E30 (1982 - 1993)
Old 07-17-2009, 01:56 PM
Pennyw1se Pennyw1se is offline
Mein Auto: 1988 325e
How to Remove Window Regulator
I have a 2 door 1988 325e (build date 10/87) and need to replace the window regulator (serpentine style). I've removed the window and have removed the 3 bolts that hold the regulator onto the door. Now what?
I even loosened the whole assembly and it slides around the door frame but I can't figure out what the heck Im supposed to do to get it all out to make sure nothing is broken or how to get the actual regulator off. (I'm assuming the regulator is the piece the window motor connects to.) I cant slide it out through the opening on the bottom of the door, or at least I can't figure out how to do it without bending the assembly. Any help would be greatly appreciated. A write up with pics would be even better. I have a feeling Im missing something because some of the write ups I've seen completely skip the actual removal, as if its something that is obvious.
I actually spent almost 3 hours just trying to get a working motor onto regulator because the motor mounting screws wouldnt catch. After 3 hours of hand cramps due to the awesome design (thanks BMW!) I then find out that it wasnt the motor itself.
Old 07-17-2009, 07:59 PM
Nevermind. I knew there was something I was missing. I wasn't removing the window trim. Its all good.
Old 04-22-2016, 01:30 PM
pgelso196 pgelso196 is offline
Mein Auto: 1986 BMW 325e
Regulator stuck
I'm currently in the same scenario. What'd you end up doing to get the regulator out? I can't even access the bolts to detach the regulator from the window itself. Thanks.
Patrick
Old 07-17-2016, 04:57 PM
JMarchione JMarchione is offline
Mein Auto: 2007 #93 335i
I too am in this situation. Please help!
Old 07-17-2016, 07:23 PM
Solved
So what you need to do is remove all of the bolts that attach the regulator to the door and then remove the chrome strip that sits next to the glass on top of the door panel. Then there is enough room in the opening where the window comes through to remove everything.
Old 07-17-2016, 10:31 PM
thanks!
