Old 08-08-2009, 08:25 AM
bspon bspon is offline
Bill
Mein Auto: 2009 335i Convertible
Alarm/Panic Button
(335i 09 Vert) I didn't order a car alarm, but I have the red light below the interior rear view mirror. Do all the new cars come this way, which I assume is a "pre-wire" package?
If it is prewired, what would it entail to have it activated?
Also, I was wondering if there is a way to remotely activate the car horn as a panic button. A lot of cars have this feature. Is there another secret I haven't discovered yet?
Man, every day is a new adventure with this machine!
Old 08-08-2009, 08:29 AM
GinoDotCom's Avatar
GinoDotCom GinoDotCom is offline
Officially a BMW Homer.
Mein Auto: 2008 335i
There's a DIY to activate the Clown Nose. I think it's over at e90Post
335i JB4 6MT: Goes from 0-60 in the time it took you to read this.
SSTT turbo chip for sale in the Classifieds
Old 08-08-2009, 08:30 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
^ Yup
BMW ripped off 3 series owners with no alarm.
Old 08-08-2009, 09:49 AM
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
We all have the clown nose that doesn't work, unfortunately, unless you purchase the alarm. A lot of the cars come pre-wired for one, but you have to purchase the alarm yourself and have it installed. I have a 2009 and my car is pre-wired for an alarm No panic button unless you have the alarm installed!!
Sig by Solidjake
2009 335i Coupe, Titanium Silver Metallic, Coral Red Dakota Leather, Gray Poplar trim, Premium package and Sports package with 19s.
Previously Owned: 2006 Audi A4 S-Line Quattro with all the belles and whistles and a B5 Imola Yellow Audi S4
Old 08-08-2009, 12:16 PM
neapolitan neapolitan is offline
Insert T I T L E here
Mein Auto: BMW e90
Q: Why do BMW keyfobs not have a panic button?
A: BMW drivers never panic.
Old 08-08-2009, 12:22 PM
Solidjake's Avatar
Zero. Leaks.
Old 08-08-2009, 12:38 PM
Oulixes's Avatar
Oulixes Oulixes is offline
Mein Auto: 330xi, 335i
q: Why do bmw keyfobs not have a panic button?
A: Bmw drivers never panic.
+1
Old 08-08-2009, 03:53 PM
e60lover's Avatar
e60lover e60lover is offline
Mein Auto: 335i, 535i
The panic function is activated by holding down the trunk/roundel button for an extended period of time considering you have the alarm option installed.
2011 535i- Sophisto Grey/Dark Graphite, cinnamon, dark wood, sport automatic, premium I/II, sport package, convenience package, top/side view cameras, split fold rear seat
2011 335i Coupe M-Sport- Alpine White/Saddle, dark glacier aluminum, premium package, harmon kardon, heated seats, BMW apps
Old 08-08-2009, 08:52 PM
oilfighter oilfighter is offline
Mein Auto: Car
How does one find out that the car is pre-wired for alarm?
Old 08-09-2009, 03:14 AM
BerfsBimmer's Avatar
BerfsBimmer BerfsBimmer is offline
Boosted Bavarian
Mein Auto: '08 335Ci
When was your car manufactured? The mid '09 production changes came sometime towards the end of March '09. They no longer pre-wired the car for an alarm and made it a factory option. Also, the ashtray and lighter with a flip cover was replaced by a storage bin.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=93468&dateline=1203123566
'08 E92 SpaceGray/Gray/Burl/ZSP/ZPP/ZCW/Step/Nav/CA/6FL/HD/Original HPFP
Old 08-09-2009, 05:59 AM
Northcar Northcar is offline
Mein Auto: 435i F33 M Sport Verte
I believe this practice is called decontenting. Mercedes did it with the E Class just after I purchased mine when they dropped the puddle lamps that lit the ground below the side mirrors and did away with the cooling feature in the center console. Sometimes older is better.
Old 08-09-2009, 07:04 AM
Bill
Thank again for the replies. My car came without the ashtray/lighter so it probably isn't prewired for alarm either. It was a March build. Good one about "BMW owners don't panic"..In my case, I'm "not alarmed" either.
Old 08-09-2009, 08:36 AM
Barmats Barmats is offline
Mein Auto: 2015 X5 50i
The DIY is a self-powered flasher circuit that will light up the clown-nose LED. It gives the appearance that you paid several hundred dollars for the optional OEM alarm, when in fact you only spent a few bucks for the parts. Here is the DIY from e90post:
http://www.e90post.com/forums/showth...ght=clown+nose
I considered doing this, but ended up spending the $500 for the alarm and activation. I have an E93, so I figured that having an alarm that actually worked wouldn't hurt. But it was expensive, and this is the only car I've owned in the past 10 years or so that didn't come with the alarm as standard equipment. It's also the most expensive car I've ever bought. Go figure.
Old 08-09-2009, 08:45 AM
hommedefromage hommedefromage is offline
Mein Auto: 135 Cabrio
Sleep Mode versus Battery Disconnect
I've got the alarm kit to retrofit into my E93 and accessing the battery is a supreme pain. Can I put the car into sleep mode instead of disconnecting the negative cable when I install the siren/tilt sensor unit?
Gary
Old 08-09-2009, 09:06 AM
I feel your pain... the E93 is built around the battery, and although I persisted (when I installed my M3 wheel w/DCT paddles), it was a supreme PITA. The sleep mode can be accessed by leaving the doors open for about 20 minutes. From what I've read, it should remain in sleep mode until the doors are closed again, but I'm not 100% sure. I would test with a voltmeter from a known hot 12vdc source to be absolutely sure the power is off.
