Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-03-2009, 10:24 AM
jaybird535i jaybird535i is offline
Mein Auto: 1985 535i
the hose on the back of the reserve tank
where the does the little hose on the back of the reserve tank connect to?
mine bri=oke and was leaking fluid but i cant see where the hose connects to? please help
1985 bmw 535i
Old 08-03-2009, 10:49 AM
south26 south26 is offline
Mein Auto: 535i 1989
That is over flow show it will leak when there is to much fluid.
Andy
Old 08-03-2009, 12:26 PM
so it dosent connect to anything? because when it broke it leaked all the fluid out of the tank untill it was empty
Old 08-03-2009, 04:21 PM
That small hose, that one connects to the top of the radiator on the drivers side. it is right next to the big hose that is on top.
Andy
Old 08-06-2009, 09:00 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
If you are talking about the cooling system expansion tank, it has two hose connections: the one facing to the front connects to the radiator top side and the back one is the pressure bleeder hose. If the front one broke off you will need a new expansion tank. The one on the back shouldn't be leaking coolant at all times. If you do your radiator cap is bad so replace it.
Jimmy Moreno
1995 530i
1986 535i
Old 08-06-2009, 01:50 PM
Hi, i have a good expansion tank which includes a good cap, for 24 shipped.
Andy
HTML code is Off
