Old 07-08-2009, 03:38 PM
bigrdogr bigrdogr is offline
Mein Auto: 2001 740i
01 740i - ATF for power steering fluid
I have read several posts here and it seems as if my cap says ATF on it then I am supposed to replace the fluid with synthetic ATF fluid. Does that sound correct? Is Mobil a good solution or should I go to the dealership for BMW label?
Old 07-08-2009, 06:35 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
I use atf fluid...castrol for foreign/import vehicles i think
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 07-08-2009, 06:48 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Power steering - ATF
Any Dexron/Mercon III ATF will do for the power steering if the car does not have self leveling (and the cap says ATF).
Power steering - Pentosin CHF 11S
If your car had self leveling, you would use Pentosin instead, and it would say so on the cap.
Note, the E38 automatic transmission does not use ATF. It uses Esso LT 71141 or an equivalent.
Examples:
(Manual photo from Q)
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 02-12-2011, 04:51 PM
clonefourteen clonefourteen is offline
Mein Auto: 2001 bmw 740il e38
How can I tell if my power steering pump is a "self leveling pump" or not? there are two systems, thanks.
Old 03-27-2011, 06:46 PM
Ezzyme Ezzyme is offline
Mein Auto: 1999 740i
"Take to dealer to top off ATF fluid"
What's up with that. What secret is the manual talking about. Can anyone explain the tricky stuff the dealer does when topping off ATF power steering fluid? The manual won't even let us in on the exact kind we should us.
Old 09-17-2014, 05:33 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
As above, if the fluid reservoir says CHF 11S on it then you will have the combined power steering and self levelling pump, referred to as a tandem pump. The reservoir is common to both systems.
HTML code is Off
