E28 (1982 - 1988)
e 28 HELP ASAP
I need help with the torque specs and the head bolt sequence ASAP PLEASE HELP
thanks steve |
for got to say it was a 1983 528E \
sorry |
What kind of head bolts are you using?
I can tell you in the morning sorry I can not help now. Andy |
what do you mean
i think there 5/16 torques bolts idk the manufacture but i can wait till morning |
Hi the reason that I asked about the bolts was because there are 2 different kinds. One is Torx head bolts and the other is hex head bolts and the torques are different. Also if you are putting the head back on youhave to tighten the bolts in a certain order or bad things can happen.
The order of tightening is as you are looking down at the head on the passenger side. 12 10 4 2 6 8 14 13 7 5 1 3 9 11 This is for torz head bolts, it can be done with the engine being cold and there is no time that you have to wait until you do the next stage. Stage one 22 ft-lb Stage two 90 degrees Stage Three 90 degrees This is for hex-head bolts Stage one 29+4 ft-lb Then wait 15 minutes Stage 2 44+4 ft-lb the run the engine until fully warm(about 25 minutes) Stage 3 25+5 degrees I hope this helps. Andy |
By the way where are you located in Ohio
Andy |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
