E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Changing water valve........
Anything to watch out for when changing the water valve (heater control valve)? Looks fairly simple, couple of hose clamps and an electrical connection. Is their any chance of getting an air lock in the cooling system? If so, how can you tell and how do you fix.
Cheers Dave |
i am doing mine soon too... I would assume you need to bleed the cooling system . Hopefully someone can chime in.
-Travis-
Can anyone help with bleeding cooling system?
Cheers dave |
My guess to be safe would be to do a coolant flush. The cooling system is bled when you are SLOWLY refilling it with coolant with the bleeder screw loose.
http://www.bmw325i.net/maint_coolant_change.shtml |
I changed the valve and only lost a thimble full of coolant - started it up to operating temp and all seems ok. I now have air con that can cool as well as heat.
Cheers Dave |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
