E46 (1999 - 2006)
Old 07-16-2009, 05:24 AM
Flabbagasted Flabbagasted is offline
Mein Auto: BMW E46 318i ES
Unhappy Bmw Issue
Hi All
Im wondering if you could help me , my bmw is running fine but when i put the air con on the car jults and then a continous noise is coming from the car its a sort of low tone vibrating noise. then when i switch the air con off all goes back to normal.
If i use the fan normally it works fine the air con works fine too just makes this noise.
Thanks for your help.
Old 07-16-2009, 06:59 AM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
Hopefully it only needs a can of R-134A. If the can doesn't help, the problem could be elsewhere, and somewhat expensive to repair.
It could be your HVAC blower and the DIY is here: http://www.dvatp.com/bmw/diy/hvac_blower/
It's it is anything else more serious, you need to let a specialized mechanic to fix it.
