Removing 91 E30 Airbag Steering wheel with ignition lock on - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 07-26-2009, 08:59 AM
BlackBMWs's Avatar
BlackBMWs BlackBMWs is offline
Check twice, fix once...
Mein Auto: 540it 533i 318ic 325i
Sharing a fun experience in removing a E30 steering wheel with an airbag from a local Pick n Pull. I needed a replacement steering wheel w/airbag for my 91 E30 Vert. I came across a donor with a perfect replacement wheel, but there was no ignition key in it to unlock the steering column lock.
I received feeback that I had to disengage (break) the lock to get the steering wheel off.
I did see other E30's with mangled M-tech type steering wheels from folks who wanted the steering wheels who also had trouble with the pins.
What I thought would be a 30 minute removal turned out to be hours in the hot, Sacramento sun...
Tools I ended up using, plus a 16mm wrench for the steering wheel puller, some WD-40, a rubber mallet, vice grips and 2 quarts of cold water. (it was really hot...)
What a PITA to get the steering lock to disengage. They wern't kidding about pounding the lock. I started with a 2lb hard rubber mallet ended up with a 4lb hammer and two screwdrivers.
I improvised to pull the steering wheel off the spline. The car I was pulling the steering wheel from had no seats. (Read no leverage)
Here's the metal pin that holds the steering wheel from turning or being released. I ended punching the back if the lock cylinder through the back of the lock housing, then got some vice grips on the shaft that turns the electric switch and spun the cylinder enough to disengage the metal pin.
Here's what I did with my hammer and screwdrivers.
$40 bucks for the steering wheel and airbag. Actually in really good shape. It'll be an improvement from my current wheel as the rubber has separated from the underlying metal frame and feels like a sponge. Not sure it was worth the time though in the 104 degree heat for a few hours... Anyway, it got down to not letting the lock beat me...
Lesson learned: ebay next time...
1999 540it - Jet Black/Sand Beige, style 5 rims, Zionsville Cooling kit
1984 533i - Schwarz/Schwarz, 17" style 65 reps
1997 318ti Sport - Schwartz II/Schwartz Anthratz, style 68 rims
1995 318ti Sport - Schwartz II/Schwartz Anthratz, style 27 rims
1994 325i Sedan - Bostongrau/Tan
1991 318ic - Schwarz/Anthratz Stoff
1985 635CSI - Schwartz\Sand - Sold
1984 318i - Champagne/Tan, Stock - Sold
BMWCCA# 160411
Old 08-21-2009, 02:27 AM
scotte36's Avatar
scotte36 scotte36 is offline
Mein Auto: 325i
why did you have to havve the steering unlocked to remove the wheel?
Old 08-21-2009, 02:40 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
it doesnt come off without the steering lock disengauged. its like that in all cars.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 08-21-2009, 11:45 AM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 08-21-2009, 09:56 PM
scotte36's Avatar
Mein Auto: 325i
Old 08-21-2009, 10:30 PM
BlackBMWs's Avatar
So, on the E28 and E30 models there is a locking pin when the ignition is in position '0'. The pin retracts when you turn the ignition to position '1' or '2'. In the photo, the pin is 3/4 in the down position.
When this metal pin is up or in the locked position, it prevents the wheel from turning or pulling loose from the hub.
Normally, to remove the steering wheel, you just remove the pad as you describe, remove the center nut and put the ignition key in and turn to Position 1 to retract the pin. At that point, if the wheel is loosened from the shaft spline, you just pull it straight off. With the pin up, it wont move more than 1/4" off the shaft.
So, the steering wheel I was pulling off was in a local salvage yard. In the salvage yard, none of the cars have ignition keys in them so they are typically locked. Defeating the lock retracts the pin.
If you pulled the steering wheel off with the pin up, I (and others) would sure would learn from you as to how you did it.
BMWCCA# 160411
Old 08-21-2009, 11:02 PM
scotte36's Avatar
Mein Auto: 325i
Old 08-21-2009, 11:09 PM
scotte36's Avatar
Mein Auto: 325i
dunno mabe mine is stuffed to start with lol.
i just undone the two screws on the back of the wheel,lifted it up,unplugged the airbag,undone the bolt on the spline and pulled the wheel off.
however i did break the little white plastic thing on the spring @ 2 o'clock,luckily i dont need it with the new wheel i am putting on .
mine is an E36 325i dunno if that matters or not,according to a previous post they are all the same.
Old 08-21-2009, 11:25 PM
BlackBMWs's Avatar
I've read some cars have plastic pins instead of the metal pins. In those cases, folks have turned the wheels hard left or right to break the pin, then pulled the wheel off.
Unfortunately, all the ones i've come across has had metal pins.
BMWCCA# 160411
Old 08-22-2009, 10:01 PM
scotte36's Avatar
Mein Auto: 325i
Originally Posted by anstead610 View Post
someones easily amused....small things amuse small minds
Old 10-09-2009, 09:06 AM
Andries Andries is offline
Mein Auto: E30 318i
E30 ignition lock removal
Hi guys
Just became a member, checking out many useful tips/tricks etc...loving it!
Have a problem with my 318i E30.
Someone tried to steal my car, screwing up my ignition lock, does any one know how to take off the steering column panels without removing the steering wheel itself (or braking the panels)
I have removed all the screws/nuts but some plastic "tabs" extend behind into the steering wheel, do they need some encouragement or has the steering wheel need to come off..
I can apparently get the car started if i remove the ignition lock witch reveals a basic "turning" switch. And get the ignition lock repaired or replaced.
Andries
Old 03-12-2015, 07:54 AM
greasyhands greasyhands is offline
Mein Auto: '91 325iC
Hey guys just a quick tip,
I was in the same place yesterday: at a yard w no ignition keys.
Try putting your own key in the ignition. I put my E30 keys in this car in the lot and voila! It worked. The wheel turned and slid right off.
Might save you a couple hours, but won't always work.
Hope that helps someone
