List Something You Discovered About Your Car AFTER You Bought It... - Page 33 - Bimmerfest - BMW Forums
Old 02-23-2014, 05:08 PM
afscotch afscotch is offline
Mein Auto: 2010 535i
Originally Posted by flipwils11 View Post
I read your post and and it made me wonder about the 550i I bought about a week ago. Ran out to the garage, wtf, I don't have them either. My e39 540i had them!?
So much for my Thule roof rack from the 540i...
So much for my one-of-kind feature! Haha
Sent from my DROID RAZR HD using BimmerApp mobile app
Old 02-23-2014, 06:05 PM
njlou njlou is offline
Mein Auto: corvette/528xi
Roof-mounted luggage rack*
A special rack system is available as an option
for your BMW.
The mounting points are located in the door
openings or on the roof rails*.
Old 02-24-2014, 06:07 AM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
Originally Posted by Happywith535i View Post
That space in the trunk is for installation of the cd changer.
I'm not sure which space you're referring to but the cd changer for an E60 goes in the glovebox.
Old 02-24-2014, 06:09 AM
Originally Posted by Marine0369 View Post
I discovered the windshield squirters are not that great.
Mine are just fine, both headlights and windshield. Yours might have something plugging it up.
Old 02-24-2014, 06:11 AM
I can't turn the outside lights completely off with the car running. Anyone know how to do that?
Sent from my KFTT using BimmerApp mobile app
Turning my knob to center turns everything off. I'm not sure if that is pre-LCI or not.
Old 02-24-2014, 06:30 AM
phedrick phedrick is offline
Mein Auto: 2010 528i xdrive
Upgradding the maps on the nav system is crazy expensive
Old 02-24-2014, 08:33 AM
Marine0369 Marine0369 is offline
Mein Auto: 2001 Ram 2500 4x4 Cummins
You mean your headlight knob? Nope; doesn't work for me as I tried that right from the start. However, I have not tried turning it to off, and then starting the car.
Mike
2009 535i X Drive Premium Monaco Blue
Old 02-24-2014, 08:34 AM
It just seems weak, with 2 big streams per jet.
Mike
Old 02-24-2014, 09:00 AM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is offline
545i pilot
Mein Auto: e60 545i e34 540 e32 740
Mine are perfect horizontal fans, you should try cleaning them
Old 02-24-2014, 09:06 AM
Will do; I didn't know how they were supposed to be. Now I do!
I wonder if I should just put a bunch of dish soap in the reservoir? I don't imagine they come out too easily to clean them manually? Thanks!
Mike
Old 02-24-2014, 09:15 AM
545i pilot
Well mine have always been just right, so I really couldnt say how to clean them. Im sure doing a search here on the 'fest would yield some pretty good info....I guess dish soap might help, but dish soap will DEFINITELY strip the wax right off of your car, so I guess if it works youll need to wax afterwards.
Old 02-24-2014, 09:22 AM
I'll try cleaning them with a tooth brush and see if that helps. Thanks!
Mike
Old 02-24-2014, 10:13 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
No, not really.
Old 02-25-2014, 03:43 AM
kfswart kfswart is offline
Registered 550i Beast!
Mein Auto: 550i
I have owned my 550i for an unreal couple of days now...never experienced anything like it. a 1/4" push on the pedal brings instant ear to ear grin, as I realize what warp drive must be like My first "aha" moment is realizing I need to set up a nursery in my garage for bottle feeding the battery system. The second, was needing to double pull the door handle to open the drivers door from inside.
Old 02-25-2014, 04:36 AM
I need to double pull the door handle as well but only when I have the door locks automatically lock. First pull unlocks the door second pull opens the door.
Disable the auto door look function and you will only have to pull once to open it. That is how it is on mine anyways.
Mike
Old 02-25-2014, 07:51 AM
aber57 aber57 is offline
Mein Auto: 2007 550i 6MT
They include washer jet cleaner tools with most loaves of bread. Take the twist tie and pull the plastic off the metal spine. The wire can get the outside clog off. I assume there is a rubber goody down inside nozzle to do the fluidic spread of water so don't force the wire in very far at all. Just use it break the crust and gunk from nozzle outlet.
Old 02-25-2014, 09:38 AM
Mein Auto: 550i
Thanks for the info I am really enjoying the journey of learning all of it's secrets.
Old 02-25-2014, 11:16 AM
I turned the daytime running lights off and all the lights are off (with light knob on middle position) when car is running.
Mike
Old 02-25-2014, 11:39 AM
If you mean the center =0, that is OFF!
You want to put the switch on the left position for automatic on/off or to the right for constant on.
If you have the auto dimmer option it may be different!
Old 02-25-2014, 11:58 AM
Yes; center (0) is off. However, with daytime running lights activated in the iDrive, they do not turn off even on position 0.
Mike
Old 02-25-2014, 01:12 PM
mitchelljnv mitchelljnv is offline
Mein Auto: CARBON SWARTZ 550i sport
The reverse lights suck. Searching for an upgrade.
On my 08 550 I bought LEDs and they were no brighter plus the computer kept giving errors because they don't pull enough amps
Old 02-25-2014, 04:27 PM
Did they say error free?
Mike
Old 02-25-2014, 04:29 PM
DIY'er
Originally Posted by Rrosol View Post
The radio presets aren't just for the radio. They can be programmed to call the wife, banker, or boyfriend. Just bring up that person in iDrive, and instead of hitting Call, press and hold a preset button. I suspect this works for all kinds of iDrive functions, now that I think about it, e.g. checking oil level and other hard-to-find functions. I still need to play with it a bit.
Interesting. Will have to try that tomorrow.
Old 02-25-2014, 06:48 PM
PolkNole's Avatar
PolkNole PolkNole is offline
Mein Auto: 2008 535i
The radio presets aren't just for the radio. They can be programmed to call the wife, banker, or boyfriend. Just bring up that person in iDrive, and instead of hitting Call, press and hold a preset button. I suspect this works for all kinds of iDrive functions, now that I think about it, e.g. oil level and other hard-to-find functions. I still need to play with it a bit.
Yep - works for maps, radio, phone - I have two buttons I use for maps - one for directions home, one for directions to work.
JB4 Tuner; RPi Exhaust; Sport, Prem & CW Pkgs; Nav; HUD; L7; hardwired V1; M Trunk Lip; Chrome Rims; 17% Tint; Michelin PS PS2s
Old 02-25-2014, 09:18 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Preset buttons that are multifunction are LCI only, LCI cars have 6 buttons under the DVD player that can be preset to control a variety of things.
Marine: If you have an LCI car the DRL can be disabled in the iDrive, if you have pre-LCI - nope, sorry, DRL are supposed to be on whenever the car is.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
