E30 (1982 - 1993)
Old 08-01-2009, 10:07 AM
Robbovius Robbovius is offline
Mein Auto: 1988 325e
Broken Hood Latch Cable.
MY son snapped the hood latch cable on his '88 E30. I spent some time this morning under neath nd peering theu the grille, but can't seem to locate a way to undo the hood latch from outside. I know I'm probably just missing something obvious, but I'd sure be appreciative if somebody could let me know hos to get the hood open fromthe outside.
thanks
Robb
Old 08-01-2009, 10:42 AM
533-3.8 533-3.8 is offline
Mein Auto: 1988 325ix '88 325ix
you can access the lock mechanism behind the driver's side light. The two bolts to the left hold the lock. Take the clips off the top of the plastic light grill and the two screws toward the bottom. It may be difficult getting the top clips off without the hood open but take the screws out and gently pry down on the top.
Old 08-01-2009, 10:47 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Use a flashlight to locate the latch on the driver's side behind the grille. Take a long flat blade screwdriver. Insert it between the fins in the grille, into the opening in the front of the hood latch and turn. may take a couple of tries at first, but it'll pop open.
You don't have to remove the grille.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 08-02-2009, 12:35 PM
Thanks!!! I have just the monster flat blade fior the job.
Old 08-02-2009, 12:51 PM
zklug1013 zklug1013 is offline
labatt blue E30
Mein Auto: 87 325e
Mine is broken as well but the hood is open and the handle broke from the inside. rocking the vice grips lol
Carbon nanotubes will solve it all.
Old 08-05-2009, 10:51 AM
estebanayala estebanayala is offline
Send a message via AIM to estebanayala
Mein Auto: 1987 BMW 325e
any way to replace this or to put tension back in the line without buying a new latch?
Old 08-05-2009, 10:58 AM
jleon426 jleon426 is offline
e30 project
Send a message via MSN to jleon426 Send a message via Yahoo to jleon426
Mein Auto: lokking for an e30
you dont need a new latch when my cable snap i just when to the junk yard and got a cable it took me like 20 min to replace it
Old 08-05-2009, 03:27 PM
ramius ramius is offline
Mein Auto: 1989 BMW 325i
make sure your cable is actually snapped. Take the hood opening mechanism (inside the car) off (2 bolts) and see if it is still attached. Mine was just stretched or part of the mechanism was shot. now I just leave it dangling and give it a good pull and she opens up just fine.
Old 08-05-2009, 06:42 PM
labatt blue E30
Mein Auto: 87 325e
the ball snapped off mine (where the cable is attached too the handle) so i think i will just replace the cable instead of rigging it.
