Old 07-05-2009, 11:03 PM
540NUT 540NUT is offline
Mein Auto: 2002 540i
e39 oil indicator reset?
see if u guys can help me out?
how do you reset the oil indicator on the dash after an oil change?
Old 07-06-2009, 12:44 AM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
It took about 10 seconds to search the answer. You could have found it faster than I can type this sentence and post the answer.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 07-06-2009, 03:48 PM
timmychuck timmychuck is offline
Mein Auto: 1997 528i
will this work for my 09/1996 528i
Old 07-06-2009, 04:13 PM
chiefwej's Avatar
Freude am Fahren
Nope, Not unless you have had the cluster replaced with a late model one. But it will work for the OP's 2002 540i. Your car needs a reset tool or the jumper wire trick. (do a search)
Old 07-06-2009, 06:54 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Service Interval Light Reset Instructions
Timmy...ditto what Chief said...and...did you read the heading at the top of the page? It says that the instructions are for the e38/e39/e53 with 9/2000-up build date.
I just changed my oil today in my 99 540iT which still has the 20 pin DLC (data link connector) in the engine bay. This is how you reset your OIL SERV or INSPECTION light if you change your oil and don't have a BMW reset tool or a Peake or other aftermarket tool.
All you need is a wire (paper clip will do) or a pair of needle-nose pliers. Just short pins #7 & #19 (the pins are numbered and MAKE SURE YOU HAVE THE CORRECT PINS...STICK THEM IN THE WRONG PINS...YOU'LL SUFFER THE CONSEQUENCES OF YOUR OWN ACTIONS!
After changing your oil or performing an Inspection I or II...to reset the SI Light intervals and restore 5 green LEDs:
  1. raise hood and unscrew the 20-pin round DLC cover
  2. Insert your tool of choice (wire or needle nose pliers) into pins #7 & #19
  3. turn your ignition to POSITION 2 (start counting the seconds: 5-10 seconds for OIL SERV...10-15 seconds for INSPECTION)
  4. remove your tool of choice from the 20-pin DLC for the time interval required for whichever RESET you're performing
  5. screw the DLC cover back on (lights should reset at this point...see images below)
  6. turn ignition off
Q {BMW CCA Member #191509}
(SOLD)
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Cross the 19 and 7 pin with a wire, turn the ignition on, wait 10 (I think) seconds, pull the wire….iirc. I use a buddy because I don't want to go longer than 10 sec. Searching will turn up more than enough information.
You can also spend an exorbitant amount of money on a tool that will do this, or spend money on a Peake or Carsoft code reader, which will help you diagnose any unfortunate problems you may have.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 07-14-2009, 08:27 AM
Jerry Garcia Jerry Garcia is offline
Mein Auto: 1997 328
Great idea to color code these pins!
Old 07-14-2009, 06:04 PM
QSilver7's Avatar
Thanks...I got to the point (age ) where I couldnt read the digits next to the pins any longer...I had to call one of the kids over that was playing in the neighborhood to read the numbers for me a few years ago...that's when I got the idea to paint the correct holes so that they could easily be identified.
(SOLD)
Old 03-04-2014, 08:16 PM
HeliBarney HeliBarney is offline
Mein Auto: '02 540iT Wagon
Inadvertently switched outside temperature reading to Celsius from Fahrenheit
during the service intervalI accidentally switched the outside temperature reading from Fahrenheit to Celsius. Whoops. Anyone know how to reverse that?
Old 03-05-2014, 11:59 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
It's 2014...seriously, you don't know how to use Google search engine?
Okay, first one on me:
http://www.bimmerfest.com/forums/sho...d.php?t=263450
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 03-05-2014, 12:37 PM
I know, I know! Sorry about that. I was being lazy, and I really appreciate the help. I was on my phone, it was dark and I was tired - and sometimes those searches lead to a lot of useless info. Won't happen again!
