forgot about the flower wheels and richard simmons pic... I'll be a fruit loop instead of a flower weilding exercise guru..
Old 07-28-2009, 07:29 PM
Originally Posted by cn90 View Post
LMSenus,
I am the second owner. I did get the entire service history on the car prior to purchase, and it was only ever serviced by a BMW dealer. As it was still under the CPO, I had the oil change in June done by my local dealer.
The only other thing to note is the original owner only drove about 6,000 miles a year and only had the car serviced annually. I don't know if that makes it more likely to have a sludge problem or not.
Now I'm going for the popcorn and settling in for some (apparently) entertaining reading
Old 07-28-2009, 07:36 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Where do you find the oil capacity. Don't see it in the mannual for 2001 530i.
Old 07-28-2009, 07:39 PM
Approx. 7 qts.
Old 07-28-2009, 07:44 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
All cars burn oil, many not enough to notice on the dipstick but every single car on the road does burn some oil. Oil lubricates the piston rings, and of course some is left of the cylinder walls. BMW's are in face known (esp the M cars) to burn more oil than any other car on average.
Old 07-28-2009, 07:46 PM
dannyc9997's Avatar
Mein Auto: 540i
That is a VERY reasonable amount of oil to be burned over that period. I wouldnt even give it a second thought unless there is an obvious leak.
Old 07-28-2009, 07:55 PM
MatWiz's Avatar
Mein Auto: 528
7 quarts.
mw
MatWiz
Old 07-28-2009, 08:09 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
Guys,
M54 3.0 engines are notoriously known for consuming oil. Every M54 engine I know burns at least a quart of of oil per interval.
Replace the CCV will help decrease the amount but not completely.
Old 07-28-2009, 08:11 PM
QSilver7's Avatar
Look again...you should find it under CAPACITIES: below is the fluid chart from the owners manual for the 528i/540i...and the 2nd image is from the manual for the 525i/530i/540i...see Engine Oil Filter Change...
(SOLD)
MatWiz's Avatar
Mein Auto: 528
Learn how to check your oil using the dipstick every morning before you turn on your car.
Keep an eye on it and see how many miles per quart you are losing.
Do not wait for the car oil sensor to tell you that you neglected your engine.
DO NOT over fill your oil above the maximum line. Not even 1 millimeter.
Only use the 5-30 full synthetic oil you buy at your BMW dealer. (Yeah I know - everybody is going to jump on me and turn this thread into a "what is the best oil for..." So forget that - this is only for your little experiment until you figure out what is going on - if anything at all.)
That 1cm between the lower line and the top line on the dipstick is 1 quart. - Don't overfill.
....and of course report back so we can give advice.
Oh, and I was joking about your $stealer. If they didn't charge you, they are ok.
mw
MatWiz
Old 07-29-2009, 06:51 AM
Dutifully checked the dipstick this a.m. so we know exactly what our baseline is.
Maybe I'm panicking over nothing. The car is still new to me, and I'm still learning what's "normal".
Thanks for your help and encouragement.
That was pretty comical (if a bit painful) to read. (Why, oh why, can't people write decently anymore? "u" and "r" by themselves are not words! And would somebody please buy this guy a capital letter, and maybe a punctuation mark or two? ) Still, the lesson is important: check the simple stuff first. It's usually the $0.25 washer or the like that's the source of the problem.
Old 07-29-2009, 07:20 AM
16valex's Avatar
LMSenus,
Most 530 and 330 that has the M54 3.0 engine consume a bit of oil, believe or not dealer will tell you a quart per 1000 miles is acceptable.
Have you done the CCV system in your car? I would suggest to have it done it will cut the amount of oil consumption in half if not better, plus your engine will love you for it.
Old 07-29-2009, 09:02 AM
LMSenus,
Back to that comical thread:
It took us a long time to diagnose the problem for "dambro24". The interesting part about that thread is that I thought it was a defective Oil Pressure Sensor, and since it was a $5.00 part (aren't you pleasantly surprised there is such thing that costs only $5.00 in a bimmer....), I told "dambro24" to replace it.
In the process of removing the Oil Filter Plastic Cap (that needs to be removed to get access to the Oil Pressure Sensor), "dambro24" discovered that his Oil Filter Plastic Cap is missing a part, maybe from the many times the oil is changed, the previous mechanics accidentally broke something off. Then "dambro24" never bothered returning to post a follow-up. I had to send him a PM to tell him please post a F/U so all of us can learn from it and voila.....see post #64. It was a valuable lesson for everyone to see how a small little part can wreak havoc.
Since engine oil is the lifeblood of the car (no engine oil pressure is like having a heart attack, the car engine will seize in 1-2 minutes = $5-6K repair!), if I were you, I'd do the following for peace of my mind:
I use EACTuning dot com for many of my cars, so here you go.
1. Change the Oil Filter Plastic Cap. Use only BMW part:
Part# : 11421744000 = $25.00
http://eactuning.com/parts/product_details/11421744000
2. Go and buy 7 qts of good synthetic oil (I use Valvoline Syntec). At 4K miles, you are due for an oil change anyway.
3. Get a new Oil Filter. You can use either brand from here:
PN 11427512300 = $5.90; I use "Mann" for all my bimmers, Volvo.
http://eactuning.com/parts/product_details/11427512300
4. And lastly get a new Oil Pressure Sensor (aka Oil Switch).
This is basically a switch: On-Off type, which means when oil pressure falls below a pre-set value, let's say 3-4 psi rather than 7 psi at idle:
Then this Oil Switch will trigger a warning light on the Instrument Cluster, which may even shut your car down to protect the engine.
PN 12617568480; Get TRW-MERA (OEM) $6.50
http://eactuning.com/ssf/part_number_search/12617568480
The Oil Switch fits right behind the Oil Filter Housing:
Then go for the oil change, at the same time, swap the new Oil Filter Plastic Cover and then install a new Oil Switch (changing the Oil Switch is a 5-min job).
All in all, this next oil change only costs you an additional $30 (Oil Filter Plastic Cover and Oil Switch) and you will have eliminated these 2 items as a culprit should the warning light came back later (I doubt it).
Good Luck and this is the joy of owning a bimmer!
Old 07-30-2009, 05:48 PM
Alrighty, then! I've got some homework, apparently. You guys will be amused by this: my husband (who has worked as a mechanic) insists that I work on my own car. He helps me, but he insists that I do as much as I can (with his help) and learn what's what under the hood. So this is my project.
Checked the oil level tonight, still holding steady.
Old 07-30-2009, 07:23 PM
1+!!!
You will soon realize that 90% of the routine maintenance (oil change, air filter change, spark plugs change, brake job etc.) is within the scope of a Saturday mechanic willing to learn.
The heavy duty stuff (muffler, clutch, strut etc.) can be left to a shop as you don't run problems very often.
Welcome to the Saturday Mechanic Club!
