Old 08-13-2009, 04:17 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
S52 Guys - Which Oils?
Which brand, type (dino or synth) and viscosity are you running in your crankcase, gearbox and diff?
TIA,
Mark
I Timothy 2:1-2
Old 08-13-2009, 04:22 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Wink Utsf
Do a search; this subject has been discussed to death
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 08-13-2009, 04:39 PM
an audience of One
Haha, yeah, I could have done that
I Timothy 2:1-2
Old 08-14-2009, 02:52 AM
///McQ ///McQ is offline
Addicted
Send a message via AIM to ///McQ Send a message via Yahoo to ///McQ
Mein Auto: 2000 M Roadster
That appears to be for the S54 engine. What about S52, as the OP requested?
My owner's manual suggests either synthetic or regular, and my mechanic suggests Castro 5w30, synthetic.
2000 M Roadster
1993 Miata
1999 Chevy Silverado 4x4
Old 08-14-2009, 06:16 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Your mechanic's suggestion is good.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 08-14-2009, 06:25 AM
pwrdbym pwrdbym is offline
Mein Auto: 06 Z4MR, 99 Z3 MC, 85 M6
Synthtic for sure. As for which kind.....you are going to open a can of worms on that one. Honestly there are many brands that will do just fine, Mobil 1, Castrol Syntec, Royal Purples, AMSoil, Red Line, etc....
The thing that really matters is that you change it at regular intervals, along with a quality filter. Bav Auto or ECS tuning will display oils for your car if you want some other ideas.
I have been running Royal Purple 10w-40 with no issues. My Blackstone reports are good. 5w-30 or 10w-40 will be fine depending on your climate, I don't do a lot of winter driving with the car and it is pretty hot in OK most of the year, hence the higher viscosity.
99 Z3M Coupe
06 Z4M Roadster (1 of 1)
85 M635CSI (Euro)
91 850i 6MT
97 M3 Coupe (Track)
13 Chrysler 300C V8 AWD
14 Jeep Grand Cherokee Diesel
Old 08-14-2009, 09:41 AM
elfhearse's Avatar
elfhearse elfhearse is offline
Mein Auto: 00Z3MC,10e91-ZMP,14e8928i
Engine: over the years I've used the BMW Syntec 5W30, Amsoil Euro 5W40, Mobil one...only BMW approved is the 0W40 (black label). Trying the Elf/Total Quartz 0W/30 next.
Gearbox: Moved on from Redline MTL, using Royal Purple Synchromax...better.
Diff: Amsoil Severe Gear 75/90
Old 08-14-2009, 11:15 AM
jmillet's Avatar
Wink Read the entire posting carefully
If you read the entire BMW NA Synthetic Engine Oils page you'll find it addresses all Bimmer engines:
The BMW NA letter is very brand and weight specific regarding approved oils and they must be LL-01 rated.
The only two other than the BMW High Performance SAE 5W-30 Synthetic Oil (BMW part number 07 51 0 017 866) that are widely available on the US market are: Castrol Syntec European Formula SAE 0W-30 (AutoZone) and Mobil 1 SAE 0W-40 (everywhere). The other two approved oils are very difficult to find in the US. The approved Pennzoil Platinum European Formula Ultra SAE 5W-30 is NOT the Pennzoil Platinum 5W-30 you commonly find on auto supply store shelves. The same applies to the approved Valvoline SynPower SAE 5W-30. The one that meets LL-01 is the Valvoline SynPower MST 5W-30 which also is not commonly found on auto supply store shelves.
Jim Millet
Old 08-14-2009, 11:19 AM
an audience of One
A good brand and readily available
Thank you for the in-depth post, I appreciate it.
Excellent, thank you.
Some history is in order: I am in the process of swapping a '99 M Coupe driveline (S52, ZF 5-speed, 3.23 finned diff, as you are well aware, I am sure) into my '87 325is. My knowledge of the S5X is limited, so that's why I am here. Thank you for sharing your insight/experience
I Timothy 2:1-2
Old 08-14-2009, 11:29 AM
updmst updmst is offline
Mein Auto: 2000 M Coupe, 1997 318ti
Jim, you are right - but that page could be better written. Everyone thinks of the S52 as an M engine. EDIT: Ok, that last sentence could have been better written. "As the S52 is an M engine, S52 owners often think they should use the 'M' oil."
The Oil page talks of two groups
1 - M vehicles equipped with S54, S62, S65 or S85 engines
2 - all other BMW Passenger vehicles and SAVs in the US market with gasoline engines
Old 08-14-2009, 12:08 PM
an audience of One
Thank you
The S52 isn't an M engine? A cammed and bored M50, is it? It seems to me the site provides documentation for MY 2004 and newer. The S14 and S38 aren't mentioned, either.
I Timothy 2:1-2
Old 08-14-2009, 02:05 PM
jmillet's Avatar
Originally Posted by markseven View Post
Thank you
The S52 and S50 are M engines, but according to BMW NA don't require the Castrol TWS 10W-60 oil.
My interpretation of the BMW NA letter is that if your gasoline engine is not specifically identified as requiring Castrol TWS 10W-60 oil then the other LL-01 oils are recommended.
Jim Millet
Old 08-14-2009, 03:02 PM
an audience of One
The S54 and S50 are M engines, but according to BMW NA don't require the Castrol TWS 10W-60 oil.
Ah, clarity thank you (you meant S52 and S50, correct?)
I Timothy 2:1-2
Old 08-14-2009, 03:14 PM
jmillet's Avatar
Red face S52 and S50
Ooops
See edited version.
Jim Millet
Old 08-14-2009, 03:28 PM
an audience of One
Ooops
See edited version.
I Timothy 2:1-2
Old 08-14-2009, 05:10 PM
Addicted
I have a PDF of the Bentley E36 Service Manual, MY 1992-98. I don't know how much info would transpose for the Z3 (E 36/7), or how much it would help with an '87 325is, but if you want a copy, shoot me a message here.
2000 M Roadster
1993 Miata
Old 08-14-2009, 06:33 PM
Oldman M Coupe's Avatar
Oldman M Coupe Oldman M Coupe is offline
Oldman M Coupe
PENTOSIN
MOTOR OIL 5W40 PENTO HIGH PERF II 5L
5L BOTTLE
502.00 / 505.00 / /505.01
Pento High Performance 5W-40 is an especially formulated fuel economy engine oil. It is based on synthetic base oils only, the most modern and best engine oil additives currently available and a very shear stable VI - Improver. The combination of these exquisite components guarantees an excellent engine performance under the most severe driving conditions. Pento High Performance 5W-40 is ideally suited as an all season engine oil. Pento High Performance 5W-40 contains a special combination of very efficient fric-tion modifiers which cause the engine to run very smoothly. Even more important, it causes fuel savings in a recognizable way.
Pento High Performance 5W-40 Typical Data Unit Result Method Appearance bright and clear visual Density at 15 C kg/m 857 DIN EN ISO 12185 Kinematic Viscosity at 100 C mm/s 13,8 DIN EN ISO 3104 Kinematic Viscosity at 40 C mm/s 86 DIN EN ISO 3104 Viscosity Index 167 DIN ISO 2909 Dynamic Viscosity at -30 C mPa*s 5900 ASTM D5293 Pour Point C -36 ISO 3016 Flash Point C 220 DIN EN ISO 2592
( Compatible with OEM part number: MO5W40HP25 / MO5W40HP25 )
List Price: $58.53 :: Impex Price: $39.06
Old 08-16-2009, 12:11 AM
an audience of One
Originally Posted by Oldman M Coupe View Post
PENTOSIN
5L BOTTLE
Thank you, sir
I Timothy 2:1-2
Old 08-16-2009, 04:33 PM
an audience of One
Another question: Was this the official recommendation prior to BMW invoking the life-time fill policy and the coincidental implementation of their free maintenance program?
I Timothy 2:1-2
Old 08-16-2009, 06:32 PM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
http://www.bimmerfest.com/forums/sho...&highlight=oil
yes we did beat this one to death a few times.
for the S52
bmw or mobil1 0-40 were the most popular
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 08-18-2009, 10:50 AM
woodym3 woodym3 is offline
Mein Auto: 88 M3, 96 328is, 99 M Cpe
Anyone know where to get these "Euro Formulations" recommended in some of these posts?
Old 08-18-2009, 11:00 AM
Oldman M Coupe
Look up PENTOSIN oil made in the father land.
Old 08-18-2009, 03:04 PM
Doc Holliday Doc Holliday is offline
Still Cruisin'
Mein Auto: 2003 325xi, 2001 Z3 3.0
I think jmillet works for Castrol or something.
BMW "approved" oil is a bunch of BS. Any high level synthetic at the correct viscosity is fine.
Remember, BMW is the same gang that tells you it's ok to go 15k miles on an oil change, and 100k on automatic transmission fluid. And before that, it was "lifetime" fill.
Why would you believe them when they tell you what the "approved" oil is?
While you're in warranty, use what they tell you to keep them from trying to find a way out of warranty work. Once it's out of warranty, ignore them like you should be ignoring most of their fluid recommendations.
Old 08-18-2009, 03:26 PM
an audience of One
jmillet has been very informative and appreciate his input
See post #19 - I think we are on the same page. I sent an email to Mike Miller of Roundel Tech Talk fame, and he said that a good synthetic of the proper viscosity is more than adequate. For my drivetrain, he suggested:
Crankcase: Redline 10W/40
Gearbox: Redline MTL
Diff: Redline 75W/90 with friction modifiers
^^^^ this is what I am going with
I Timothy 2:1-2
Old 08-18-2009, 04:27 PM
jmillet's Avatar
DOC: I don't give hoot what fluids you use in your Bimmers; that's your choice. I'm just trying to let folks know what the "official" BMW NA position is regarding engine oil so they can make an informed decision rather than an emotional one
And no I don't work for Castrol or anyone else for that matter
Jim Millet
diff, engine, gearbox, s52, viscosity
