E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
code read..car stall
When I turn on the car, it start and then the rpm drop to 0 and stall. Check engine light is on. So, I check the code using the INPA software. IT turns out..there are 4 errors....all of them are:
90 TEG_up_1 N_32 672 rpm MAF 119.84mg/stk TCO 97.5 Grad C V_TEG 0.02v and also the other code called 92 TEG_down_1 What does TEG_up and down mean? I have cleaned the MAF IAC and throttle body....the car gains power back to normal...however, the stall still happens sometime.....but not all the times... |
What's INPA software? Use a standard ODB2 reader and give us a Pxxxx code...
I will try to get the PXXX code .....
I did try goggle on TEG_up or down...but nothing come up in english.. only come up in other lang. I cant read......hope someone can help and read it.. thanks ray |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
