Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 07-18-2009, 09:56 AM
Kurt_OH's Avatar
Kurt_OH Kurt_OH is offline
First Timer
Mein Auto: Me: M3; Her: 335i
Coupe vs. Sedan, weights
In the 335i, there is 23lbs difference between coupe and sedan.
In the M3, there is 22lbs.
Seems to me that:
1. Coupes should have a GREATER weight advantage generally
2. M3 coupe should have GREATER weight advantage than 335, or what the heck is the point with that roof?
Separately, why does the BMW web site list the M3 as sitting almost 2" taller than the 335? Does that seem odd to anyone else here? Is that correct?
Not here to kick the M3: I LOVE them, and want one. Wife has 335i now, which is a very nice car.
Originally Posted by PhillyNate
I just love how a 4 year old car/design is STILL the benchmark which other automakers aspire to reach. Still winning comparisons . Still very much in the conversation. Is the E9x M3 a legend? You bet your @ss it is.
Old 07-18-2009, 10:05 AM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
M3 is higher? Hmmm does seem odd. Others will know more because I don't have either of those cars (yet).
I do know the "Supreme special edition M3 cars supposedly in production for 6 months and avilable in the US this month is .4 inches (metric and inches?) lower than other M3 cars.
Old 07-19-2009, 12:57 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Seems to me that:
Why? E46 sedan weighs less than the coupe, and the body is stiffer as well.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 07-19-2009, 08:48 PM
CliffJumper CliffJumper is offline
Mein Auto: '15 Audi S4
G35 Sedan weighs less than G35 coupe (at least in 2004).
M3 is taller than a 335. I park my M3 next my gf's 335 sport pack (both sedans) regularly, and my car is definitely taller. With the bulging fenders, 19" wheels and bright blue color, my car looks like a caricature of her car...
Old 07-20-2009, 04:00 AM
Kurt_OH's Avatar
First Timer
Why? It's just a thought or sense of the purpose, in my thinking. A coupe is more focused on sportiness; sedan = "and my family".
Seems the sport focused would attempt to reduce the greatest enemy to sportiness: weight. Also, two less doors/hinges/frames.
That's it.
I also do NOT get why the c/f roof is in there?! Why does an M3 coupe weight closer to/greater than a sedan than other E9x 3 series? I presume it does, since WITH the CF roof the coupe/sedan diff. is about the same as other 3 series.
Old 07-20-2009, 04:50 AM
Dave 330i's Avatar
Mein Auto:
That's it.
The B piller gives the sedan greater stiffness. You know chassis stiffness gives a better sense of control in corners. The coupe's door is exeptional longer and shuts with less precision. Next time when you are in the dealer test shutting both the coupe and the sedan's doors and then tell me which car feels more solid. Granted, the coupe looks more sporty. Given a choice for a M3 coupe or sedan, the coupe would be my choice, but the sedan's chassis stiffer.
Old 07-20-2009, 07:46 AM
TLudwig's Avatar
TLudwig TLudwig is offline
Stuck in Monday
Mein Auto: 2009 M3
The sedan is indeed slightly stiffer, but you'd never notice it unless you're an experienced driver taking a hard turn/corner on uneven pavement. I actually noticed the difference much more in the E46 than in the E9X.
FWIW, coupe doors never feel as "solid" as their sedan counterparts when shutting, but it doesn't always mean that the sedan has greater chassis rigidity.
2009 Interlagos Blue E92 M3 (Sold)
2004 Silver Gray 330Ci ZHP (Sold)
Old 07-20-2009, 08:12 AM
Dave 330i's Avatar
Mein Auto:
The shear fact that the B piller is there increases overall stiffness. The coupe's stiffness is only slightly better than the converitble.
Old 07-20-2009, 09:39 AM
elp_jc elp_jc is offline
Mein Auto: '08 E92 M3 6MT
The coupe has a B pillar too man; where the heck do you think the seat belts are anchored? It's not visible from the outside for styling reasons, but it's there (behind the glass). If sedan is stiffer (doubt it), it'd be insignificantly so. Coupe is longer though, so probably about the same weight as a sedan with sunroof IMO, and a bit lighter without. If you're anal about that, there should be detailed weight stats somewhere (car mags with calibrated scales are your best bet for accuracy).
'08 E92 M3 6MT, SSII/Black (moonroof), all options. MODS: black OEM muffler, ultimate aluminum pedals,
OEM black grilles, body-color gills, reflector delete, euro light switch, tint, black OEM 19s, ZHP lighted knob
Old 07-20-2009, 09:46 AM
TLudwig's Avatar
Stuck in Monday
Mein Auto: 2009 M3
Originally Posted by elp_jc View Post
The coupe has a B pillar too man; where the heck do you think the seat belts are anchored? It's not visible from the outside for styling reasons, but it's there (behind the glass). If sedan is stiffer (doubt it), it'd be insignificantly so. Coupe is longer though, so probably about the same weight as a sedan with sunroof.
Yes, the coupe does have a B-pillar, but the longer coupe door pushes it further back. Throughout the 3-series' history, the sedan frame has always been slightly stiffer than the coupe.
Old 07-20-2009, 04:17 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
The point of a carbon roof is also to help lower the center of gravity by dropping the weight at the highest level of the car.
Old 07-20-2009, 04:27 PM
That makes sense. Plus it's shorter too. Take care.
Old 07-20-2009, 05:45 PM
Kurt_OH's Avatar
First Timer
Yea, by REMOVING the weight. I presume they don't take the metal out of the roof and add it to the floor!? :-)
The chassis stiffness is a valid comment that I've read elsewhere also; that and aerodynamics allegedly make the sedan the faster of the two in pretty much any speed competition. However, what I was asking is why the two vehicles' weights are so close, and what do they do to the M3 coupe so that even WITH a CF roof, it's STILL the same number of LBs different than the sedan - in other words, the M3 coupe with a steel roof would likely OUTWEIGH the sedan!?
Old 07-20-2009, 07:05 PM
TLudwig's Avatar
Stuck in Monday
Mein Auto: 2009 M3
Kurt, it's difficult to say where the "extra" weight comes from. The coupe is 1.5" longer (all in the C-pillar/trunk area), but the sedan is almost 1.5" taller. The coupe may have more structural reinforcement to make up some of the chassis stiffness.
Interestingly, the coupe has closer to a 50/50 weight distribution, likely due to the longer tail end.
Old 07-20-2009, 08:59 PM
Kurt_OH's Avatar
First Timer
I also still don't "get" why the M3 is TALLER than the 335?! That one REALLY scrambles my brain.
Taller, heavier (even with an allegedly lighter than prior 6cyl engine) than 335 . . .
NOT that an M3 isn't clearly more desirable - I would love to have one, and would gladly swap our 335 for one tonight (uh, minus the $30k+ price diff between my used 335 and a new M3).
I'm just trying to learn/understand where the height and weight are coming from?!
Old 07-22-2009, 04:19 PM
Dave 330i's Avatar
Mein Auto:
I couldn't resist. It's the bigger brother? If you don't shut up, I'm going to beat the crap out of ya.
Old 07-22-2009, 04:31 PM
NetSpySD's Avatar
NetSpySD NetSpySD is offline
Mein Auto: 2008 X6 xDrive3.5
The M3 comes with 18" tires standard where the 335 comes with 17".
Coupled that with the M3 having a different suspension.
The M3 sedan is 57" tall, the 335 sedan is 55.3. That is 1.7" difference, minus the tire size and your are at 1.2 inches. Again this could be the height with dampening control included, who knows? No big whoop either way. for all we know, the web site is a typo.
2008 X6 xDrive 3.5
Old 07-24-2009, 02:33 PM
Kayani_1 Kayani_1 is offline
Account closed at users request
Mein Auto: Graphite & Silver E92/E60
The M5 is taller then 530i and M6 is taller then non-sport 650i and so is the M3 taller then 335i. It is all because of the fact that M cars have bigger wheels + tires compared to regular standard versions of 3er, 5er, and 6er.
Old 07-25-2009, 08:47 AM
Dave 330i's Avatar
Mein Auto:
Without taking sagging due to extra weight of tire pressure, compare stock tires and wheels.
1st 2nd 3rd group below 225/45-18, 245/40-18, 265/40-18 respectively. Diamerter =Circumference/Pie
24.98" (stock 335i coupe) 25.72" (M3 fronts) 26.35" (M3 rears). Average out the front and rear of M3 = 26.04"
Difference in height between 335i coupe and M3 coupe is 26.04-24.98=1.05"
Stock Tire - 225/45R17 >Search Tires Tire 1 - 245/40R18 >Search Tires Tire 2 - 265/40R18 >Search Tires
Section Width: 8.85 in 225 mm
Section Width: 9.64 in 245 mm
Section Width: 10.43 in 265 mm
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7 - 8.5 in
Rim Width Range: 8 - 9.5 in
Rim Width Range: 9 - 10.5 in
Overall Diameter: 24.97 in 634.23 mm
Overall Diameter: 25.71 in 653.03 mm
Overall Diameter: 26.34 in 669.03 mm
Sidewall Height: 3.98 in 101.09 mm
Sidewall Height: 3.85 in 97.79 mm
Sidewall Height: 4.17 in 105.91 mm
Radius: 12.48 in 316.99 mm
Radius: 12.85 in 326.39 mm
Radius: 13.17 in 334.51 mm
Circumference: 78.44 in 1992.3 mm
Circumference: 80.77 in 2051.5 mm
Circumference: 82.74 in 2101.5 mm
Revs per Mile: 832.9
Revs per Mile: 809.0
Revs per Mile: 789.6
Actual Speed: 60 mph 100 km/h
Speedometer1: 58.2 mph 97.1 km/h
Speedometer1: 56.8 mph 94.8 km/h
Speedometer Difference: - Speedometer Difference: 2.954% too slow Speedometer Difference: 5.483% too slow
Diameter Difference: - Diameter Difference: 2.88% Diameter Difference: 5.21%
Old 07-25-2009, 09:47 AM
Difference in height would be HALF the overall diameter difference buddy, as the other half just reduces fender gap (wheels are attached in the middle, not at one end). Makes sense????
I'm sure speedo was recalibrated for the M3 as my error is 3.7%, which is perfectly normal, but if not, it'd be the difference in circumference between rear tires. Take care.
Old 07-25-2009, 11:22 AM
Dave 330i's Avatar
Mein Auto:
My bad. I got the right approach, but wrong answer, can't fault that in a physic exam.
Old 07-26-2009, 05:06 AM
NetSpySD's Avatar
The M3 is taller so when the potential customer is on the lot comparing the M3 to the 335 and asks why the M3 costs so much more, the dealer can say because it is taller.
2008 X6 xDrive 3.5
Old 07-26-2009, 05:08 AM
Dave 330i's Avatar
Mein Auto:
and weighs more. And, in the sedan, you get two free doors.
Old 07-26-2009, 05:31 AM
ffej's Avatar
ffej ffej is offline
Tightrope walking
Mein Auto: Jackwagon!
Why are we arguing the merits of 22lbs difference on a car that weighs almost 2 tons, again?
Building a ZHP wagon... click the pic!!!
Because BMW wouldn't do it for me
For Sale - HUGE part out of 2005 ZHP sedan
Originally Posted by KrisL View Post
My input is that ffej knows what he's talking about .
Old 07-27-2009, 07:17 PM
Kurt_OH's Avatar
First Timer
1. It ISN'T about 22lbs. It's about why the coupe isn't 200lbs lighter. Isn't the coupe SUPPOSED to BE sportier? Or is it just LOOK sportier, but BE slower (which it is)?
2. It is ALSO about if the LB diff between coupe and sedan on 335 is 22lbs, then if the M3 coupe has a carbon roof, then shouldn't the LB diff on M3 coupe vs sedan be GREATER than the LB diff on 335 (no carbon roof on coupe)?!
3. If you don't think 1.7" matters, perhaps you should read all the crap put out by auto manufacturers about 10mm ride height reductions with their multi-thousand dollar sport suspensions. It matters a BUNCH. That's ~3% reduction in height and corresponding CG reduction.
