Old 08-18-2003, 10:38 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
Fluidyne Radiator
Anyone install one of these yet. I'm not sure if it will "bolt-in" our cars. I see it listed for all E36 6 cyl cars. not sure if thats us also.
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 08-18-2003, 11:08 AM
A Clean Windshield
Hose ID?
The fluidyne radiator is advertised for the E36 6 cyl cars.. The manufacturer thinks the size is an almost sure thing for the M Coupe. But the Hose size is a question. Fluidyne thinks our inlet and outlet are 1 5/8", The radiator has 1 1/2" fittings.
Looking at the parts list I see the drivers side hose is the same p/n as the M3. But the passenger side is different.
The coupling flange (the part that holds thermostat/ is plastic and many of us replace this part with the alumnium one) is the same p/n for both M3 and M coupe ( 11-53-1-722-531) , so I would think the hose sizes must be the same on both cars.
This radiator would be a nice replacement for ours when they die and also would surely lower the temp some.
What is the inside diameter of our radiator hoses?
1 1/2" or 1 5/8"
Old 08-18-2003, 05:35 PM
Rex Tener Rex Tener is offline
Mein Auto: S54 M Coupe, S65 M3 Sedan
Four options for radiators
[QUOTE=bob lindquist]The fluidyne radiator is advertised for the E36 6 cyl cars.. The manufacturer thinks the size is an almost sure thing for the M Coupe.[QUOTE]
It looks like there are serveral options for E36 M3 and M Coupe and Roadsters with S50/S52/S54.
Fluidyne all aluminum
PWR all aluminum
Zionsville Autosport all aluminum
BMW S54 17-11-2-227-281
On my next E36 M3 I will probably retrofit the S54 radiator and oil cooler to it.
Rex
Old 08-20-2003, 08:34 AM
A Clean Windshield
Write up coming
Ok its a done deal Fluidyne radiator is due here today. I will do a photo and write up thing as the project progreses.
I would like to accurately measure the water temp in the stock radiator before the swap. How would the easiest and most accurate way be to measure the temp?
I could buy a s/w water gauge and screw it in temporarly somewhere. any suggestions?
Old 08-20-2003, 09:06 AM
Randy Forbes's Avatar
Investigative Tinkerer
A couple of thoughts here...
Is there a drain plug on the bottom of the radiator(s)? A temperature sensor could be installed there temporarily or pemanantly.
An infrared temp gun is useful to see the temperature change as the coolant flows through the core (I've used them to identify blockages in stationary engine cooling systems). It would be hard to do comparison tests on different radiators though under varying conditions.
Randy Forbes
2001///M Rdstr Steel Gray
Old 08-20-2003, 10:16 AM
A Clean Windshield
Yes
The Fluidyne has all the same connections as the stock one. I just received it! Very nice work. There appear to be all the same threaded connections as the factory unit.
I understand the water temp gauge in our cars is some kind of computer analyzed generalization, rather that a linear reading. This is why I thought of using a gauge with actual degreed readings would be good to get some sort of baseline.
Anyone have a gauge to loan?
Old 08-20-2003, 11:15 AM
M Power M Power is offline
Send a message via AIM to M Power
Mein Auto: 2008 X5 4.8i
This is something I had in my mind, getting a high flow radiator in place of my stock one.
I wonder if Fluidyne model flows better than stock S54's radiator? Better yet, I wonder if radiator for my 2001 S54 M Roadster is the same as S54 M Roadster/Coupes?
Anyone?
Thanks.
2011 X3 35i
2008 X5 4.8i
2003 330xi -sold-
2001 X5 4.4i -sold-
2001 M5 -sold-
2001 M Roadster (SCed, Highly modified) -sold-
2000 M Roadster -sold-
1995 325is -sold-
Old 09-01-2003, 02:24 PM
A Clean Windshield
Shots of radiator
Fluidyne
ID:	18818   Click image for larger version
ID:	18819   Click image for larger version
Old 09-10-2003, 10:21 AM
A Clean Windshield
Hose fit
I checked the samco silicone hose fit on the fluidyne. Very nice. Much better that the stock hoses.
Old 09-13-2003, 06:36 PM
adam p adam p is offline
Mein Auto: 2k mcoupe
Any pic of it installed?? I really want to make this move as well but I want to make sure it will not interfer with my AA SC and a few other bits!
Thanks,
Adam P..
Old 09-16-2003, 12:28 PM
A Clean Windshield
On Hold
Thanks,
Adam P..
Haven't gotten to the project yet,as I am going to install the Oil cooler at the same time. I havent worked out all thoses issues.
Old 09-16-2003, 12:33 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
Bob
Please take pic's of the install if you have time
max
